07-11 MS3 Deatschwerks DW65C Fuel Pump I have two brand new open box item for 120 shipped to your door. They are brand new never installed I we just open the box to take a look inside. Part number is 9-651-1009 Gone are the days where you need to modify your fuel pump bucket to install an aftermarket pump. The Deatschwerks DW65C fuel pump flows 265 LPH and will allow your high performance MS3 to inject more fuel, run higher boost and make more power. All Deatschwerk fuel pumps are fully compatible with E85 fuel, adding an additional advantage over other manufacturer's pumps. All Deatschwerks fuel pumps are designed for quiet operation and connect directly into your stock fuel pump location. DW fuel pumps are packaged with an application specific installation kit to guarantee a precise fitment and perfect operation and are backed by DW's 3-year no-fault warranty! This part is the REAR fuel pump, NOT the cam driven fuel pump. This fuel pump is designed to be used in conjunction with an upgraded cam driven fuel pump. http://www.deatschwerks.com/images/s...00x600-300.jpg |
| All times are GMT -7. The time now is 04:35 PM. |
