Cobb Accessport , BOV, Intake, Cobb Accessport , BOV, Intake, ( Ca resident please add 10.25 sales tax to all orders) Please pm or call if you have questions. Accessport , Intake, Downpipe, BOV http://www.cobbtuning.com/images_products/cat_5869.jpg POWER. FLEXIBILITY. CONTROL. The AccessPORT is the industry leading OEM ECU flashing, managing and monitoring assistant. Unlock power hidden within the ECU by replacing conservative factory settings with more aggressive calibrations. The result is impressive gains in torque and horsepower while maintaining a high degree of safety. The AccessPORT comes with pre-installed maps that are optimized for common performance modifications. Tuning flexibility ranges from simply loading one of the included performance maps designed for common modifications, all the way to complete custom map authoring using our powerful AccessTUNER software. Extract maximum power from virtually any modification while retaining the driveability and sophistication inherent in the OEM ECU. http://www.cobbtuning.com/images_products/cat_5913.jpg Netting a + 11 HP and + 16 lb. ft. gain, the C.A.R.B. certified COBB Tuning SF Intake utilizes our custom CFD design to maintain optimal flow and generate ideal performance. The OEM MazdaSpeed airbox is the most restrictive stock intake we have seen to date. Simply replacing it with the COBB Intake will allow your MazdaSpeed3 safe and consistent power gains! The custom conical cloth filter feeds filtered air directly to the engine, while maintaining optimal intake velocity and minimizing turbulence found with many aftermarket intake systems. http://www.cobbtuning.com/images_products/cat_5924.jpg COBB Tuning announces the immediate availability of the COBB Turbo Inlet Hose for the MazdaSpeed 3. This sleek, high temperature silicone hose replaces the clunky plastic OEM piece. The interior features a uniform lining and incorporates a true taper design, eliminating any sudden neck-down in diameter found on lesser designs. The end result is a smooth, unrestricted path from the intake to the turbo inlet, adding power and improving engine responsiveness. http://www.cobbtuning.com/images_products/cat_5921.jpg The COBB XLE BPV is a compact and lightweight by-pass valve that is capable of holding very high boost pressure without leaking. Its unique design allows for extremely fast venting of boost when actuated. It is designed to operate in multiple venting modes and can be quickly reconfigured using simple hand tools. Innovative engineering and precision manufacturing result in a compact package able to fit in the confines of a tight engine bay. http://www.cobbtuning.com/images_products/cat_5915.jpg COBB Tuning has outdone itself with the COBB 3” Downpipe for the 2010+ MAZDASPEED3,which is a study in engineering design and artistic execution. The COBB 3” Downpipe replaces a very restrictive element in the Mazdaspeed3 exhaust system. Considerable effort was spent designing a flow path with the fewest number of direction changes and minimal degrees of bend in order to eliminate restrictions. This beautifully fabricated downpipe delivers significantly improved exhaust flow, resulting in faster turbo response time and power gains across the entire rev range, while still protecting the environment with its highly efficient custom catalytic converter. |
Got my Accessport today from ERZ. Thomas replies faster to PM's than most and the unit got here in one day. Thanks man! |
Quote:
Ordered my AP late Wed night. Shipped out Thu and received it early Fri. This guy is legit. Will definitely do business with again I hope. Thanks for the great service and best price on AP ANYWHERE! |
how much for a cobb bpv? |
Quote:
Thanks for all the order guys. |
I'm looking for an accessport but can't send you a pm yet (not enough posts). can you pm me? thanks. |
interested in the cobb bpv, anything tempting? thanks. |
Discussion with ERZ for a GFB Blow off. I thank ERZ for his patience. Because French which speaks English, that must not be easy to read. :lew::lew: |
| All times are GMT -7. The time now is 04:37 PM. |
