> CX-7 > Issues & Troubleshooting
 Old 06-08-2012, 09:07 AM   #1
trf5000's Avatar
Posts: 2,290   (View Stats)
Default CX-7 Won't Start When Hot
Ok so my parents own a 08 CX-7, and they are having an intermittent starting issue with it. Whenever the car is driven for awhile and parked for a short time (like driving 20 minutes and running into the grocery store) it won't start. When I say won't start, they turn the key and nothing happens, not even the click from the solenoid on the starter. They have to let it sit for a few hours and it starts right up.
My only thoughts are that the starter is taking a dump or the electrical connections to the starter are corroded. Anybody experience anything like this on their CX/MS3/MS6?
I remember reading that the speeds sometimes have the corrosion on the terminals, but I didn't know if there was any CX7 specific advice.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
 Old 06-09-2012, 04:46 PM   #2
Shortymazda's Avatar
Posts: 20   (View Stats)
Shortymazda will become famous soon enoughShortymazda will become famous soon enough
You could try checking to see if the cut off switch from the remote start is not staying engaged even after alarm is deactivated , had similar problem with my friend cx7. He ended up buying a new one.
Hope this helps!
Shortymazda is offline   Reply With Quote
 Old 06-09-2012, 04:47 PM   #3
purge valve.
 Old 07-24-2013, 03:58 PM   #4
EhMazda's Avatar
Posts: 1   (View Stats)
EhMazda is an unknown quantity at this point
Default 2007 CX-7 Wont start hot
My CX-7 will not start after being driven for a while and brought up to temperature , once I shut it off the lights etc still work but no cranking , just a very faint click , wait 15 minutes and it starts right up .... very frustrating .... any suggestions on what to check , cleaned the battery terminals but no help ....
Thanks
EhMazda is offline   Reply With Quote
Car won't start... ahfunaki Gen2 MS3 General Discussion 17 03-29-2012 10:48 AM
where to start jlaudioman18 Mazdaspeed3/6 General Discussion 4 12-20-2011 07:24 AM
Car won't Start funka09 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 06-30-2011 12:17 PM
If you could start over Whiteboy Mazdaspeed3/6 General Discussion 28 02-14-2011 06:29 PM
Let's Start Getting Some CX-7's Over Here! rexrzer CX-7 > General Lounge + New Member Welcome 28 11-08-2010 02:19 PM
Page generated in 0.24925 seconds with 23 queries
