> CX-7 > Issues & Troubleshooting
Like Tree3Likes
  • 1 Post By spoolnwhips
 Old 11-20-2016, 02:55 PM   #1
spoolnwhips's Avatar
Posts: 7   (View Stats)
spoolnwhips is an unknown quantity at this point
Default oil leak at exhaust manifold?
Hello, Ive developed an oil leak that pools up on the exhaust manifold, fills and overflows the triangular section with oil in 1-2 minutes at idle.
It was coming from between the mani and head at the yellow line so i pulled the manifold. By looking at the surface on the head and the gasket it appears to have been coming from the sideways t shaped hole in the head, circled in red. Is this an oil passage that is sealed by the exhaust manifold gasket?
TIA!
spoolnwhips is offline   Reply With Quote
 Old 11-20-2016, 05:36 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
It's probably from up above that at the valve cover gasket. Have you had it off recently?
Sent from my SM-G935V using Tapatalk
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 11-20-2016, 05:45 PM   #3
No definitely not coming from the v.c. I caught it right after it started leaking as it actually caught on fire it is not a slow leak and I have not had the valve cover off in this picture you can see the trail where the leak was it actually started to wash out the exhaust Port that it was leaking into in this picture you can see this thing on the head where it was leakingIMG_20161120_183155601_HDR.jpg
phate likes this.
 Old 11-20-2016, 05:46 PM   #4
Lol I don't know these engines is there supposed to be oil in the t section.
 Old 11-20-2016, 06:05 PM   #5
Eth Fiend
phate's Avatar
Oil shouldn't be in there. You sure that's the source? Is there oil pooled in that port...is the spark plug in that cylinder wet?
How's the car run, besides the massive oil leak?
-06 MS6
Last edited by phate; 11-20-2016 at 06:05 PM. Reason: MSF Database - Automerged Doublepost
Nliiitend1 (11-21-2016)
 Old 11-20-2016, 06:09 PM   #6
No the closer you get to the valves the dryer it gets only wet at the edge of the port and it looks like the port divide has been washed off a bit. I guess the head gasket could be leaking into the t section. Arrgh guess it's time for a leak down...
The car ran fine and wasn't smoking from the exhaust the engine was just starting to get loud from low oil when I shut it off other than that it ran great. On second thought there was a trail of light smoke from behind the car but not a thick fog. It may have been burning some of it but up untill now I had figured it was burning off the exhaust externally
Last edited by spoolnwhips; 11-20-2016 at 06:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-20-2016, 06:31 PM   #7
Eth Fiend
phate's Avatar
You might want to try cranking it over with the exhaust mani off. Use flood clear mode so it doesn't fire (gas pedal to floor while cranking). You might be able to circulate enough oil to see where it's leaking from.
Second person would be handy.
-06 MS6
 Old 11-20-2016, 06:33 PM   #8
Great info thx!! Proceeding...
 Old 11-20-2016, 06:46 PM   #9
Got it to crank for 15 sec or so now it won't crank anymore. It did this once before when I replaced the turbo and was priming the new one, had to wait a while before it would.crank again.. did not build enough pressure to see a leak.
phate likes this.
 Old 11-20-2016, 07:47 PM   #10
Damnit finaly got it to start seeping by cranking it. Bad news there's a crack through the port upwards and through the top of the head. Bs the car was full on fluids well maintained and had only been running for 2-3 minutes when it cracked I remember hearing a pop noise from the turbo area stopping at a light. Got on highway and by the end of the ramp I had smoke In the cabin.
Phate, Thank-you VERY much for your help!
phate likes this.
Last edited by spoolnwhips; 11-20-2016 at 07:47 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-20-2016, 08:25 PM   #11
Eth Fiend
phate's Avatar
Sucks to hear, but at least you didn't run it out of oil and take out the bottom end. Keep us posted on what you decide to do, or if you need help sorting that out.
-06 MS6
Engine bay exhaust leak tokoam Mazdaspeed3/6 General Discussion 2 03-30-2016 09:09 AM
exhaust leak AZST Mazdaspeed3/6 General Discussion 0 03-28-2015 12:21 PM
Exhaust Leak? mand2240 2010 MS3 - Troubleshoot/Diagnostics 4 02-06-2015 09:52 AM
Full Race Exhaust Manifold/Exhaust Combo mr.speedy3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 01-29-2015 07:56 PM
Exhaust leak kylec_2003 2010 MS3 - Engine, Transmission & Driveline 3 11-15-2010 08:12 PM
Page generated in 0.29609 seconds with 22 queries
