> CX-7 > Issues & Troubleshooting
  • 1 Post By Agitated C-X-7 Owner
 Old 12-07-2010, 08:20 AM   #1
Agitated C-X-7 Owner's Avatar
Posts: 7   (View Stats)
Agitated C-X-7 Owner is a jewel in the roughAgitated C-X-7 Owner is a jewel in the roughAgitated C-X-7 Owner is a jewel in the roughAgitated C-X-7 Owner is a jewel in the rough
Default Turbo Seal Failure/ Smoke from Exhaust Pipe: Mazda Technical Bulletin
*Official* TSB from Mazda regarding smoking Turbos
SMOKE FROM TAIL PIPES AFTER PROLONGED IDLE PERIODS
Applicable Models
Model Starting S/N Ending S/N Model Spec CX7 2007-2008 000001 209008 P/D BEFORE 2/15/2008 MAZDA6 2006-2007 000001 999999 ALL MAZDASPEED6 MAZDA3 2007-2008 000001 880368 P/D BEFORE 2/6/2008 Related Category/Subcategory/Symptoms
ENGINE / MECHANICAL / WHITE SMOKE,BLUE SMOKE
ENGINE / EMISSIONS SYSTEM / EXCESSIVE OIL CONSUMPTION
ENGINE / EMISSIONS SYSTEM / WHITE SMOKE,BLUE SMOKE
ENGINE / EMISSIONS SYSTEM / BLACK SMOKE
ENGINE / MECHANICAL / EXCESSIVE OIL CONSUMPTION
MTOL - 5505 Dealer Repair Information
Symptom and Conditions
Applicable Model(s) VINS
CX-7 JM3ER ****8* 209008 Produced before 2/15/08
MAZDASPEED6 ALL ALL
MAZDASPEED3 JM1BK ****8* 880368 Produced before 2/6/08
Some customers may experience white/blue smoke from their exhaust pipes
after prolonged idle periods and/or while driving in traffic at very
slow speeds.
This condition may be the result of the turbo's oil supply not being
able to adequately drain out of the turbo during long idle periods.
Vehicles having this concern should be diagnosed using the following diagnostics procedure.
Repair Procedure
1. Confirm that the proper maintenance intervals have been performed.
2. With the engine at normal operating temperature, allow it to idle
for an extended idle period.
Caution:
Closely monitor the engine coolant to the assure the engine does not Overheat.
3. If smoke from the exhaust is present after the extended idle period,
take before pictures of the smoke, then change the oil and filter
using 5W/40 (synthetic). After the oil change, in order to burn off
the oil that remains in the exhaust system, perform the following:
start the engine, check for oil leaks, then let it idle for 10
minutes, after the 10 minute idle period, increase the RPMs to 3000
for 1 minute, repeat idle test to confirm that no smoke returns.
A: If the smoke returns, contact the Technical Assistance Hotline
(Select option #2 for Major Assembly Authorization) with the oil
change history information, to attain an authorization for a turbo
replacement.
B: If smoke DOES NOT RETURN after the repeat idle test, NO other repairs
are to be performed at this time. Explain to the customer that MAZDA
is currently working on an improved positive crankcase valve (PCV)
system to reduce the engine crankcase pressures to allow the turbo's
oil supply to drain from the turbocharger more efficiently This fix
will be available approximately within 90 days and at that time the
oil will be changed back to 5W-30 and the improved PCV system will be
installed
Agitated C-X-7 Owner is offline   Reply With Quote
The Following 2 Users Say Thank You to Agitated C-X-7 Owner For This Useful Post:
DonMS6 (04-03-2015), iudesha (07-09-2012)
 Old 12-07-2010, 08:32 AM   #2
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Repost. Go back to the CX-7 issues and troubleshooting section and you'll see the same damn thing in the first thread.
The Following 3 Users Say Thank You to triplejumper18 For This Useful Post:
Black Metal (06-12-2011), FreeFlyFreak (12-07-2010), smitty5788 (12-07-2010)
 Old 12-07-2010, 09:34 AM   #3
Exclamation 2009 CX-7 Turbo Replacement/ Actual Turbo Seal Failure Problem
I reposted the Technical Bulletin to be on the top of this forum and because the other forum just has the members arguing about taking off from the drive way with full throttle. That does not discuss the issue at all.
I have a 2009 Mazda CX-7 (2.3 L Turbo) that I purchased New. At 25,000 Miles I noticed that the white smoke coming from the exhaust pipe during city driving conditions (Long Idle periods waiting for lights to turn color). I found the Technical Bulletin online and changed the oil to 5W-40. The white smoke stopped until 3,000 miles later it began again. I then took the CX-7 into the dealership for the 30K service package and asked them to investigate the Technical Bulletin that I found. They checked it and got the car to smoke. I got the turbo replaced at 30,000 Miles for free but it cost me $300.00 for the 30K service. I performed all oil changes and kept records which the dealership had asked for. I did not have a problem with the fact that I did all my own maintenance with diligent records.
 Old 12-07-2010, 09:50 AM   #4
Exclamation Root Cause of the Turbo Seal Failure
After a few months of researching this issue on other forums and reading the non OEM PCV system fixes for the CX7 Turbo issues. I believe I found what the underlining issue is that is causing the turbo seal failures to occur.
The root cause of this failure is the fact that at idle conditions, the crank case pressure of the engine increases due to air being sucked in through the PCV system. The increased crankcase pressure acts as a restriction to the oil return from the turbo. This causes oil levels to increase in the turbo until the level gets high enough to begin to push against the turbo seals. This repeated situation causes the turbo oil seals to eventually fail and allow oil to bypass it to the exhaust piping (Hot) which causes the white smoke to be created.
This does not happen during turbo boosting (Non Idle Conditions) because the amount of air flowing through the intake is high enough that it causes a bernoulli tube effect onto the PCV pipe. This means that the intake flow causes the pressure of the intake to be lower than the pressure of the crankcase which causes the crankcase to be vented to the intake and thus the crankcase pressure is not allowed to increase because it is vented.
This is the reason why the PCV pipe is 3/4" ID. PCV pipe ID's are typically 1/3 the size or smaller for non turbo charged engines.
There are two non OEM fixes: 1.) Noon Bolt and 2.) PTP Pill.
These fixes do not fix the high crankcase pressure condition occuring at idle. They only alieve the issue. The noon bolt fix takes the oil return bolt from the turbo and increases the orifice size by drilling a bigger hole to allow more oil to return to the engine block. The PTP Pill is an orifice that is put into the PCV pipe. This restricts the amount of air that is sucked into the crankcase however, it is not sized appropriately for the boosting operation and can actually cause the high crankcase issue in the boosting engine operation instead of idling.
The problem lies with the fact that our engines use an ingestive low pressure PCV system which takes Blow-By Oil and Contaminants (Hydrocarbons,Carbon Dioxide, others) and puts it back into the combustion process. This is the main reason why oil catch can systems are installed on our engines to reduce/eliminate this from getting into the engine. Allowing the excessive oil and contaminates back into the engine causes the following:
Reduced spark plug life • Fouled or damaged turbocharger or aftercooler • Reduced detonation margin, engine detonation = damaged pistons • Reduced load capability and operation • Reduced efficiency • Reduced component life.
The need for a better PCV system in our engines is very important for the reliability and elimination of future turbo seal failures that are costly.
Has anybody tired any other methods for modfiying the PCV system?
Speed3Pedro likes this.
Diehonda (11-11-2013), Speed3Pedro (04-28-2016)
 Old 12-07-2010, 10:07 AM   #5
smitty5788's Avatar
Posts: 1,065   (View Stats)
smitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the world
Groans: 215
Neutral  :  -2 score
do you think this is new info to anyone?
2011 DGM STI Sedan - Fully Bolted FP Green Setup
368WHP / 335WTQ
SOLD: Black Mica 2010 MS3 - Tech Package -CPE Catless DP - CS CBE - SURE Aeros - SURE Sidewinder - TS BPV - CPE HPFP - JBarone Shifter Bushings - TRZ RMM - MD OCC - Progress RSB - DashDAQ - 18x8.5 +45 Rays Gram Light 57F - 235/40 Potenza RE760
smitty5788 is offline   Reply With Quote
 Old 12-08-2010, 08:06 PM   #6
Exclamation
I know that this is not new information to everyone but I was trying to get the information gathered in one place so someone new to the issues does not have to search google endlessly for hours to try to come up with all this information. Also, if this is not new information, then why does there exist a true fix for this issue?
I still would like to know if anyone has tried to use solely a breather filter (Atmospheric Crankcase Venting) or if a series of check valves were added to the current PCV system?
Maybe a Combination of a Breather filter with check valves would allow for proper venting and operation without affecting check engine lights?
Any thoughts?
The Following 3 Users Say Thank You to Agitated C-X-7 Owner For This Useful Post:
Imsorryk (09-11-2013), iudesha (07-09-2012), MarcoAntonio (02-18-2013)
The Following User Says NO Thank You to Agitated C-X-7 Owner For This Un-useful Post:
FreeFlyFreak (12-08-2010)
 Old 12-08-2010, 09:31 PM   #7
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Originally Posted by Agitated C-X-7 Owner View Post
Any thoughts?
I have a thought, but I would have to label this thread "NSFW" to post it.
Suspension:
 Old 12-09-2010, 06:35 AM   #8
Dude, get the catch can that I sent you the link to. Collect the crap that goes into the intake and eventually into the turbo that spews the oil.
 Old 03-01-2011, 07:32 PM   #9
New tsb. http://www.mazdaspeedforum.org/forum/foru...38/#post750426
FreeFlyFreak (03-02-2011)
 Old 04-11-2011, 07:41 AM   #10
phimon's Avatar
Posts: 1   (View Stats)
phimon is an unknown quantity at this point
Newbie... Raider I can't find the link to the catch can and have this same problem.
Thanks,
Phil
phimon is offline   Reply With Quote
 Old 04-11-2011, 07:46 AM   #11
Well, the thread is in the for sale section of VIP where people have bought them. Donate $10 to the forum, you will get access.
his official website is here:
Home - Performance Automotive Engineering
Order the Speed 6 kit.
 Old 06-12-2011, 10:38 AM   #12
dokey27's Avatar
dokey27 is an unknown quantity at this point
Default 2007 CX-7 GT - Recall Idle Smoking - Mazda Fixed Free SSP84
Hey All,
Just wanted to let you know that as of June 2011, Mazda Canada is considering the turbo smoking after idle problem a recall. The Mazda cause code: SSP84. The FP part number is: L3Y1-13-S80B. The description is Ventilation Kit. The recall covers a larger section of production dates and up to 140,000km or i think, 7 years...need to check that. So good news. (Mazda doesnt cover this, if there have been any changes to the turbo.) Hopefully this problem is fixed...Fingers crossed!
dokey27 is offline   Reply With Quote
 Old 06-17-2011, 01:37 AM   #13
TonyN's Avatar
Posts: 28   (View Stats)
TonyN is a jewel in the roughTonyN is a jewel in the roughTonyN is a jewel in the roughTonyN is a jewel in the rough
the US market is SOL?
*07 Mazda CX-7 GT AKA The Baby Wagon
Baby Stuff
*05 Mercedes Benz E500 AKA The Daily
Apperance Package, Sport Package, Comfort Package, Lighting Package, Navi, Keyless Go, Airmatic Suspension, AMG Quad Tip Exhaust,
*94 Toyota Supra Turbo AKA The Garage Anchor
Precision 63 / Auto 3.8k Stall / Methanol Injection / Volk SF Challenge / Recaro Speed / Seibon / Eibach / KYB / Greddy / Bomex / C-West / RMM / Tial /
TonyN is offline   Reply With Quote
 Old 06-17-2011, 04:27 AM   #14
Nope. We have a tsb for it too.,just install an occ to collect the crap though. Fixed us.
 Old 07-10-2011, 06:46 PM   #15
queenfan's Avatar
Posts: 2   (View Stats)
queenfan is an unknown quantity at this point
Hi all. I have a 2007 CX-7. On Friday, I was stuck in a 5 hour traffic jam.
Two weeks earlier, my timing chain had been replaced under the powertrain warranty. After this, my engine began whining whenever I accelerated. Just a bit, but enough to be annoying.
So this brings us back to Friday. Heading out to the shuttle launch, I had a few times where I would accelerate heavily and the whining would get worse and my car seemed like she had an engine powered by two hamsters on a little wheel. Then, the traffic jam. After that, any time I tried to accelerate, the whining would happen.
I took her to the dealership to see if somehow the timing chain repair had affected the turbo, and they swore no, but said to call Mazda on Monday to see if I could get authorization to diagnose the problem. They told me the car was smoking, which it hadn't been doing, or at least not that I had noticed. I drove off, and she was smoking so bad I could have been driving a Bond car. I made a u-turn to get back to the dealership ASAP, and then my car started bucking like a mechanical bull. I was afraid she was going to stall. The dealership stated that they had no responsibility for causing this additional damage (even though the smoking started after they worked on my car) and that I was going to be responsible for getting Mazda to cover diagnosis and repair.
I came across this forum and see there are what appear to be 2 TSBs for this problem. At the same time, they aren't giving me a rental or anything. If there's a TSB, doesn't that mean that they are responsible for doing the work?
queenfan is offline   Reply With Quote
 Old 07-10-2011, 07:03 PM   #16
Welcome! Sadly, tsb applies only really under warranty. Out of warranty, you are fucked. Canada had a recall. USA did not.
The best thing to do is call mazda USA and raise hell.
We had our turbo replaced under powertrain (2007 as well) warranty at Classic Mazda of Orlando.
It still smoked after but not as much. As you might see in searches here, our pcv system sucks. If you donate $10 to the forum or VIP access (DVD nav updates, speed3 manuals, and the buy sell section. Look for the @MATT DAMOND oil catch can and install one. How to is in this section. Will collect the oil before it is fed back into the intake. Winning! Best $160 spent.
 Old 07-21-2011, 08:37 PM   #17
queenfan's Avatar
Default Grrr
Okay, so Mazda came back today and offered to pay half the repair. I tried to remind Mazda USA that not only is this a well-known problem, but they dealer seems to be the one who really hurt the car.
I asked them to clear up exactly what test the dealer did to determine the turbo was a goner; they said that they looked at it and could tell.
I've got a call in to the dealership's GM to raise hell with him--my car was working, they tested it, they killed it. I'm keeping my fingers crossed someone there has a conscience, but I rather doubt it. I can't get them to say what they did to cause the smoke, but the 2 TSBs on here help.
 Old 07-21-2011, 09:18 PM   #18
Groans: 196
Get big turbo, solve problem, go faster.
The Following User Says Thank You to triplejumper18 For This Useful Post:
Tony. (06-16-2012)
 Old 01-25-2013, 04:40 PM   #19
Peterspeed3's Avatar
Posts: 19   (View Stats)
Peterspeed3 is infamous around these parts
i just recently got home, and there is excessive blue smoke from the o2 sensor/ headers are. basically my turbo seal is leaking is what i think happened. also there is a lot of smoke from my exhaust. i have a stock turbo, vibrant headers, turbo xs downpipe, cobb sfi and cobb ffront mount intercooler. if anyone can tell me what are the other causes of this excessive smoke is id appreciate it. fml...
i have a 07 mazda speed3 btw lolol forgot to mention.
Last edited by Peterspeed3; 01-25-2013 at 04:40 PM. Reason: MSF Database - Automerged Doublepost
Peterspeed3 is offline   Reply With Quote
The Following User Says NO Thank You to Peterspeed3 For This Un-useful Post:
faeker (01-27-2013)
 Old 01-25-2013, 05:58 PM   #20
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
Groans: 106
shits broke!!
 Old 01-25-2013, 08:54 PM   #21
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
wow. dead thread revival.
I was unaware that Vibrant made an exhaust manifold for the speed 3's. so much so that it's not even on their own website. perhaps you meant exhaust. knowledge the fuck up.
Mods: stock
 Old 01-27-2013, 10:31 AM   #22
Groans: 106
ya i thought the same thing lol
 Old 06-06-2013, 12:06 AM   #23
USMCMAzda's Avatar
Posts: 95   (View Stats)
USMCMAzda is a name known to allUSMCMAzda is a name known to allUSMCMAzda is a name known to allUSMCMAzda is a name known to allUSMCMAzda is a name known to allUSMCMAzda is a name known to all
Groaned at 146 Times in 20 Posts
You would think they would have to do more about this..
USMCMAzda is offline   Reply With Quote
 Old 06-06-2013, 01:42 AM   #24
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Vibrant headers?
Cobb sfi?
Never heard of these things.
Either your turbo seals are blown and or your ringlands are cracked.
Pickles Tune in progress
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f518/turbo-seal-failure-smoke-exhaust-pipe-mazda-66588/
'14, low idle, smoke This thread Refback 04-28-2015 06:22 PM
New Daily Driver Happening Now... This thread Refback 01-06-2014 11:52 AM
[SURE Sidewinder Turbo Inlet for 2.3L MZR DISI: BLUE] OCN ????????????? This thread Refback 10-09-2013 08:54 AM
Украинский Мазда Клуб :: MazdaClub.UA > Порвем баян про турбу!!! This thread Refback 09-29-2013 12:13 PM
My Next Car Thread (Novella) - Page 19 - CICENetwork - Forums This thread Refback 09-27-2013 07:00 AM
My Next Car Thread (Novella) - Page 18 - CICENetwork - Forums This thread Refback 09-26-2013 08:53 AM
Порвем баян про турбу!!! - Украинский Мазда Клуб :: MazdaClub.UA This thread Refback 06-06-2013 06:15 AM
Turbo Rebuilt!!!! - Mazda 3 Quebec This thread Refback 05-30-2013 08:37 PM
Advice requested regarding a smoking 2008 CX7 : mazda This thread Refback 01-28-2013 07:41 PM
Exhaust Smoke???? Ian MazdaSpeed 3/6 - Troubleshoot/Diagnostics 48 11-28-2013 07:25 PM
Smoke from the exhaust bzwyatt CX-7 > Issues & Troubleshooting 21 11-20-2013 10:09 AM
Mazda Variable Valve Timing Service Bulletin for MZR DISI 2.3 Engine Funky MazdaSpeed 3 - Engine, Transmission & Driveline 13 12-22-2008 07:57 PM
Good seal-gasket for the tmic and cold pipe? gsrtype1 MazdaSpeed 3/6 - Turbo Induction 7 12-19-2008 02:42 PM
Turbo back exhaust vs CAI and down pipe? mehrdad02DLI Mazdaspeed3/6 General Discussion 16 05-10-2008 11:03 AM
Page generated in 0.49906 seconds with 33 queries
