| Blinder Xtreme Laser Jammer Blinder Xtreme is the TOP LED based Police Laser jammer on the market. The Blinder Xtreme covers all current Police Laser guns currently used by Law Enforcement. |
(Thread Starter) | Not Ranked : 0 score Seriously ive been wanting one of your laser jammers for like 5 years.
| Approved MSF Vendor ![]() Join Date: Dec 2010 Location: Lakeland,Fl
Rep Power: 121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Thanks for the welcome. Now is the time to buy with such great prices. |
| Not Ranked : 0 score Works so well that if you get a ticket from LASER while using Blinder we will pay it. |
![]() Join Date: Feb 2011 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
| Not Ranked : 0 score Come one day there may not be room for naughty drivers like us to slip about so let's have a little fun with it now!!
__________________ New: 2012 Mazda MX5 Miata True Red |
