Like Tree13Likes
 Old 09-30-2012, 07:39 PM   #81
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Originally Posted by kpsoerensen View Post
So I just got under my car to install the SSP occ. I guess I can't install it with CAI. shit. Also...it seems near impossible to do the install without removing the IM?
Sent from my space phone
PM me your email and I'll send you the SSP instructions. Also, check out JBRs instructions for removing the dip stick to get to the PCV valve
Blue Pu.
rfinkle2 (11-11-2012)
 Old 09-30-2012, 07:43 PM   #82
Oldturbonoob's Avatar
Posts: 26   (View Stats)
Oldturbonoob is a name known to allOldturbonoob is a name known to allOldturbonoob is a name known to allOldturbonoob is a name known to allOldturbonoob is a name known to allOldturbonoob is a name known to all
Groaned at 4 Times in 1 Post
It can be done with the intake on from underneath. The can sould still fit with a CAI. It mounts right by the horn. Your CAI goes that far?
Oldturbonoob is offline   Reply With Quote
The Following User Says Thank You to Oldturbonoob For This Useful Post:
EdgeAutosport.com (10-01-2012)
 Old 09-30-2012, 11:24 PM   #83
kpsoerensen's Avatar
Posts: 144   (View Stats)
kpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond reputekpsoerensen has a reputation beyond repute
Hmm well maybe I am looking at the wrong spot then. Do you have a picture of it mounted?
-~-2008 MS3 cosmic blue mica-~-
Orinda, CA 94563
kpsoerensen is offline   Reply With Quote
 Old 10-01-2012, 04:32 PM   #84
See post #67 of this thread.
 Old 10-04-2012, 01:16 PM   #85
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
So there isnt any reason this would not fit the MS6 is there?
700HP CLUB
11.479@124mph
#DIX
 Old 10-04-2012, 01:32 PM   #86
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Nope. Might have to find your own location to mount. But it will work as intended.
"Exclusivity" - CP-enis
Demodded.
The Seals
Downmented (10-04-2012)
 Old 10-04-2012, 05:16 PM   #87
Okay so there are two screw holes. One goes through the top of the mounting hangar for the horn and the second goes through a blank hole directly above this. That is the only way I can see this working. Though there is no threading on the blank hole so I suppose I will need to bolt it down?
Also, my bracket is Gen 1 specific -- so that is legit -- however the two curved tubes on mine look like Gen 2 rather than Gen 1 pipes. Whats up with that?
That didnt make any sense... I will post a pic when I get home...
Orinda, CA 94563
 Old 10-04-2012, 05:54 PM   #88
Downmented's Avatar
Groans: 493
Maybe thats something to note, the gen 1 and gen 2 seem to have either straight or bent tubes. I wonder if 1 would be better than the other.
Also, doesnt it need to be low enough that when it drains, it doesnt drain on anything?
700HP CLUB
11.479@124mph
#DIX
Last edited by Downmented; 10-04-2012 at 05:54 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-04-2012, 06:22 PM   #89
Actually I installed it with the top hole bolted via the bolt for the horn mount and used the bottom hole to mount the horn on (ergo replaces horn bracket). So only one bolt holds it on. Sounds like not enough but I've been driving it around on bumpy roads for around a week now and it hasn't moved (I also zipped up my hoses pretty well so that might help). Single bend elbows would have been easier than U adapters so I think you will be ok.
My picture of the drain location with this mounting scheme is on page two of this thread.
Last edited by Oldturbonoob; 10-04-2012 at 06:22 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Oldturbonoob For This Useful Post:
kpsoerensen (10-05-2012), rfinkle2 (11-11-2012)
 Old 10-05-2012, 12:35 AM   #90
Thank you big time.
Orinda, CA 94563
 Old 10-05-2012, 01:49 PM   #91
No problem. It kind of sucked figuring this out when I did it so that's why I decided to post it.
 Old 10-14-2012, 05:43 PM   #92
Andjo's Avatar
Posts: 937   (View Stats)
Andjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the world
Looks like this is going to be my next purchase
GT3076 and supporting mods with Kozmic Motorsports Built motor and tune
FUTURE MODS: 6266 with V-Band everything
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
2013 TROLL CHAMPION "DYLANFYHN"
Andjo is offline   Reply With Quote
The Following User Says Thank You to Andjo For This Useful Post:
EdgeAutosport.com (10-15-2012)
 Old 10-24-2012, 02:24 PM   #93
bump
 Old 10-30-2012, 08:43 AM   #94
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Going to be ordering soon
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
EdgeAutosport.com (10-30-2012)
 Old 10-30-2012, 09:21 AM   #95
cool we have more on the way
IshiKage (10-30-2012)
 Old 10-30-2012, 02:41 PM   #96
Gringo East's Avatar
Posts: 198   (View Stats)
Gringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the world
subbed
Gringo East is offline   Reply With Quote
 Old 10-30-2012, 02:50 PM   #97
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
2nd that on it can be done from under.
I took the damn OEM PCV and black breather box thing it sits on off from underneath. And then replaced it with a new one.
Probably would have been a good idea to take off the dipstick, but I didn't, just had fun moving heater hoses around.
Wiggling hoses the right way does wonders for removing them.
 Old 11-02-2012, 10:41 AM   #98
 Old 11-11-2012, 11:44 AM   #99
What's up dudes. I just installed the can. That damn tab is a frikin bitch.
Anyway, after about 15 miles of driving I get a little puff of oil smoke coming out of the tail pipe. When I start the car or begin to accelerate from a stop.
Just jacked the car up and checked all connections. All good there.
Any ideas?
Orinda, CA 94563
The Following 2 Users Say Thank You to kpsoerensen For This Useful Post:
EdgeAutosport.com (11-12-2012), JP@edgeautosport.com (11-19-2012)
 Old 11-12-2012, 09:22 AM   #100
Any ideas?
Is this going on? Let me ask the guys here and see what they think.
 Old 11-17-2012, 05:27 PM   #101
Okay my turbo or something is officially smoking now.
Right after I did the occ it began. Now it is full fledged.
Just to double check. I capped the little hole on my intake that runs to the valve cover - and capped the bottom of the IM. I ran lines to the catch can from the green 90degree elbow on the PCV, and the valve cover breather.
Any ideas what's up? Or is this just the inevitable and now I have to buy a BNR S3.
Orinda, CA 94563
The Following User Says Thank You to kpsoerensen For This Useful Post:
 Old 11-17-2012, 05:41 PM   #102
Tokay444's Avatar
Groans: 793
Not pulling enough vaccum out of the crank case to drain the turbo.
Demodded.
The Seals
JBR (11-18-2012), JP@edgeautosport.com (11-19-2012)
 Old 11-18-2012, 10:18 PM   #103
Mikey's Avatar
Posts: 2,049   (View Stats)
Mikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the worldMikey is the leader of the world
Groans: 104
Groaned at 45 Times in 36 Posts
Hey Eric, Do you guys have these in yet? I have been waiting over a week now for mine to make it here? lol I would like to crank up my boost and back to my E85 @ 25psi map. Been running my base BT map so I don't blow my dip stick.
2007 Cosmic Blue
Built HTA 3076 Corn Fed with shot of Meth and Freektuned
Mikey is offline   Reply With Quote
The Following 2 Users Say Thank You to Mikey For This Useful Post:
EdgeAutosport.com (11-19-2012), JP@edgeautosport.com (11-19-2012)
 Old 11-19-2012, 07:31 AM   #104
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
Hey @Mikey; thanks a ton for your patience. These are officially in transit. I think we're getting them today or tomorrow so yes, you'll get yours very soon
The Following User Says Thank You to JP@edgeautosport.com For This Useful Post:
Mikey (11-19-2012)
 Old 11-19-2012, 07:55 AM   #105
Mikey's Avatar
Groans: 104
Thank you, thank you
2007 Cosmic Blue
The Following User Says Thank You to Mikey For This Useful Post:
 Old 11-19-2012, 08:00 AM   #106
How many miles did you have on the car when you did this? Do you know how built up the manifold or intake is?
Since the PCV is no longer breathing into the intake manifold, at idle and cruise it will change the characteristics of flow in the IM and might be picking up some of the crap in the manifold.
How many miles have you driven since you put in on?
kpsoerensen (11-19-2012)
 Old 11-19-2012, 09:26 AM   #107
Hey thank you for the reply.
I have 93,xxx on the odo. When I take the TB and IM off there is usually oil deposits on everything. My valves don't look too good either. I blocked the EGR and cleaned the PCV valve thing (can't remember what it is called, the black box with the plunger) at around 75,xxx.
I have had the occ on for 60 miles.
The smoke is intermittent and doesn't happen consistently when I am at idle. On Saturday at around 40 miles on the occ the thing was pouring smoke out of the exhaust. Now it is back to wisps at idle.
Could it be that the system is clearing out? I don't even know of that is possible.
Orinda, CA 94563
 Old 11-19-2012, 12:09 PM   #108
Considering you had that many miles, you might be burning off what was heavily built up prior to putting the OCC on after the airflow has changed since vacuum acts a little different now. I would give it a little bit of time, say 500-1000 miles and see if it clears up. Built up oil can take a long time to burn off. At the end of the day, it's best to clean the intake system but obviously that a big task so if you can't right away, see if it clears up a little after a little driving time.
Also, monitor your AP. Just want to make sure it's running healthy during the time it's clearing out a bit.
 Old 11-19-2012, 12:14 PM   #109
triphop631's Avatar
Posts: 1,191   (View Stats)
triphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the world
Groans: 30
Can't wait for mine to get to me.
I haz Partz!!!!!!!!!!
triphop631 is offline   Reply With Quote
The Following 2 Users Say Thank You to triphop631 For This Useful Post:
 Old 11-19-2012, 12:20 PM   #110
Greet tip. Thank you JP. I will let you know how it comes along. I am really happy with it. I feel like my engine is thanking me. Like I quit smoking and my lungs are clearing.
Orinda, CA 94563
 Old 11-19-2012, 12:23 PM   #111
Just keep us posted because if it does continue to smoke after a long time, I'd like to figure out what else it could possibly be. I honestly think this is probably what it is but just keep us in touch.
 Old 11-20-2012, 07:55 PM   #112
Mikey's Avatar
Groans: 104
Hey guys. Is there a set date for the catch can to arrive?
2007 Cosmic Blue
 Old 11-20-2012, 08:08 PM   #113
btstarcher's Avatar
Posts: 4,852   (View Stats)
Arrive where?
SnailTune in progress
 Old 11-20-2012, 09:10 PM   #114
Mikey's Avatar
Groans: 104
ummm wow..I would think at their shop, where they send their shit out. I'm just guessing.
2007 Cosmic Blue
 Old 11-21-2012, 05:26 AM   #115
btstarcher's Avatar
No, just wondering if you're talking about the SSP OCC or something else. They've had them in stock for months now. If you actually read this thread you would have seen that.
 Old 11-21-2012, 10:28 AM   #116
Mikey's Avatar
Groans: 104
Dude really. If you would actually read and not worry about my business when I was talking to EDGE. This is what was said about 4-5 post up.
"Originally Posted by Mikey
Hey Mikey; thanks a ton for your patience. These are officially in transit. I think we're getting them today or tomorrow so yes, you'll get yours very soon"
Just let them answer their post man.
2007 Cosmic Blue
btstarcher (11-24-2012), triphop631 (11-22-2012)
 Old 11-21-2012, 10:35 AM   #117
triphop631's Avatar
Groans: 30
I am also curious as to when they will leave EDGE.
 Old 11-25-2012, 11:49 AM   #118
Emptied the can after about 270 miles. Lots of nasty stuff in there already. Not are if this is normal.
Also, still occasionally smoking at idle when I sit for a while. Saw a few wisps of smoke from the catch can itself before I emptied it.
All of this smoke is certifiably oil smoke.
Should I be doing anything differently?
Is this a unique case?
Most importantly should I pull the trigger on a BNR?
^ not sure if that picture loaded... Sent from my phone... If you can see it, that bottle is one of those blue crystal geyser ones. More girth than a regular water bottle. All that shit smells strongly of gas. Has the consistency of oil, and milky shit on top.
Orinda, CA 94563
JP@edgeautosport.com (11-25-2012)
 Old 11-25-2012, 11:51 AM   #119
All of that shit from the can smells strongly of gas. It has the consistency of oil, with milky shit on the top.
Orinda, CA 94563
 Old 11-25-2012, 12:04 PM   #120
Tokay444's Avatar
Groans: 793
And that's why we run an occ.
Demodded.
The Seals
JP@edgeautosport.com (11-25-2012), STY? (12-08-2012)
HPFP are back in stock and ready to ship www.cp-e.com Custom Performance Engineering (cp-e.com) 0 07-26-2012 07:38 AM
DeatschWerks Fuel Pumps IN STOCK READY TO SHIP! JP@edgeautosport.com EdgeAutosport.com 4 02-24-2012 10:54 PM
Chevy Volts ready to ship, just need official EPA mileage stickers Haltech Automotive News 0 11-17-2010 04:40 PM
COBB Tuning SF Intakes - In STOCK and Ready to Ship ! MS3 & MS6 kevin@gripgarage.com Mazdaspeed3/6 General Discussion 0 08-03-2009 12:43 PM
In stock items ready to ship Performance Racing Mazdaspeed3/6 General Discussion 0 04-24-2008 01:01 PM
Page generated in 0.58235 seconds with 34 queries
