 Old 10-15-2013, 11:59 AM   #1
rcisdrummer's Avatar
Posts: 52   (View Stats)
rcisdrummer has a reputation beyond reputercisdrummer has a reputation beyond reputercisdrummer has a reputation beyond reputercisdrummer has a reputation beyond reputercisdrummer has a reputation beyond reputercisdrummer has a reputation beyond reputercisdrummer has a reputation beyond reputercisdrummer has a reputation beyond reputercisdrummer has a reputation beyond reputercisdrummer has a reputation beyond reputercisdrummer has a reputation beyond repute
Default AUTOTECH INTERNALS QUESTION
I'm a newb. I've been reading for a week or so. I've learned a lot; I know I need to upgrade my fuel pump first. That said, I ordered a Borla exhaust first. Anyway, next is the internal upgrade. My question is: If my only upgrade are the internals and exhaust, will running everything stock for a while with new internals cause an issue with fuel? i.e., running rich/lean, or change how my car is moving fuel? I hope I asked the question correctly.
I'll also be buying the V3 AP when I upgrade the internals.
Thanks, I'm just a novice tuner. Would like to run Stage II soon.
My order of upgrades:
1. borla
2. internals/AP
3. Corksport Stg II SRI, RMM, and colder plugs
after that, I don't know.
kevin
rcisdrummer is offline   Reply With Quote
The Following User Says Thank You to rcisdrummer For This Useful Post:
EdgeAutosport.com (10-16-2013)
 Old 10-15-2013, 12:18 PM   #2
JgamB's Avatar
Posts: 2,566   (View Stats)
If that Borla exhaust is a cat back only, it's not going to do much of anything for your back pressure, and shouldn't give you any issues.
Add a test pipe and e-tune from one of the great tuners on here and you're done with the best bang-for-the-buck mods.
 Old 10-15-2013, 12:19 PM   #3
GARRETHEXTREME's Avatar
Posts: 516   (View Stats)
GARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the worldGARRETHEXTREME is the leader of the world
Welcome man!
Internals is always good idea to install immediately for peace of mind. It just capable to push fuel more than the stock, which can enable you to mod more and make it more powerful without worrying the fuel pump isnt pumping fuel enough. You should be fine with the new internals and that mods. I havent got internals, since i dont have money now! haha, but it will be definitely my next upgrade.
What RMM are you planning to run on?
2008.5 Mazdaspeed3 GT
MODS:
ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP
Running on Freektune OTS+ Map
Possibly the first deaf MS3 owner here? hmmm...
GARRETHEXTREME is offline   Reply With Quote
 Old 10-15-2013, 12:29 PM   #4
Originally Posted by GARRETHEXTREME View Post
Welcome man!
Corksport RMM vs. the JBR. I'm going to get some opinions and do more thread reading first!
Welcome man!
Yes, it's the Borla catback. I need to keep it legal, pass emissions testing in Nashville TN.
Last edited by rcisdrummer; 10-15-2013 at 12:29 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-15-2013, 12:33 PM   #5
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
No step colder plugs.
I've said this at least a billion times on here.
RUN THE HOTTEST PLUGS YOU CAN WITHOUT PRE IGNITION.
If your plugs are too cold you will foul them out.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 4 Users Say Thank You to smoogs12 For This Useful Post:
dsb_chicago (10-15-2013), Fatpig78 (10-17-2013), trancehead (10-15-2013), Zpuhalla (10-15-2013)
 Old 10-15-2013, 12:39 PM   #6
Which brand plugs do you suggest? I know at some point before Stage II the stock plugs will have to come out.
Thanks for the tip!
 Old 10-15-2013, 01:08 PM   #7
jm211's Avatar
Posts: 943   (View Stats)
Nkg oem if you want
I have used the autolites for a while and work just find. Go stock heat range.
You r on right track. What car u have?
Dont forget maintenance like tranny fluid and diff fluid if u have a 6. Leak test and clean ur valves.
Compression/leakdown test will give u idea of engine health.
 Old 10-15-2013, 01:08 PM   #8
Zpuhalla's Avatar
Posts: 244   (View Stats)
Zpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the worldZpuhalla is the leader of the world
Groaned at 32 Times in 14 Posts
Good info, I have heard this can happen. Is it an overtime issue or pretty quick thing.
Zpuhalla is offline   Reply With Quote
 Old 10-15-2013, 01:11 PM   #9
Originally Posted by jm211 View Post
Nkg oem if you want
I've got a 2013 White speed3. Thanks for the info! Right on track?? You mean for the order of upgrades?! Thanks! I don't want to blow my ride!
 Old 10-15-2013, 01:16 PM   #10
smoogs12's Avatar
Groans: 423
Depends on how much heat the insulator is actually retaining.
Too much and you get pre ignition (get step colder). Too little and you get plug fouling (get step hotter).
It all abou how far to either end of the spectrum you are. Every case is different.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 10-15-2013, 01:32 PM   #11
jm211's Avatar
Ok, brand new car. Nice!
FP, AP, Intake, a TP and an etune will get you cruisin!
The Following User Says Thank You to jm211 For This Useful Post:
 Old 10-15-2013, 02:40 PM   #12
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I would recommend the JBR88 or the CPE Stage two as i feel they are the best offerings for RMM.
I do not have person experience with the stage 2 cpe do plan on moving to it over the winter.
The JBR88 i helped install on a friends car. hardly any added NVH i was quite impressed
Damond Built Speed 6
 Old 10-15-2013, 02:46 PM   #13
lk250f's Avatar
Posts: 253   (View Stats)
lk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the world
Borla is an axleback for GenPu's BTW. I have the Corksport RMM and am impressed with it. 70d vibes less than stock almost, 80d vibrates but is not bad at all.
2013 CWP Mazdaspeed3
lk250f is offline   Reply With Quote
 Old 10-15-2013, 03:01 PM   #14
^^^^^^ I heard many good things about JBR88, that's what I would go for when I get the money. I just want to get rid of these annoying wheel hops, as well improving the shifting!
MODS:
 Old 10-15-2013, 03:04 PM   #15
Primus sucks. This is a dumb question, but what is GenPu? Are you suggesting the Corksport CBE over the Borla?
lk250f (10-15-2013)
 Old 10-15-2013, 03:12 PM   #16
haha, Genpu means Gen 2 ms3, and Genwon means gen 1 ms3
MODS:
 Old 10-15-2013, 03:14 PM   #17
jd's ms3's Avatar
jd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond reputejd's ms3 has a reputation beyond repute
@rcisdrummer; This is what you should've followed along with the RMM. Why did you get the exhaust first?
jd's ms3 is offline   Reply With Quote
 Old 10-15-2013, 03:22 PM   #18
zephgrave's Avatar
Posts: 162   (View Stats)
zephgrave is a glorious beacon of lightzephgrave is a glorious beacon of lightzephgrave is a glorious beacon of lightzephgrave is a glorious beacon of lightzephgrave is a glorious beacon of lightzephgrave is a glorious beacon of light
OP I'm on same track as you. I'm getting ap and internals by next month. I think the wife would flip if I got them now. Edgeautosports has like a deal on getting both at the same time.
zephgrave is offline   Reply With Quote
The Following User Says Thank You to zephgrave For This Useful Post:
 Old 10-15-2013, 03:30 PM   #19
It's not installed yet. Hasn't arrived yet, so I could possibly still get the Corksport. What's the difference? I thought they were the same exhaust set up.
 Old 10-15-2013, 03:31 PM   #20
lk250f's Avatar
Go with whatever exhaust you like. The Borla is only an axleback though. I recommended the Corksport rear mount. And Primus did suck, Les stopped that phrase in the mid 2000s. Good to see another fan, though!
 Old 10-15-2013, 03:40 PM   #21
jd's ms3's Avatar
I don't have an opinion either way on the exhaust! I was more or less saying that if you need to pass emissions, leave the exhaust alone all together and get internals, ap, intake, and RMM and be happy for awhile.
 Old 10-15-2013, 03:47 PM   #22
Sure. Makes sense. I"m more or less taking that route.
Awesome! Glad to see a Primus fan as well. I threw the Sux out to see the response! I love it. Primus is my favorite band; certain albums mind you. I've been listening to them since "92 or so. I'm a drummer here in Nashville; day job then hit the skins off hours. Anyway, Tim Alexander is in the practice space again. He's been jamming for a month or so with them. I can't wait to see what comes of it.
Last edited by rcisdrummer; 10-15-2013 at 03:47 PM. Reason: MSF Database - Automerged Doublepost
lk250f (10-15-2013)
 Old 10-15-2013, 04:21 PM   #23
lk250f's Avatar
Wish I could say the same myself. Only been a fan for a few years since I'm a youngin. Herb is an amazing drummer so I love all of his albums he recorded with the group. There is a antipop is my favorite Brain album. Good luck with the car!
 Old 10-16-2013, 04:07 PM   #24
Lots of good info in here!
Here is a modification guide on our site that might help you out with your research.
Send me a PM and I'll get you setup with the combo deal for Autotechs/AP.
azazelthegreat (10-16-2013)
 Old 10-17-2013, 06:57 PM   #25
Great info! Thanks everyone!
And, three more posts to go...
Last edited by rcisdrummer; 10-17-2013 at 06:57 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-17-2013, 06:59 PM   #26
zephgrave's Avatar
Yesss the info it's great
 Old 10-17-2013, 07:08 PM   #27
Last post before I can PM edge...damn.
EdgeAutosport.com (10-18-2013)
 Old 10-17-2013, 07:09 PM   #28
zephgrave's Avatar
I was wanting to do that deal but I just bought my ap today all I need now is the internals
 Old 10-17-2013, 07:17 PM   #29
I tried Pming, not sure if it got to you...
 Old 10-17-2013, 07:20 PM   #30
zephgrave's Avatar
Rcisdrummer are you on that site on Facebook for the new or parts? It's a pretty good place for deals. I heard this is too but I haven't donated yet
 Old 10-17-2013, 07:28 PM   #31
Which site? Think I missed something. I don't use Facebook. No cell phone either.
 Old 10-17-2013, 07:29 PM   #32
zephgrave's Avatar
It's a Facebook page it's called mazdaspeed new/used parts
 Old 10-17-2013, 07:31 PM   #33
I haven't donated here yet. I've got 120sq ft of hardwood to put down, a room to paint, and a MPS to get a few bells and whistles the next couple months, and then a little something for these tweekers.
 Old 10-17-2013, 07:42 PM   #34
zephgrave's Avatar
Yah I've had this car for a few months now and just been putting money away every paycheck. Now I've been buying parts and setting them aside to put them all on after I get the internals
 Old 10-17-2013, 07:45 PM   #35
12aven's Avatar
Posts: 15   (View Stats)
12aven has a spectacular aura about12aven has a spectacular aura about12aven has a spectacular aura about
Edge Auto has it well laid out but I would do additional reading and research as I dont feel it is as good as others advice.
^^ Thats on the $$^^
Exhaust isnt recommended until your making over 350(? correct me if I'm wrong). TP, and much later DP, is recommended on the exhaust side. So you need to let us know if its for the sound or performance. My TP keeps me sounding stock at idle and aggressive enough when moving or zoom-zooming.
I much prefer the sound of the turbo from my SRI/TIP amd the BPV anyways. I bought turbo, not muscle.
12aven is offline   Reply With Quote
 Old 10-17-2013, 07:51 PM   #36
zephgrave's Avatar
Yah I felt the same way. now I have SRI/TIP cobb, and a V2 ap on the way. In the next couple weeks I'll have internals on the way. The next upgrade I want after that is a DP and a TMIC after that.
 Old 10-17-2013, 08:07 PM   #37
Well, to start I'd like a little more performance. The car is my daily driver to work and my travel car. I work 3 days a week and have time to hit the road for a while. I want to keep it for as long as it will run (+100,000 miles); moderate mods, able to run Stage II on occasion later but I won't do it often. Stay in Stage I tunes and flash to stock for my trips and such. I thought about the CS Stage II SRI since it has the TIP included for a decent price. Upgrading my internals, plugs, RMM, and getting the V3 AP. Enjoy that for a while then see what I'm feeling like.
I looked at the Borla, Cobb, and Cork exhausts; but like the ARK. I'd like a nice sound; a presence if you will. Not a fart box I hear running around Nashville; but low, tonal at idle but makes it self known. Tight and low I guess. Something that can lend itself for a little of both performance and sound. Listening to shit on youtube is hard to get a natural feel. I'm even using studio monitors to listen.
 Old 10-17-2013, 08:13 PM   #38
Zpuhalla's Avatar
That's what they all say... same with E85...
ATP GTX3067R, ATP Catted DP, HTP 3" Intake, UR FMIC, Stratified GA, Stratified EBCS, Bilstein B8's, Cobb Springs, JBR RSB, JBR Mudflaps, JBR OCC, GFB 50/50 BPV, Autotech Internals, JBR Shifter Bushing, Cobb RMM, Cobb AP
 Old 10-17-2013, 08:17 PM   #39
Uh oh. You saying I'll just run like hell all the time?!! Once I get a taste I won't stop...
 Old 10-17-2013, 08:23 PM   #40
Zpuhalla's Avatar
yes... Once you taste the kool-aid, it's hard to resist..
Autotech internals retainer question Stingray69 2010 MS3 - Fuel, Nitrous & Water Injection 1 02-16-2013 02:38 PM
Autotech internals question kpsoerensen MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 34 12-28-2012 07:10 PM
Page generated in 0.58297 seconds with 31 queries
