Like Tree11Likes
 Old 09-27-2012, 11:03 AM   #201
Domino81's Avatar
Posts: 5,081   (View Stats)
Sometimes I feel like a woman in a man's body, do you sell a product for that?
kritz likes this.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
The Following User Says Thank You to Domino81 For This Useful Post:
smoogs12 (09-27-2012)
 Old 09-27-2012, 11:16 AM   #202
Philgire's Avatar
Posts: 1   (View Stats)
Philgire is an unknown quantity at this point
Originally Posted by JP@edgeautosport.com View Post
I would definitely run stock hangers. Rubber = less noise, vibration, harshness. Bad for motor mounts, good for hanging exhaust on a street car. No other parts are necessary. You reuse the turbo gasket and the CPE DP is made with a large beaded end so it replaces the donut gasket from the factory and just hooks right up to an aftermarket 3" exhaust.
Any of the inlet pipes create the louder whoosh. I've actually never been in one with a CAI so that might be louder.
I just bought my wife an 08 Speed3 with 6400 miles on the clock. The first mod I did to my car was a TBE and Cobb AP running stage 2 for an 05 STi, made a world of difference in power and drivablility. With such low miles on the Speed3 I am torn between buying a full set of motor mounts from either CP-E or Sure or starting off with just a Cobb AP and stage 1 tune. As she is not into high hp and spirited driving I am leaning more toward motor mounts for reliability especially the RMM. I have read the reviews for both the CP-E and Sure and seems the biggest difference is rubber vs. urethane. Was your basis above for saying "bad for motor mounts," because of material breakdown between rubber and urethane or because of NVH?
Cheers,
Mike
Philgire is offline   Reply With Quote
 Old 09-27-2012, 11:23 AM   #203
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
spit or swallow?
Mods: stock
 Old 09-27-2012, 02:56 PM   #204
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Cheers,
Mike
Rubber just flexes too much for a motor mount. Of course, we here at MSF like everything as stiff as possible...
If I had to choose between a RMM and AP for your wife, I'd go with the RMM first. With the AP, you'd find yourself wanting A HPFP upgrade next to run more boost, then the modding bug would bite you HARD. Next thing you know you're putting in racing seats and a full roll cage.
Tapadatass
EdgeAutosport.com (09-27-2012)
 Old 11-07-2012, 10:30 PM   #205
HardHitter's Avatar
Posts: 313   (View Stats)
HardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond repute
I bought my 2012 Mazdaspeed3 with tech on Saturday with around 17-20 miles on it. I promised myself that I would not mod the car with the car having a warranty but I don't know how much longer I can last.
I found $383 in my PayPal account that I did not know about and I found out you can finance for 6 months with 0% interest and that has led me to this thread and questions.
With that said, I am looking to add power and "sound" without violating any CARB laws (Live in CA). I'm looking to keep the engine bay "stock" looking to a smog tech (going with all black silicon/parts)
I was thinking the following setup for now but wanted to get your thoughts (If something isn't CARB legal, please let me know):
First Set of Mods:
SRI/TIP: Cobb (CARB legal?)
Autotech Hi-Volume Fuel Pump (I don't think the smog tech will know)
Forge Motorsports V2
RMM: Which brand and one do I go with?
Second Set of Mods (Occurs after warranty):
Cobb AccessPort
Cobb Downpipe (Carb legal?)
Cobb Exhaust
Third Set of Mods
Big Turbo
Is there anything I'm missing or you would suggest replacing or moving around?
HardHitter is offline   Reply With Quote
 Old 11-07-2012, 10:38 PM   #206
lilred's Avatar
Posts: 5,792   (View Stats)
Maybe I'm wrong but I Cobb intake is carb legal for gen 1 pending for gen 2, corksport is only genpu carb legal?
Removing a cat (downpipe) will not pass and violates carb but a test pipe can easily be swapped back for the test.
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 11-09-2012, 01:15 AM   #207
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
First Set of Mods:
Cobb AccessPort
Cobb Exhaust
Third Set of Mods
Big Turbo
Maybe this is the wrong way to look at it but seriously you have a new car and if i'm not mistaken you have 5years before you have to worry about any smog certificates.
If anything start off with internals and an accessport and see how things work out. If for any reason you need to smog or get warranty work you can easily cover up traces of an accessport
Just my .02 cents
Sent from my EVO using Tapatalk 2
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
The Following User Says Thank You to turbo test For This Useful Post:
lilred (11-09-2012)
 Old 11-19-2012, 05:22 PM   #208
Dumyz's Avatar
Posts: 402   (View Stats)
Dumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the world
Groans: 27
Groaned at 6 Times in 2 Posts
Got any CBE's laying around the shop that you'd want to give to me for free?!?!?
2010 Mazdaspeed 3 - Sold
New: 2008 Toyota Tundra
Dumyz is offline   Reply With Quote
 Old 12-11-2012, 12:49 PM   #209
Dream20b's Avatar
Posts: 373   (View Stats)
Dream20b is the leader of the worldDream20b is the leader of the worldDream20b is the leader of the worldDream20b is the leader of the worldDream20b is the leader of the worldDream20b is the leader of the worldDream20b is the leader of the worldDream20b is the leader of the worldDream20b is the leader of the worldDream20b is the leader of the worldDream20b is the leader of the world
Groaned at 27 Times in 20 Posts
Not sure if this has been asked, but will my 3" ATP Downpipe bolt up to my stock cat-back?
Dream20b is offline   Reply With Quote
 Old 12-11-2012, 01:04 PM   #210
faeker's Avatar
Groans: 731
Because i filled my dickhole response quota i shall play nice; yes with an adapter. No i will not link the part.
tappy-tap-tappytalk
Mods: stock
Dream20b (12-11-2012)
 Old 12-11-2012, 01:07 PM   #211
Cujo's Avatar
Posts: 1,192   (View Stats)
Groaned at 6 Times in 4 Posts
I saw you guys offer the GFB Respons on your site. I was wondering what your opinion of it was.
2012 Mazdaspeed3 Black Mica
 Old 01-06-2013, 03:30 PM   #212
OverBoosted's Avatar
Posts: 1,608   (View Stats)
I just installed A COBB sri and I want to make sure the noise it is making is right. under low boost it almost sounds like my bpv is leaking. not sure as this is the first turbo'd car I've had with an upgraded intake. any advice would be helpful. I've tried searching but can't find an answer.
 Old 01-06-2013, 04:53 PM   #213
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
An aftermarket SRI will sound different than stock. Almost like a whistling sound. I am sure your fine.
 Old 01-06-2013, 06:02 PM   #214
yea i found some vids on you tube and it seems right.
 Old 01-07-2013, 07:12 AM   #215
jay32m's Avatar
Posts: 161   (View Stats)
jay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant future
Question: Is it possible for springs to warp (or shorten) if ridden around on blown struts for a good period of time? I ask because I had my struts and shocks replaced with Sensen's and now I'm getting a clunking noise when I hit bumps. The tech showed me how loose the springs were in the struts while in the air. He was able to move them and said it seems like the strut is too tall for the spring or something. I admit I probably over did it on the stockers that's why I ask. Do I need new springs now?
Cobb SRI // Cobb AP // SU Turbosmart BOV // CNT Catless TBE // PG FMIC // SU RMM // JBR PMM 70D // TWM Shifter Bushings // Eibach Pro Kit // Sensen Struts/Shocks // 18x7.5 Konig Countersteers // Moddiction Anvil 2 knob // Autotech Internals
jay32m is offline   Reply With Quote
 Old 01-07-2013, 09:42 AM   #216
The Nut's Avatar
Posts: 1,571   (View Stats)
Cobb SF is C.A.R.B. legal, TIH isn't. Who cares though, for us Gen2's we've got between 5-7 yrs. here in Cali before our 1st smog check. In the next few years there doing away with the standard smog check (at least the sniff test) anyway. They're just gonna plug into our OBD2 ports, make sure there are no codes, including ones being blocked, and send us on our way.
No aftermarket DP of any kind is legal. Our car has 2 CAT's, the most you can keep with a turbo back is one. So find a spot in the garage or (get a guy you go to).
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 01-07-2013, 09:47 AM   #217
The Nut's Avatar
When you start from a cold start, that whistling noise is the SRI sucking in rediculous amounts of air and spooling up your turbo. It's especially loud for the first couple of weeks cause 1) your not used to the sound. And 2) your ecu (reprogrammed or not) takes a while to get used to it. It'll get much quieter after a few weeks, but will still never sound as quiet as the stock choke box.
 Old 01-07-2013, 09:59 AM   #218
its not a whistle noise. its the same sound the stock bpv makes when you let off the throttle, it just does it on spool up. Once I get to about 4-4.5rpm it starts to whistle. i'm assuming its just the sound of sucking the air in. I'm going to just check and make sure everything is tight in a little bit.
 Old 01-07-2013, 10:30 AM   #219
moomooz12's Avatar
Posts: 378   (View Stats)
moomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the world
I'd actually be more worried if there was a whistle noise coming from my engine bay. The sound the sri makes is a sucking sound.
Autotech HPFP Internals || Corksport TBE || cp-e FMIC || JBR 3.5" WP Intake || JBR TIG & Coolant bypass || JBR EGR delete || JBR OCC || JBR BSD || JBR 88 Trilogy Mounts|| JMF Direct Port Meth Inj IM || Stratified 2-Port EBCS || Turbosmart BOV || NGK colder plugs || Swift springs || JBR RSB
|| Snow Performance//Devils Own WMI
Self Tuned @ 330whp/352wtq 10/19/2013
moomooz12 is offline   Reply With Quote
 Old 01-07-2013, 10:37 AM   #220
Finally you tubed it and sounds like all the ones on there. Also checked and everything is nice and tight. Just wanted to make sure, thanks for all the input.
Tapatalked
 Old 01-07-2013, 10:44 AM   #221
The Nut's Avatar
Tapatalked
Mine sounds the exact same way. The air sucking sound is pretty loud when your not used to it and really screams when you get over 4000 rpm's. you should hear how load it is with an inlet hose on there too.
OverBoosted (01-07-2013)
 Old 01-07-2013, 11:16 AM   #222
I will soon, just waiting for the right one to pop up in the for sale section. And I thought I was going to mod this car...foolish me.
Tapatalked
 Old 01-07-2013, 12:07 PM   #223
Burn69's Avatar
Posts: 143   (View Stats)
Burn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to behold
Groaned at 7 Times in 4 Posts
What size/offset 18 in wheel do I need to a 255/35/18 to fit with no rubbing front/rear? Also possible to use a 275/35/18 on 2012 speed3 w/o rubbing? Size/offset needed to clear?
2012 Speed3 w/ Tech. / SURE Full3 Aeros & TIP Combo / SURE Shortcut w/ Counterweight / SURE TorqR3 RMM / SURE AGS Shift Knob / COBB AP Programmer / CNT CBE Blue Tip / UR Test Pipe / RallyArmor Flaps / SPC Rear Camber Arms / MORE (coming soon).....
Burn69 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Burn69 For This Un-useful Post:
faeker (01-25-2013), mituc (01-26-2013)
 Old 01-25-2013, 12:18 PM   #224
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
About to order my koni yellows, swift springs, and whiteline anti lift kit from edge. I'm not one to fiddle with shit once it's installed properly, that being said, what do you guys recommend for the rear rebound settings? Considering the rears have to be removed to adjust I'd like to get it comfortable the first go around. Car will more than likely not see a track again but I do like things to be a bit more aggressive. I was thinking somewhere in the middle but have no previous suspension experience and have nothing to compare it to. Thanks!
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
 Old 01-25-2013, 01:07 PM   #225
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
Good question. To be honest, it's all up to the end user and how you like it set up. Some people like it stiffer and some people like it not so much. Considering there's only 3 settings on the yellows, I would put it in the middle and see how you like it.
Sorry this never got answered. I honestly don't know the exact offset need. If I were to guess, you'll need a +45 or less. I can tell you the 275 is going to be hard pressed to fit. Even if you do it, chances are it will rub. I know the GenPus have much nicer gaps to play with though. Check out the wheel and tire section for GenPus. That's where I go to see what others have done.
Last edited by JP@edgeautosport.com; 01-25-2013 at 01:07 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-25-2013, 03:09 PM   #226
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
What size EWG fits on the CPE turbo manifold?
Performance:
Stratified Tune in progress
The Following User Says Thank You to Swinger13 For This Useful Post:
EdgeAutosport.com (01-25-2013)
 Old 01-25-2013, 06:07 PM   #227
It's a 44mm EWG flange
Swinger13 (01-25-2013)
 Old 01-25-2013, 11:29 PM   #228
Bob-o's Avatar
Posts: 1,312   (View Stats)
Did you guys run a dump tube on your shop car's EWG? Also was it a manifold mounted EWG? Or an EWG hotside?
Also does your EWG kit come with a dump tube and all the other goodies so its 100% bolt on?
 Old 01-26-2013, 12:00 PM   #229
When we had the CPE mani on, we were still using the EWG on the turbine housing of the turbo. The kit on the site for the ATP EWG Bolt-On kit includes the dump tube, wastegate, turbo, and lines.
JP
Bob-o (01-26-2013)
 Old 01-26-2013, 12:42 PM   #230
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
You will never be able to run anything wider than like 245 without rolling your fenders. Anyway, 235 should be more than enough, even the 450+whp guys here don't have wider tires than that (some of them may be using 245's though).
275 is going to be insane, inefficient and totally unnecessary. And your MPG will drop significantly along with the acceleration, handling and steering response. Oh, and running that wide in front will put a lot of stress on your power steering pump which may blow up in hot summer days.
Usually when you think about purchasing a part you should know why you want it and what you expect from it. If you want it only for the cool factor then just set it to any stiffness but just make sure it's the same both in front and back. But here are some newby explanations about how the swaybars work:
Increasing the swaybar stiffness will increase the rigidity and will reduce the angle and distance the two shock absorbers will move one from the other. If you drive your car on a smooth track you may want stiffer settings. If you drive your car on the street or on bumpy tracks you may want a more elastic/soft setup.
If you change only the front sway bar for a stiffer one without making any other changes (camber?) you may end up understeering more on bumpy roads/tracks because the back of the car will have a softer setting and this will give it more grip.
If you put a stiffer swaybar in the back you will oversteer more (and unpredictably) on bumpy roads or tracks because the back of the car will jump more.
So if you want to change the swaybars make sure you change them both and you get a front+rear set from the same manufacturer. Personally I'd invest more in a better coil over setup and leave the factory sway bars. They are awesome for street driving and perfectly balanced, while the factory shocks and springs may not be.
That unless you track your car quite a bit and stiffer SB options for track days start making sense (even though some track guys sometimes disconnect the swaybar end links and track their car without the sway bar on some specific tracks). So choose wisely.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
silvapain (01-29-2013)
 Old 01-26-2013, 01:19 PM   #231
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
I saw the thread title and thought it was (NSFW) bolt on tatas.
Nator is what it does.
The Following 4 Users Say Thank You to kritz For This Useful Post:
EdgeAutosport.com (01-26-2013), lilred (01-27-2013), silvapain (01-29-2013), Speed3 Wolf (01-29-2013)
 Old 01-28-2013, 02:14 PM   #232
IamJamen's Avatar
Posts: 789   (View Stats)
I just installed my AT internals and now I am thinking I should buy myself a shiny CP-E TMIC. It's now or never since I am supposed to be saving for the ridiculous engagement/wedding ring she just has to have. Can you help me out with a convincing deal on a TMIC?
The Following User Says Thank You to IamJamen For This Useful Post:
Jhornbrook (01-29-2013)
 Old 01-29-2013, 09:50 AM   #233
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Haha well I feel your pain my gf looks at that shit everyday and finds her perfect ring at least once a week. I decided to set up two funds. Car and ring. The car gets more because it doesn't talk back. Lol. But see what Tmic is the cheapest/best deal they all perform well and relatively equal.
Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC//
Jhornbrook is offline   Reply With Quote
 Old 01-29-2013, 11:13 AM   #234
I meant settings on the koni yellows. I have a rsb and really don't plan to get a front sway. And im not so lazy that I wont adjust a sway bar lol. It's removing the strut that I have reservations about. I thought they had more than three settings honestly. That being the case I'll go with the middle one, and set the front a tad softer for daily use, then even them up of I ever do hit a track.
Okay this has been wracking my brain today too... The bump stops (front and rear) I'm sure will have to be replaced. What I can't draw a conclusion on is if they should be cut at all. And if so, how much? The swift springs lower 1.2 and 1.1 for the rear iirc. Has anyone seen the how to for servicing your strut mounts rather than buying new ones?
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 01-29-2013, 01:46 PM   #235
IamJamen's Avatar
Exactly! And she just loves it when I tell her that I don't need a ring because I'm not going to wear it anyway.
Jhornbrook (01-31-2013)
 Old 01-29-2013, 02:25 PM   #236
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
I wouldn't cut the bump stops at all. And if you are the type like me and do not want to mess with settings, get Bilstein SP. The Swift lower the ride on the gen1 less than the gen2. Somewhere along the lines of .6F/1.0R if I remember correctly.
thatsmrgimp2u (02-01-2013)
 Old 02-01-2013, 01:43 AM   #237
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
SSP doesn't sell an oil return line kit that would fit a K04/BNR turbo right?
Just bigger Garret and Precision turbos?
 Old 02-01-2013, 08:26 AM   #238
Alexander's Avatar
Posts: 841   (View Stats)
Alexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the world
Groaned at 43 Times in 16 Posts
Hey, so I've been hearing that if you install a bov on our engines (instead of a bpv) that it will run like shit. Does anyone know why this would happen? That sounds really unusual to me
2011 Mazdaspeed 3
Cobb v3 AP | Autotech CDFP | JBR Sri | JBR Balance Shaft Delete | JBR Rear Sway Bar | JBR 88 duro RMM | M2 Testpipe | Corksport Tip | Corksport Short Shifter | Corksport SSP | Corksport Shifter Bushings | Cobb Counterweight | H&R Lowering Springs | Joseph Koni Shocks/Struts | SPC Rear Camber Arms
Alexander is offline   Reply With Quote
 Old 02-01-2013, 08:41 AM   #239
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Dude....search. It's been answered a million times, and there are solutions to make it work if you really need VTA for some reason.
 Old 02-01-2013, 08:42 AM   #240
There is tons of info on this around the site but I will help you out. In short the air that you would be sending into atmosphere is metered. Used to determine the amount of fuel going into the engine. So without recirculating the air you will get whackadoo trims and have rich conditions between shifts. If you must follow the rice path look into a "guardian Angel"
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
Bolt help iracer7 MazdaSpeed 3 - Engine, Transmission & Driveline 18 07-25-2009 11:26 AM
Fully bolt SS/SC vs MS3 Bigbody250 Street Racing Stories ( Bench Racing ) 12 06-22-2009 09:24 PM
Getting new intercooler bolt? iracer7 MazdaSpeed 3 - Engine, Transmission & Driveline 11 05-18-2009 04:28 PM
Page generated in 0.63236 seconds with 48 queries
