Like Tree8Likes
 Old 10-06-2014, 10:01 AM   #41
darkstar5440's Avatar
Posts: 477   (View Stats)
darkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the world
What you heard about act 6 puck is false, that clutch will last a long time as long as you know how to use it. A twin disk is really only needed if your shooting for anything over 400-450 ftlbs of torque. And longevity shouldn't really be of concern if you are at that level of power IMO
OMWTFYB
darkstar5440 is offline   Reply With Quote
The Following 4 Users Say Thank You to darkstar5440 For This Useful Post:
LumberJack (10-06-2014), Micha (01-14-2015), ms3blackmica (10-07-2014), WetzMS3 (10-06-2014)
 Old 10-06-2014, 12:26 PM   #42
YoursTruly's Avatar
Posts: 325   (View Stats)
That is good to hear. I am very gentle driving around 90% of the time, but I will do pull now and again. I have done 1 proper launch, 1 botched launch (<3k rpm), and a couple quick starts.
I am looking to do a light build and a slightly bigger turbo, but I would like to daily drive it if possible. This means I need to over build a couple things in order to make it last. Even under 400tq, the stock axles aren't going to cut it. The stock clutch definitely won't hold up, but the previous owner installed the 6-puck and I like it so far.
I am mainly looking at the twin disc for durability and longevity. I would rather not have the motor or trans out again for a couple years.
Time for more research and thought into whether or not it is a good idea.
2010 MS3 "Maiko" - Sold
 Old 10-06-2014, 02:22 PM   #43
LumberJack's Avatar
Groans: 57
Stock axles are a lot stronger than you think. I'm making 800/600+ and in stock axles.....
10.36@148 Fastest Gen 2
darkstar5440 (10-06-2014), YoursTruly (10-07-2014)
 Old 10-06-2014, 02:30 PM   #44
Like @LumberJack; said stock axles will hold up to alot of abuse
OMWTFYB
The Following 2 Users Say Thank You to darkstar5440 For This Useful Post:
LumberJack (10-06-2014), YoursTruly (10-07-2014)
 Old 10-06-2014, 04:16 PM   #45
Clutch mileage is totally dependent on the driver. It is hard to say how many miles you can get out of one but typically the twin disc will last you a good while without being as harsh as the six puck from ACT.
LumberJack (10-06-2014), ms3blackmica (10-07-2014), YoursTruly (10-07-2014)
 Old 10-07-2014, 12:31 PM   #46
YoursTruly's Avatar
My ms6 axles will not handle that.
Like LumberJack said stock axles will hold up to alot of abuse
The ms3 axles are usually all you need, but I am selling the ms3 and working on an ms6.
Harshness isn't that big of a deal, but I drive 15+k miles every year from commuting and changing a ms6 clutch every other year will get old quickly. This might be a good option for me.
 Old 10-07-2014, 04:19 PM   #47
I've seen local guys around here get 30k+ out of a 6 puck making 500whp+. Like said before its all about how you drive
OMWTFYB
The Following User Says Thank You to darkstar5440 For This Useful Post:
 Old 01-12-2015, 12:33 PM   #48
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
I just pulled my 6 puck off last night. 18k on it and it looks like it's about done!! Doh!! I wonder how much longer this will last for me. Gotta weigh my options now. We will see if I can fit this in my tight budget lol.
h.h.sk1nny is offline   Reply With Quote
The Following User Says Thank You to h.h.sk1nny For This Useful Post:
EdgeAutosport.com (01-12-2015)
 Old 01-12-2015, 12:46 PM   #49
LumberJack's Avatar
Groans: 57
I know you'll hate to hear this but, with the ms6 you'll want to look into the 850 with the new steel flywheel option. The guys running the aluminum were having a lot of issues. Specifically in the 6, once they switched to the steel option they were saying night and day difference.
EdgeAutosport.com (01-12-2015), Mauro_Penguin (01-12-2015)
 Old 01-12-2015, 04:41 PM   #50
They have a steel flywheel for the 725 now. We just gotta get it on our site...
725 Series Steel FW
 Old 02-02-2015, 07:22 PM   #51
derek13p's Avatar
Posts: 1,195   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
Damn it, why do you say I need the expensive one? And why steel over aluminum??
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
 Old 02-02-2015, 08:19 PM   #52
LumberJack's Avatar
Groans: 57
The ms6 is much heavier and the extremely light (compared to stock) flywheel doesn't have enough mass and inertia to slow the clutch down and it bogs. Anyone that's running a twin from cm in a 6 has switched or is switching to the steel option.
EdgeAutosport.com (02-04-2015)
 Old 02-02-2015, 08:57 PM   #53
derek13p's Avatar
Groans: 38
Yeah I can understand that.
Why the 8.5 vs the 7.25 though?
06 MS6 & 06 MS6
Daily driven
 Old 02-03-2015, 01:01 PM   #54
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
i had my ACT 6 puck pulled off at around 30k miles and it looked almost brand new. Replaced it with a new one since the puck is only around $100. The shop measured the old and new and said that the old one only wore about 1/100"
 Old 02-03-2015, 02:17 PM   #55
h.h.sk1nny's Avatar
LOLZ. Dang I'm jelly dude. Ended up just getting a new disk. In reality, there is not much disc material to start with, even less when you account for the rivets holding the pads on. I do a lot of stop and go driving as well as numerous days out at the 1320.
 Old 02-04-2015, 02:01 PM   #56
Thats pretty impressive! More proof that clutch wear is dependent on the driver.
 Old 02-19-2015, 02:57 PM   #57
Tax Sale applies here
 Old 02-19-2015, 03:03 PM   #58
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
TAX 2 doesn't work. Says it can't be applied.
2011 Mazdaspeed 3 [Sold]
 Old 02-19-2015, 07:09 PM   #59
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
Serious! After I buy another clutch! It never worked when I applied it to the order.
417whp 428tq 12.037@117.2mph
 Old 02-20-2015, 08:28 AM   #60
Which clutch did you buy?
 Old 02-20-2015, 08:55 AM   #61
Snyeed's Avatar
I got a great deal on Southbend stage 3 endurance from a private seller.
 Old 02-20-2015, 09:59 AM   #62
Oh I was just curious which clutch you tried to use the coupon code for and it didn't' work?
 Old 02-21-2015, 09:55 AM   #63
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
I was trying to get this clutch too, but the discount wasn't working for me either, I ended up just going with the southbend.
What are differences in tq rating between the two versions?
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 02-23-2015, 02:01 PM   #64
The tax codes should work with all the clutches except ACT. We'll get this taken care of ASAP.
ms6mil (02-23-2015)
 Old 02-23-2015, 02:15 PM   #65
ms6mil's Avatar
Groans: 307
Too late for me.... just paid for all my stuff including the Southbend Stg 3 and I'm sure Alan's tired of dealing with my questions and changes of mind on parts. Oh well....
PTE5862 - TBD
 Old 02-24-2015, 08:35 AM   #66
Its not a problem at all! The Southbend clutch hasn't shipped yet so its not too late to change it if you want the CM.
 Old 02-24-2015, 08:53 AM   #67
ms6mil's Avatar
Groans: 307
PM'd
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
EdgeAutosport.com (02-25-2015)
 Old 03-17-2015, 03:39 PM   #68
Tax sale applies here!
Clutch disc snapped - new CM clutch experience Absolut1l MazdaSpeed 6 - Engine, Transmission & Driveline 4 05-08-2013 05:07 AM
My Clutch Masters FX400 post mortem djuosnteisn MazdaSpeed 6 - Engine, Transmission & Driveline 190 08-13-2012 04:52 PM
How to swap a clutch disc Nator style (w/pics) rodrigo MazdaSpeed 3 - How-To's 31 05-02-2011 11:31 AM
Page generated in 0.47992 seconds with 30 queries
