| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
10Likes ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
(Thread Starter) | Not Ranked : 0 score As for pricing, the Gen 2 option will be exactly $0.00 more than the Gen 1. I know that is going to be a little tough for some of you, but it is more than worth to upgrade to the Gen 2 wheel. Please let me take a moment to explain why... <deep breath> Basically, you can expect the Gen 2 GTX's to operate more efficiently than the Gen 1. This means less boost to make more power and lower adiabatic heat. When you turn it up, Garrett says you can make up to 20% more power on the GTX Gen 2 than you can the GTX Gen 1. According to Garrett, this is all accomplished with better aerodynamics. These turbos will also feature a speed sensor port so you can keep an eye on your turbos ridiculously high revs/min. ![]() ![]() First pic is of the Gen 2 Compressor map, and it is followed by the Gen 1 compressor map. Both of these are of the 3076 variety. This should make for an extremely efficient/fun Turbo series, especially in the smaller varieties which can now out power their old counter parts without losing any spool time in the process... Another cool feature that some of you top mount turbo dreamers will appreciate is that the Gen 2 GTX turbos are available in a reverse configuration meaning that you don't have to do any weird bends or have any valve cover clearance issues when you try to do a top mount turbo setup with these turbos. ![]() ATP Bolt-on GTX2860R Gen 2 Turbo Kit - $1749 ![]() ATP Bolt-on GTX2867R Gen 2 Turbo Kit - $1749 ![]() ATP Bolt-on GTX3071R Gen 2 Turbo Kit - $1849 ![]() ATP Bolt-on GTX3076R Gen 2 Turbo Kit - $1849 ![]() ATP Bolt-on GTX3576R Gen 2 Turbo Kit - $2349
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 04-26-2017 at 10:11 AM. |
| The Following 8 Users Say Thank You to EdgeAutosport.com For This Useful Post: | JohnnyTightlips (04-05-2017), KiwiFlavor (04-05-2017), mituc (04-10-2017), rtabagaboy (04-06-2017), rymanmazda (04-06-2017), ThOrZwAr (04-05-2017), Tifosi42 (01-13-2018), Varomnia (04-05-2017) |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score Why must I see this...
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
![]() Join Date: Aug 2014 Location: Charleston, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
| Not Ranked : 0 score Hnnnnnggg... *quietly chants* I don't need this, I don't need this, I don't need this...
__________________ 2012 MS3 - FreekTuned - 93 tune: 332/310 - E25 tune: 377/356 CS Stage II SRI/TIP // CS Turbo // CS EBCS // CS 3.5 MAP // CS HPFP // CS BPV // CS OCC // SU TMIC // ATP Catless Long DP // JBR 88 Duro RMM // Damond PMM/TMM // CS Front Strut Bar // CS Rear Sway Bar // EBC Redstuff Pads // EBC Rotors // Cobb V3 AccessPort // NGK Plugs (step colder) |
![]() Join Date: Apr 2013 Location: Evanston, IL
Rep Power: 1329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 938
Groans: 57
| Not Ranked : 0 score Honestly, those two compressor graphs are extremely close. Plus, ain't no one running >3.5 p/r.
__________________ "you, sir, are the most knowledge slow guy I know. Stop fucking around and drive faster." -feejay "if anyone else acts a fool, we'll punish them to Roberts oil hut to discuss string alignment technique" -wetzel |
![]() Join Date: Nov 2015 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| Not Ranked : 0 score 20% for $0.00? You drive a hard bargain...........
__________________ AP v3 -- Autotech -- HTP 3.5" Intake -- CS BPV -- JBR SSP -- COBB Shift Knob -- H&R RSB -- Custom E-cutout -- CP-e TMIC -- JBR IC Piping -- JBR Coolant Bypass -- DM TIGs -- CP-e DP -- JBR EGR Delete -- AEM 30-3000 WMI -- Akebono Ceramics -- Centric High Carbon Rotors -- s204 Lip "The mind is like a parachute, it only works when open" |
![]() Join Date: Mar 2012 Location: Bend, Oregon
Rep Power: 670 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,489
Groans: 122
| Not Ranked : 0 score fuuuuuuu
__________________ 2006 BCM Mazdaspeed 6 GT w/navi SOLD Freektune: 400whp/387awtq Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18 -Autocross Setup- 17x8 +38, BF Goodrich R1 225/45/17 Other Rides: 2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013) 1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it. 1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father) 1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD) |
Groans: 57
| Not Ranked : 0 score Where does Garret say that?
(Thread Starter) | Not Ranked : 0 score Well, I'm not sure that they have it in literature anywhere. We work pretty closely with Revvolution and they tested the Gen 1 against the Gen 2 GTX on a built BRZ a few months ago. We actually got that info from Revvolution when he was dealing with them pre test. That car made 563 on the gen 1 then lifted a head on the gen 2 somewhere over 600 and is currently waiting on a motor to continue the test. So I guess I should amend that to "word on the street" since we haven't heard it directly from Garrett. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | zenit (04-07-2017) |
| Not Ranked : 0 score Will you add the price for uggradding from a GT/GTX gen1 to gen2 (No hotside)? 20% more for 0$ is only good for peoples looking to order one without already running an old model. Can you gives more infos about the test of Revvolution or a link to them. I'm curious to see what was done beside swapping turbo. (Sometimes a bunch of add-ons count for the upgrade power too)
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
| The Following 2 Users Say Thank You to xfeejayx For This Useful Post: | Mauro_Penguin (04-09-2017), mituc (04-10-2017) |
For the BRZ, this is the link to their blog on it. Revv BRZ There isn't anything on it yet about the Gen 2 vs Gen 1 because of the head lift after they started turning it up with the Gen 2. All that was changed between the Gen 1 and Gen 2 turbos was injectors. They were near the top of what the injectors could do on the Gen 1 and would run out of fuel on the Gen 2 so they preemptively upgraded. | |
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
Groans: 78
IMO, it's clearly not worth "upgrading" to this over the old one if you want more power, but it does seem like it may produce a wider power band because of the low end, which I always like.
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT | |
| Not Ranked : 0 score Going from a gen1 to gen2 or to unobtanium compressor wheels won't do shit if you keep that altar boy choking throat on the ATP turbine side.
__________________ |
| The Following User Says Thank You to Tomas For This Useful Post: | MD1032 (04-11-2017) |
But it will still be pretty beneficial for the smaller ones like the quicker spooling GTX28's which now have a power bump and still retain the quick spool. | |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
| Not Ranked : 0 score Not seeing it on your website. Link?
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks |
(Thread Starter) | Not Ranked : 0 score Waiting on pictures before we make them view-able. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | Cataphract_40 (04-11-2017) |
| Not Ranked : 0 score any updates ?
(Thread Starter) | Not Ranked : 0 score Here are the links to where you can purchase these turbos. Updated the OP as well... ATP Bolt-on GTX2860R Gen 2 Turbo Kit - $1749 ![]() ATP Bolt-on GTX2867R Gen 2 Turbo Kit - $1749 ![]() ATP Bolt-on GTX3071R Gen 2 Turbo Kit - $1849 ![]() ATP Bolt-on GTX3076R Gen 2 Turbo Kit - $1849 ![]() ATP Bolt-on GTX3576R Gen 2 Turbo Kit - $2349 ![]() |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | Cataphract_40 (04-26-2017) |
| Banned ![]() Join Date: May 2017
Rep Power: 0 ![]() Thanks: 0
| Neutral : -1 score i want to buy some mazadas's spare parts.for more information,please visit here. |
| Not Ranked : 0 score nice. |
Groans: 30
| Not Ranked : 0 score Edge, It looks like ATP has altered the construction of the coolant line they provide (as seen here). ![]() I especially like how they seem to be using higher quality silicone hose for the EGR connection. Compare and contrast to the gen1 coolant line as see here: Can you show us how this redesigned coolant line fits on the turbo? (Orientation, etc.) I was not a huge fan of how ATP jerry-rigged the coolant line on the gen1 GTX turbos.
![]() | | #24 | ![]() |
| Not Ranked : 0 score Just 1 year after gtx gen2 release, Garrett release another new improved turbo, the G series Will you have Mazdaspeed kits for them ? IT seem to have a 54mm turbine like a GT28 can the ATP GT28 hotside fit those new design ? https://www.turbobygarrett.com/turbo...series-g25-660
![]() | | #25 | ![]() |
| Not Ranked : 0 score fuck those like noice.
![]() | | #26 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score FINALLY AN O RING ON THE COMPRESSOR HOUSING but yeah, i just briefly looked over it, but they look really good. Last edited by aaronc7; 01-08-2018 at 09:19 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #27 | ![]() |
| Not Ranked : 0 score i read a reviews and my understanding (I may be wrong) The GTX gen1 and 2 was more about the compressor wheel than turbine wheel and now, that revision upgraded both.....?
![]() | | #28 | ![]() |
Groans: 370
| Not Ranked : 0 score Yeah about everything looks brand new |
![]() | | #29 | ![]() |
Groans: 111
| Not Ranked : 0 score Holey shet that compressor map...! That turbo is efficient past 65% almost everywhere! Even though the 25-660 wheel sizes match a 3067 it pushes more air than a 3071 gen2.
![]() | | #30 | ![]() |
If we just look at flow potential we are close to be able to compare these: Model............GT3582r = GTX3076r (Gen1) = GTX3071r (GenII) = G25-660 (G2567r) Turbine size....68mm T. .....60mm T. ................60mm T. ...................54mm T Comp. size.....82mm C. .....76mm C. ................71mm C. ...................67mm C Rated hp.......400-675hp...360-640hp ..............340-650hp.................350-660hp Release time......old.............200X.................Fal l.. 2016.....................Fall 2017
| The Following User Says Thank You to Jeff23spl For This Useful Post: | mituc (01-11-2018) |
![]() | | #31 | ![]() |
![]() Join Date: Sep 2015 Location: British Columbia, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score [MENTION @EdgeAutosport.com I just wanted to let you know that when you filter parts by car (in my case 2007 MSP6) these new Gen 2 turbos do not show up. You have to search by MSP3 in order for them to appear. Just thought I'd let you know. |
| Display Modes | |
| Tips on removing turbo mount bolt on speed 6 | Tuff Gong | Mazdaspeed3/6 General Discussion | 10 | 03-09-2017 04:43 PM |
| ATP Bolt On Turbos At EdgeAutosport | EdgeAutosport.com | EdgeAutosport.com | 60 | 09-17-2015 01:29 PM |
| ATP bolt on turbos + tunes | Lex | Stratified Automotive Controls | 3 | 11-01-2014 08:18 PM |
| V6 6-speed Accord vs bolt on MS3 | J30VTEC | Street Racing Stories ( Bench Racing ) | 13 | 10-16-2012 05:45 AM |
