  • 2 Post By EdgeAutosport.com
 Old 02-13-2015, 09:27 AM   #1
Default Install Guide How To: License Plate Frame
We've had absolutely no requests to do a how to on this so we decided we'd help the community and wake people up to the one mod they are missing out on the most. The highly demanded Edge Autosport license plate frame.
We hope you enjoy this install guide and find it helpful when installing yours. As always, ask us if you have any questions during install, we're here to help!
Step 1: Locate the license plate area you will be working with. Usually, this is in the rear of the vehicle.
Step 2: Using the appropriate screwdriver, remove either screw by inserting the flat end into the slot on head of the screw and rotating. Remember, righty tighty lefty loosey. Turn counterclockwise to remove the screw. A flathead or standard screwdriver is used in this particular install.
Step 3: With the help of a friend, hold the license plate in place so that it doesn't fall down while removing the second screw. You don't want to scuff up the bumper paint. Remove the second screw. This is done in the same fashion as the first screw.
Step 4: When reinstalling the license plate with the new frame. Make sure the orientation is correct. You don't want to draw any attention from the local authorities or have any girls laugh at you when they find out your frame is upside down.
Step 5: Again, using the help of a friend, hold the license plate and frame in place and insert one of the screws in the place it was removed from. Now, use a clockwise movement from left to right to tighten down the screw. Don't tighten all the way! Allow for movement on the other side to line up the holes.
Step 6: With the other side slightly loose, insert the second screw into the other side and tighten down, remember, clockwise. Now you can fully tighten the other side down.
The end result should look like this. If it doesn't, trace your steps back to where you lost all hope, you might be going back to when you fell on your head as a child if you are having a hard time with this.
Cheers!!
The EdgeAutosport Team
ThizSpeed3 and Mauro_Penguin like this.
The Following 23 Users Say Thank You to EdgeAutosport.com For This Useful Post:
Agent_Orange (02-17-2015), ArmanRus (02-17-2015), Bob-o (02-13-2015), Code Monkey (02-13-2015), CWP_MS3 (02-13-2015), cyclist20 (02-13-2015), Easter Bunny (02-17-2015), G Sp33dy (02-13-2015), g00s3y (02-17-2015), Ingle (02-14-2015), jack_hammer (02-14-2015), juxt3r (02-15-2015), kylejenson (02-13-2015), Mauro_Penguin (02-13-2015), mazdaspeedmyk (02-13-2015), Mr. T (02-16-2015), mr.speedy3 (02-13-2015), Rommel043 (02-17-2015), rymanmazda (02-14-2015), SofaKingAwesome (02-17-2015), swsmailman (02-16-2015), ThizSpeed3 (02-16-2015), trancehead (02-13-2015)
 Old 02-13-2015, 09:32 AM   #2
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
First.
Lol
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post:
EdgeAutosport.com (02-13-2015), mr.speedy3 (02-13-2015), SofaKingAwesome (02-17-2015)
 Old 02-13-2015, 10:22 AM   #3
cyclist20's Avatar
Posts: 636   (View Stats)
cyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the world
No carbon fiber option? WTF?!
Also, what are the torque specs on those screws? So many good How To's, so few torque specs.
2013 LSM Speed BNR S3v3
AP V3
Corksport: HPFP Internals, Injector Seals, bpv, battery box, intake manifold
Full Race: Exhaust Manifold, ceramic coated for lovliness
CNT:Catted DP
Treadstone TR8 with Cobb piping
CP-e: Stage II RMM
HTP:3" intake
Stratified: 3port, Guardian Angel
JBR RSB, Shifter Bushings, EGR Delete/Blockoff
Matt Damond:OCC, PMM, TMM
UR Axleback
Rice: Corksprt CF Hoodscoop & Spoiler // 12mm spacers // Bayson R lip // Bayson R GV grill // Okiefam powercoated VC, coil, and HPFP covers
Tuned by PURPLE DRANK
cyclist20 is offline   Reply With Quote
The Following 3 Users Say Thank You to cyclist20 For This Useful Post:
Code Monkey (02-13-2015), Easter Bunny (02-17-2015), EdgeAutosport.com (02-13-2015)
 Old 02-13-2015, 10:26 AM   #4
razerer's Avatar
Posts: 168   (View Stats)
razerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond repute
Groaned at 8 Times in 4 Posts
:O I finally figured out what I was doing wrong...
Cobb AP V3 // Cp-e HPFP // Cobb SRI TIP // Cobb DP // Cobb FMIC // Denso ITV22 // Cp-e Triton Cat-Back // Forge V2 BPV // JBR 88 Duro RMM
Cobb SoCal tuned
razerer is offline   Reply With Quote
The Following User Says Thank You to razerer For This Useful Post:
 Old 02-13-2015, 11:03 AM   #5
90 ftlbs I think. But it could be inlbs... Just know that our License plate frame warranty doesn't cover installer error.
Good luck!
cyclist20 (02-13-2015), Easter Bunny (02-17-2015), jack_hammer (02-14-2015), jdmage_mx5 (02-13-2015), Mauro_Penguin (02-13-2015)
 Old 02-13-2015, 11:10 AM   #6
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
But I haz speed3 and not ST
2018 Audi RS3
2007 Acura TSX 6MT
The Following 3 Users Say Thank You to tegxsi For This Useful Post:
Easter Bunny (02-17-2015), EdgeAutosport.com (02-13-2015), Vansquish (02-16-2015)
 Old 02-13-2015, 11:19 AM   #7
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
I totally was looking for a "how to" to accomplish this task. Thank you for this nugget of knowledge. Can someone please now tell me which oil is best for my car? What about which lowering kit I can use to stance my ride? Thanks.
In all honesty this was awesome and gave me a good chuckle.
 Old 02-14-2015, 12:31 AM   #8
macdiesel's Avatar
Posts: 825   (View Stats)
Thanks for clarifying the torque specs. I thought the bolts were torque to yield bolts and couldn't be re used.
EdgeAutosport.com (02-16-2015)
 Old 02-14-2015, 01:50 AM   #9
license2ill's Avatar
Posts: 313   (View Stats)
license2ill is infamous around these partslicense2ill is infamous around these parts
Groans: 30
Groaned at 132 Times in 57 Posts
Two days after I changed my last one, thieves at a trail head showed me how easy it was to remove it with a flat head, and steal the plate. They left the brand new chrome frame sitting on the bumper.
Get the tamper-proof screws!
license2ill is offline   Reply With Quote
 Old 02-14-2015, 04:54 AM   #10
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
silver screws on a black frame?! 2/10, would not bang
it's fun to do bad things
The Following 4 Users Say Thank You to jack_hammer For This Useful Post:
Easter Bunny (02-17-2015), EdgeAutosport.com (02-16-2015), rymanmazda (02-14-2015), swsmailman (02-16-2015)
 Old 02-16-2015, 01:41 PM   #11
That is what plastidip is for right?
 Old 02-16-2015, 01:44 PM   #12
Subbed for windshield wiper install thread.
Please tag me when created, I need help with those.
Much appreciated.
Chuthor (02-17-2015), Easter Bunny (02-17-2015), EdgeAutosport.com (02-17-2015)
 Old 02-16-2015, 02:11 PM   #13
Police - Grammarhead
Vansquish's Avatar
Will this how-to apply to Mazda vehicles too?
Agent_Orange (02-17-2015), WetzMS3 (02-18-2015)
 Old 02-16-2015, 02:36 PM   #14
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
I learned from experience that if you prove an officer wrong two times in a row, he will write you up for these plate frames covering 1/3 of your tabs. Would be nice if they were notched in the corners.
Cop: I pulled you over because you have no front license plate.
Me: Yes I do, go take another look. (Plate mounted on tow hook)
(Cop walks to front of car then turns around to come back to the window)
Cop: Your window tint on the back window's is to dark.
Me: Not according to the cop that pulled me over 3 month's ago for my front windows. I have a slip saying I'm legal with his badge number and phone number. You want it?
Cop: Yes, let me see it.
(Cop goes back to his car and comes back 5 minutes later)
Cop: Im not going to argue with another cop about tint. I don't like how your license plate frame covers your tabs though. (hands me "fix-it" ticket)
The Following 2 Users Say Thank You to speed_freak91 For This Useful Post:
 Old 02-16-2015, 02:37 PM   #15
tparker14's Avatar
Posts: 180   (View Stats)
tparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond repute
LOL most helpful! I wonder if these frames fit a Canadian license plate..
tparker14 is offline   Reply With Quote
The Following User Says Thank You to tparker14 For This Useful Post:
 Old 02-16-2015, 11:23 PM   #16
Mr. T's Avatar
Posts: 659   (View Stats)
Mr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the worldMr. T is the leader of the world
Sweet! Now if you guys could do an install guide with how to change my blinker fluid that would be perfect.
Alpine White/coral red 135i (N54)
24 psi, e70, catless downpipes, midpipes, axleback. FMIC and piping, synapse bov. G5 ISO board, e85 backend flash, stage 1 lpfp, turbo inlets, Federal 595 RSR-R tires.
Mr. T is offline   Reply With Quote
The Following User Says Thank You to Mr. T For This Useful Post:
 Old 02-17-2015, 09:23 AM   #17
Yes but you have to look up the conversion chart online.
Be glad the plate frame covered the plate some cause you were getting a ticket that day mp matter what, and the next available option to the cop was your "busted tail light"...
They fit but could throw off the conversion from mph to kph...
speed_freak91 (02-17-2015), tparker14 (02-17-2015)
 Old 02-17-2015, 01:21 PM   #18
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
How much hp does this add? Do I need to tune for it?
 Old 02-17-2015, 01:41 PM   #19
sporkbomb's Avatar
Posts: 295   (View Stats)
sporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the world
I'm mainly concerned about the weight of this mod. Will it throw off the balance? I already have my car tuned for my wife's big titties and don't want to jeopardize that in any way, whatsoever.
2007 MS3 GT
Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks
2006 MS6 GT (ZZB Rebirth)
Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts
1990 Miata
I like it raw
sporkbomb is offline   Reply With Quote
The Following 3 Users Say Thank You to sporkbomb For This Useful Post:
Easter Bunny (02-18-2015), EdgeAutosport.com (02-17-2015), WetzMS3 (02-18-2015)
 Old 02-17-2015, 05:00 PM   #20
Groans: 549
Originally Posted by sporkbomb View Post
my wife's big titties .
Pics or it didn't happen
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
Easter Bunny (02-18-2015), WetzMS3 (02-18-2015)
 Old 02-17-2015, 06:10 PM   #21
This is the blinker fluid I use. Haven't done a write up though.
EdgeAutosport.com (02-19-2015)
 Old 02-17-2015, 06:41 PM   #22
08cosmic3's Avatar
Posts: 2,920   (View Stats)
I used a dremmel tool and notched out a section to fully expose my sticker. Will doing this result in an imbalance destroying the integrity of the frame? I don't want my plate falling off and cause a pile up behind me.
 Old 02-18-2015, 12:35 AM   #23
razerer's Avatar
Why you guys no use loctite? I thought it was a must...
Cobb SoCal tuned
 Old 02-18-2015, 07:13 AM   #24
Typical ST owner.
JBR License Plate Frame Poll JBR JAMES BARONE RACING 154 06-05-2013 06:28 PM
JBR License Plate Frame Development Thread JBR JAMES BARONE RACING 187 03-26-2013 09:59 AM
Page generated in 0.47832 seconds with 37 queries
