Like Tree18Likes
  • 5 Post By EdgeAutosport.com
  • 1 Post By EdgeAutosport.com
  • 1 Post By jdmage_mx5
  • 3 Post By LumberJack
  • 4 Post By SilverDemon
  • 1 Post By LumberJack
  • 1 Post By NCspecV81
 Old 02-26-2014, 11:01 AM   #1
Default JMF Intake Manifolds at EdgeAutosport
Well a lot of you have been asking us about the JMF Intake Manifold and I am here to tell you that it is now available through EdgeAutosport.
Each JMF manifold is hand made and TIG welded from high quality 6061 T6 aluminum. The flanges are all CNC machined and surfaced for precise fitment and a leak free seal. Radiused inlets are CNC machined into each plenum bottom to improve airflow by 10-15%. Every effort was made to keep this manifold as close to a stock replacement as possible. Installation for the most part is bolt on but some modifications to your IC piping will be required. This manifold will NOT work with the stock top mount intercooler, you will need to have a front mount intercooler installed.
Included with each manifold is all new stainless steel hardware, brass vacuum fittings, fittings to relocate your fuel pressure sensor, vacuum hose, and a check valve for the EVAP line preventing you from having to destroy the OEM line. Also, options are available for a "BRUSHED/UNPOLISHED" finish or for an extra $100, a mirror like "POLISHED" finish (the TB elbow and inlet do not get polished, they are not visible once installed). Additional throttle body flanges. A mount for the OEM MAP sensor. NOS bungs which are pre-drilled with a centering hole but not tapped or drilled through the runners, that is left to the customer due to the many different nozzles on the market. Lastly, 1/8" NPT bungs are available for METH/Water injection which are drilled through the runners completely. You can also choose to add Port Injection for cars with auxiliary fuel requirements.
Click below to read more about these manifolds on our website or to purchase.
JMF Intake Manifold V2 Port Injection MS3/MS6 - $979.07
JMF Intake Manifold V1 MS3/MS6 - $781.02
Let me know if you have any questions!
The Following 24 Users Say Thank You to EdgeAutosport.com For This Useful Post:
802MS3 (02-26-2014), alaskazero (04-23-2014), atvfreek (02-26-2014), cocoanton (05-16-2014), darkstar5440 (02-26-2014), Domino81 (02-26-2014), Downmented (02-26-2014), Easter Bunny (02-26-2014), GunGuru727 (03-13-2014), Hammology (03-25-2014), kbz0129 (03-05-2014), lilred (02-26-2014), LumberJack (02-26-2014), Micha (02-26-2014), mtnrunner (03-03-2014), mxlplx71 (02-26-2014), NCspecV81 (02-26-2014), RobT2009 (05-21-2014), sleeperstang1994 (02-26-2014), SpeedRebirth (02-26-2014), thehead (02-26-2014), trancehead (02-26-2014), WetzMS3 (02-26-2014), YABBAMZR (02-26-2014)
 Old 02-26-2014, 11:03 AM   #2
LumberJack's Avatar
Groans: 57
This is huge, can't wait to see all the one stop shopping here.
I can't thank Jp, and every @EdgeAutosport.com; for making this happen. You guys rock
10.36@148 Fastest Gen 2
The Following 6 Users Say Thank You to LumberJack For This Useful Post:
atvfreek (02-26-2014), EdgeAutosport.com (02-26-2014), mWindu (02-27-2014), Realgib3 (03-12-2014), Sterling (02-26-2014), trancehead (02-26-2014)
 Old 02-26-2014, 11:12 AM   #3
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
those welds give me wood
08 cwp ms3
 Old 02-26-2014, 12:20 PM   #4
VulgarKyle's Avatar
Posts: 1,137   (View Stats)
VulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the world
PORN!!! you guys rock
2011 VELOCITY RED MAZDASPEED3 W/TECH
RICHTUNED
VulgarKyle is offline   Reply With Quote
The Following User Says Thank You to VulgarKyle For This Useful Post:
 Old 02-26-2014, 01:09 PM   #5
Outlaw4shrt's Avatar
Posts: 751   (View Stats)
Outlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the world
Nice! That's a little cheaper too than what I paid for mine originally. Good job guys!
2006 TGM MS6
Cobb AP w/ SELFtune // Split Second AIC1-V4H // Stratified Guardian Angel // Stratified Boost Dial // ATP GTX3071r IWG // Devils Own Stage 1 WMI // JMF v2 Intake Manifold // 4 x Siemens DEKA IV 60 lph Injectors // Outlaw4shrt In-Tank Fuel Pump Kit w/ 255 lph pump // CP-E CDFP // CP-E SAFEseals // Clutchmasters 350 & flywheel // CX Racing FMIC // HTP 3.5" Intake // 3.5 Bar MAP // Cobb EBCS // Forge BPV v1 // XS Power Exhaust Manifold // M2 Downpipe w/ Highflow Cat // Corksport 80mm CBE // Blackworks Racing VTA OCC // NGK +1's // JBR EGR delete // Speedy 17x7.5 Lite Fin's w/ Hankook Ventus V2 225/50/R17 // TooLateTuning Springs // Bilstein B6 HD Shocks // Whiteline RSB // SPC Adjustable Ball Joints // Airlift 1000 "Drag Bags" // JBR 80 duro RMM // JBR 80 duro TMM // JBR 80 duro PMM // CP-E RDM // Turbine Tech FDM // OEM Spin-On Oil Filter Conversion // Prosport Oil Pressure and Oil Temp Gauge with Oil Filter Adapter Plate, Boost and EGT Gauges // AEM UEGO Wideband O2 & Fuel Pressure Gauges // Block8head MS6 dual 52mm vent pod // Lotek triple 52mm gauge pod // Prosport EVO Single Gauge Pod // Cobb Knob // Corksport LED Kit // Corksport LED Fogs // LED Tails // Audi LED DRL's
2008 MazdaSpeed 3 - R.I.P. 1/3/13
- from ENM 2014
well actually, if you count the number of holes you'll see we have just enough
Outlaw4shrt is offline   Reply With Quote
 Old 02-26-2014, 01:10 PM   #6
fundream's Avatar
Posts: 48   (View Stats)
fundream is a splendid one to beholdfundream is a splendid one to beholdfundream is a splendid one to beholdfundream is a splendid one to beholdfundream is a splendid one to beholdfundream is a splendid one to beholdfundream is a splendid one to beholdfundream is a splendid one to behold
Groaned at 4 Times in 1 Post
Great news !!!
fundream is offline   Reply With Quote
 Old 02-26-2014, 01:42 PM   #7
It includes shipping to the continental US as well.
LumberJack likes this.
LumberJack (02-26-2014), Outlaw4shrt (02-26-2014), Sterling (02-26-2014)
 Old 02-26-2014, 05:33 PM   #8
alextheguineapig's Avatar
Posts: 827   (View Stats)
Will this have any issues with an FMIC setup the runs over the valve cover and over the dip stick/manifold runners? Or does it require a corksport type setup that runs down near the intake?
Current
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
Damond Motorsports: RMM
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 02-26-2014, 06:17 PM   #9
LumberJack's Avatar
Groans: 57
Typically intercooler piping that runs over the top has to be modified. Easiest things IMO is to route the IC piping down under the car like a raceroots hot side does.
The Following 3 Users Say Thank You to LumberJack For This Useful Post:
alextheguineapig (02-26-2014), EdgeAutosport.com (02-27-2014), Realgib3 (03-12-2014)
 Old 02-26-2014, 07:22 PM   #10
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Really great news! Some day i will buy that mani =)
Just a heads up @EdgeAutosport.com;, when options are selected that adds cost (meth/nos/polished) it doesn't actually add anything on the price. Price in Cart with all options selected is same as none selected. Same on both mani versions
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 02-27-2014, 07:39 AM   #11
Thanks for bringing that to our attention! I'll get that fixed asap!
LumberJack (02-28-2014), SpeedRebirth (02-27-2014)
 Old 03-12-2014, 04:12 PM   #12
We have a non polished/non port injection manifold in stock. Any body want to upgrade the sexiness of their engine bay?
jdmage_mx5 (03-12-2014), LumberJack (03-12-2014)
 Old 03-12-2014, 04:16 PM   #13
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Hopefully I'll be adding one of these to my mod list soon. I will definitely hit up Edge when the time comes.
EdgeAutosport.com (03-12-2014)
 Old 03-12-2014, 04:18 PM   #14
LumberJack's Avatar
Groans: 57
This is sexiness. Get your jmf today
Thanks again to Jp and everyone @EdgeAutosport.com;
The Following 5 Users Say Thank You to LumberJack For This Useful Post:
alaskazero (04-23-2014), EdgeAutosport.com (03-12-2014), jdmage_mx5 (03-12-2014), Realgib3 (03-12-2014), xTRELLx (03-13-2014)
 Old 03-25-2014, 11:35 AM   #15
If you are hitting the limits of the factory fuel injectors, maybe its time to pick up a JMF manifold with port injection.
jdmage_mx5 (03-25-2014), LumberJack (03-25-2014), Realgib3 (03-25-2014)
 Old 04-23-2014, 10:50 AM   #16
We have been keeping JMF busy making these manifolds. I'm glad you guys are putting them to good use.
If you haven't taken a little time out of your day to thank @SilverDemon; for getting these to the market, you should. Without him these would not exist and we as a platform would probably still be stuck in the 500whp range...
Thanks Scott!!
SilverDemon likes this.
The Following 8 Users Say Thank You to EdgeAutosport.com For This Useful Post:
802MS3 (04-23-2014), alaskazero (04-23-2014), Easter Bunny (05-16-2014), ItsNox (04-23-2014), LumberJack (04-23-2014), MZRSPEED (04-23-2014), SilverDemon (04-23-2014), SpeedRebirth (04-23-2014)
 Old 04-23-2014, 11:14 AM   #17
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Thanks Scott!!
You guys (the community, and Edge) are most welcomed! I enjoyed working with Jim (JMFabrications). He runs a great shop, and you will not find some one so devoted to making quality parts as Jim. I am also happy that Edge and Jim were able to do business together.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 7 Users Say Thank You to SilverDemon For This Useful Post:
802MS3 (04-23-2014), DevinS (10-13-2016), Easter Bunny (05-16-2014), EdgeAutosport.com (04-23-2014), LumberJack (04-23-2014), SpeedRebirth (04-23-2014), WetzMS3 (04-23-2014)
 Old 04-23-2014, 11:17 AM   #18
alaskazero's Avatar
Posts: 195   (View Stats)
alaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond reputealaskazero has a reputation beyond repute
Groans: 34
Groaned at 55 Times in 18 Posts
Well ill be purchasing this item very soon
alaskazero is offline   Reply With Quote
The Following User Says Thank You to alaskazero For This Useful Post:
 Old 04-23-2014, 12:10 PM   #19
Matrix311's Avatar
Posts: 2,133   (View Stats)
Yep i'll be purchasing one of these sometime this year.
 Old 05-16-2014, 11:07 AM   #20
We have one non polished/non PI manifold left in stock. Should be getting more soon though.
ItsNox (05-19-2014), LumberJack (05-16-2014)
 Old 05-16-2014, 02:15 PM   #21
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
will these fit my regular 3?
The Following User Says Thank You to dooderek For This Useful Post:
 Old 05-16-2014, 02:23 PM   #22
Yes, with the optional flux capacitor.
Easter Bunny (05-16-2014), ItsNox (05-19-2014)
 Old 05-16-2014, 03:25 PM   #23
cocoanton's Avatar
Posts: 168   (View Stats)
cocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the worldcocoanton is the leader of the world
I hate you Edge.... You are too good not to buy shit from. You will be my ruin
cocoanton is offline   Reply With Quote
The Following 2 Users Say Thank You to cocoanton For This Useful Post:
EdgeAutosport.com (05-20-2014), SpeedRebirth (05-17-2014)
 Old 05-18-2014, 03:07 PM   #24
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Any chance of getting a v1 with the v2 flange? Don't need PI but that single opening flange is pure want.
2013 CWP and Stock
 Old 05-20-2014, 07:34 AM   #25
But seriously, I'll check and see what we can do. It will definitely be a special order if JMF will do it. I'll let you know.
NCspecV81 likes this.
cocoanton (05-21-2014), NCspecV81 (05-20-2014)
 Old 05-20-2014, 10:51 AM   #26
shadesofgray19's Avatar
Posts: 794   (View Stats)
V1 and V2 both have the single opening flange. The only difference is the holes for PI.
 Old 05-20-2014, 11:26 AM   #27
Are you talking about the intake manifold flange? Because we have a non PI intake manifold here with the split ports in the intake manifold runners. But maybe we are not talking about the same thing?
 Old 05-20-2014, 11:31 AM   #28
LumberJack's Avatar
Groans: 57
The flanges on the v1 and v2 are different. The non PI v1 has a split runner and the PI v2 has a single runner flange.
EdgeAutosport.com (05-21-2014), NCspecV81 (05-21-2014)
 Old 05-21-2014, 11:34 AM   #29
NCspecV81's Avatar
Yes I'm not going PI but I need the runners as 1. gonna be pushing a lot of shit through those ports. I need every, last, infinitesimal fraction of port real estate as possible.
2013 CWP and Stock
 Old 05-21-2014, 11:35 AM   #30
LumberJack's Avatar
Groans: 57
You realize I made almost 800whp on a divided runner head right? That divider in the intake manifold flange won't hurt you
EdgeAutosport.com likes this.
 Old 05-21-2014, 11:40 AM   #31
NCspecV81's Avatar
In deed I do. I'll be running direct port nitrous and don't want to have a worry about if anything is being deflected by the divided runner.
2013 CWP and Stock
 Old 05-21-2014, 11:42 AM   #32
LumberJack's Avatar
Groans: 57
True and fair enough gotta think though I'm spraying 6000cc worth of fuel at a divided runner head and it's not effecting anything. Just my thoughts, but hey nitrous is another level.
 Old 07-16-2016, 08:06 PM   #33
dgk910's Avatar
Posts: 12   (View Stats)
dgk910 will become famous soon enough
can anyone say wether or not there is a difference in this manifold between models? it lists a choice between the speed 6 and speed 3.
dgk910 is offline   Reply With Quote
 Old 07-16-2016, 08:40 PM   #34
Lol 2 year thread bump.
sent from my Nexus 6P
 Old 07-16-2016, 08:43 PM   #35
08speed's Avatar
Posts: 147   (View Stats)
08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of08speed has much to be proud of
If it lists separately for the 3/6 i would assume so? I would just call them and ask.
08speed is offline   Reply With Quote
 Old 07-16-2016, 11:55 PM   #36
shaneski's Avatar
Posts: 505   (View Stats)
From reading i think there is a slight difference for the 6 so it clears the power steering or some shit.
The Following User Says Thank You to shaneski For This Useful Post:
dgk910 (07-18-2016)
intake manifolds... bombdotcom MazdaSpeed 3/6 - Turbo Induction 31 01-30-2009 12:26 PM
Intake manifolds?? steedspeed MazdaSpeed 3/6 - Turbo Induction 74 10-25-2008 08:00 AM
Page generated in 0.56467 seconds with 40 queries
