 Old 02-27-2012, 06:39 PM   #1
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Default KW V3 Rear Spring Rates
JP could you or Eric please see if you can find the KW V3 rear spring rate for me. I searched high and low on the net and have only found they are progressive. I know once the springs are static loaded they are linear and I'd like to know what they linear rate is.
Once my build is done I guess you know what I'm getting next . . . .
-Paul
Fueled by the haters.
Celestspeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post:
EdgeAutosport.com (03-09-2012), JP@edgeautosport.com (03-09-2012)
 Old 03-07-2012, 12:35 PM   #2
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
Well this thread sure did sneak right past us didn't it? 400lb on the front but they don't release progressive rates because it has to do with where the ride height is set at.
 Old 03-09-2012, 11:20 AM   #3
Thanks JP,
I think, I'm going to use the rear springs from the Teins in the rear and the rest will be the V3 setup. This way I have linear 400lbs in the front and rear without going to custom.
 Old 03-09-2012, 11:31 AM   #4
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
I don't buy that the rear rate depends on the ride height, because you're not really preloading anything when you change the height in the rear.
For all intents and purposes, when the weight of the car is resting on those rear springs, they are linear.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Celestspeed3 (03-09-2012)
 Old 03-09-2012, 10:41 PM   #5
Thank you, but everyone I ask gives me the same story. Its progressive, well I know that but once the chassis is settled the springs are linear and I want to know that rate.
JP@edgeautosport.com (03-09-2012), Nliiitend1 (03-10-2012)
 Old 03-09-2012, 10:54 PM   #6
I'm going to pry KW on Monday and find this out for you. They can't make a spring and not know the technical info for it.
The Following User Says Thank You to JP@edgeautosport.com For This Useful Post:
 Old 03-10-2012, 07:59 AM   #7
Nliiitend1's Avatar
Oh I understand completely. I'm just pointing out that the statement that claims that the rate depends on ride height in this application is patently wrong.
2008 MS3 GT
2016 MX-5 Club
 Old 03-09-2012, 10:56 PM   #8
Either way you are still suppling the coils
The Following User Says Thank You to Celestspeed3 For This Useful Post:
EdgeAutosport.com (03-10-2012)
Ms6 does anyone know stock spring rates and aftermarket rates? darkcherry MazdaSpeed 3/6 - Suspension & Brakes 7 12-16-2011 03:31 PM
Spring Rates tavio025 2010 MS3 - Suspension & Brakes 1 10-04-2011 09:32 PM
Gen1 vs Gen2 Stock Spring Rates Boother MazdaSpeed 3/6 - Suspension & Brakes 7 02-18-2011 09:26 PM
Coilover Spring Rates? JMEngineer MazdaSpeed 3/6 - Suspension & Brakes 0 06-02-2009 11:25 PM
Page generated in 0.29243 seconds with 22 queries
