 Old 01-16-2015, 10:29 AM   #1
Default Make Meth Nozzle Mounting Easy! JMF TB Spacer!
JMF Throttle Body Spacer - $69.06
If you are opting to run Water/Meth Injection, this spacer makes placing your meth nozzles a breeze. With the JMF Throttle Body Spacer you can mount up to 4 nozzles directly after the throttle body. This will allow you to run more smaller nozzles for better atomization without having to deal with tapping your cold pipe or manifold.
The JMF TB Spacer is machined from 6061 Aluminum and features four 1/8th" NPT Threaded ports, one on each side. It comes with plugs for the ports not being used as well as four longer stainless bolts to compensate for spacers thickness.
If you are planning to run water/meth injection, you should look into picking up this spacer.
Click the picture to check this out on our site and read more about it!
The Following 7 Users Say Thank You to EdgeAutosport.com For This Useful Post:
juxt3r (01-17-2015), Mauro_Penguin (01-17-2015), MD1032 (01-17-2015), Micha (01-16-2015), Poohster (01-17-2015), SpeedRebirth (01-16-2015), trancehead (01-16-2015)
 Old 01-17-2015, 10:40 AM   #2
spl
spl's Avatar
Posts: 185   (View Stats)
spl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the worldspl is the leader of the world
Does this require any modifications to existing hardware for install?
2010 BM - FREEKTUNED - BNRS3
spl is offline   Reply With Quote
 Old 01-17-2015, 11:43 AM   #3
It is going to move the throttle body a little so you may have to trim a coupler if you have a TMIC, but with as little as it moves, I doubt that will be necessary.
Mauro_Penguin (01-18-2015), spl (01-17-2015)
Snow Nozzle w/ DO Mounting Adapter fywdyl 2010 MS3 - Fuel, Nitrous & Water Injection 10 04-13-2013 03:07 PM
new nozzle mounting adapter? madvillain MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 07-06-2009 12:02 AM
Page generated in 0.24484 seconds with 21 queries
