Like Tree21Likes
 Old 12-17-2014, 03:49 AM   #1
shaneski's Avatar
Posts: 505   (View Stats)
Default Manley Pistons, arrived with not much fanfare
Manley Platinum Series Pistons Mazdaspeed 3 2007-2013 / Mazdaspeed 6 2006-2007
Any info on what they are like with oil squirter clearance etc, can't find any info if these have been tested on our platform..Seen Bryce has a set ready for war on his FB. Interested between any advantages with these v CPE stage 2 and Speed performance custom pistons.
The Following 2 Users Say Thank You to shaneski For This Useful Post:
Frottage75 (11-22-2015), LumberJack (12-18-2014)
 Old 12-17-2014, 09:19 AM   #2
We were waiting till they have been ran for a bit on a few cars before we start slinging them. Don't want to get a ton out there and find out that there is an oil squirter issue (though I'm pretty sure there won't be).
As far as comparisons are concerned, they have the Gen 2 style dish like the cp-e pistons and they are about $100 less expensive.
I believe these will be an excellent option for anyone looking to build their motor for mild power or big power.
atvfreek (12-19-2014), Domino81 (12-18-2014), Mauro_Penguin (12-18-2014), mxlplx71 (12-18-2014), shaneski (12-18-2014)
 Old 12-17-2014, 10:16 AM   #3
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Interesting. I think these are promising. Manley makes awesome stuff. I had manley pistons in my mustang build and not a single problem. Looks like these will put a dent into wiseco piston sales if they work out well.
Can anyone post better pictures of the piston skirts and maybe measure the distance from the top of the piston to the bottom of the skirt at the middle and edge?
I have a set of cp-e stage 2 pistons I can measure to compare for oil squirter clearance.
If I end up needing to go oversized I think I would sell the cp-e pistons and give these a shot.
Soon to come.
WHO KNOWS? A.D.D. FTW!
The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post:
Mauro_Penguin (12-18-2014), shaneski (12-18-2014)
 Old 12-18-2014, 02:40 AM   #4
shaneski's Avatar
@Lumberjack seen your paws on these via facebook can you shed any info. @ms3blackmica @atvfreek..tagging these guys cause if shit is advancing in the DISI platform they are more than likely to have some knowledge of wizardry with parts.
 Old 12-18-2014, 05:24 AM   #5
Drive By Fire's Avatar
Posts: 448   (View Stats)
Drive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the worldDrive By Fire is the leader of the world
Originally Posted by shaneski;2776386 [MENTION=28934
LumberJack seen your paws on these via facebook can you shed any info. @ms3blackmica @atvfreek..tagging these guys cause if shit is advancing in the DISI platform they are more than likely to have some knowledge of wizardry with parts.
@LumberJack;
@ms3blackmica;
@atvfreek;
NJ NATOR
Drive By Fire is offline   Reply With Quote
The Following 2 Users Say Thank You to Drive By Fire For This Useful Post:
SarcasticOne (12-18-2014), shaneski (12-22-2014)
 Old 12-18-2014, 08:30 AM   #6
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Any idea if we can get these is sizes larger than 88mm?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 12-18-2014, 08:44 AM   #7
88mm and 87.5mm are all that is available at this time.
Mauro_Penguin (12-19-2014)
 Old 12-18-2014, 09:22 AM   #8
acemanz's Avatar
Posts: 224   (View Stats)
acemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the world
Well im not sure if i trust these... i mean its just been confirmed that Edge has been invaded with skynet! LOL!
I have an engine build coming up in a little under a year so if these check out i will most likely be buying them.
EdgeAutosport.com likes this.
acemanz is offline   Reply With Quote
The Following User Says Thank You to acemanz For This Useful Post:
EdgeAutosport.com (12-18-2014)
 Old 12-18-2014, 10:24 AM   #9
Hahaha!! We were just talking about this in the office.
 Old 12-18-2014, 10:30 AM   #10
acemanz's Avatar
It's become Self Aware ! ruuuuun ! !
someone get a set of these and stick em in to see if they fit !... or maybe send me some and i will do it
 Old 12-18-2014, 10:31 AM   #11
LumberJack's Avatar
Groans: 57
I spent some good time on the phone with Manley direct before ordering these Pistons as well as time talking with Justin.
These are Manley's highest model import Pistons. The lightweight platinum series. Manley rates them in stock fashion to about 800 crank before needing to upgrade the wrist pins. Unfortunately Manley doesn't sell those direct because of our awkward stock size wrist pin, they were king enough to inform me of a company they trust and recommended for upgraded pins. With the material and wall diameter I chose Manley confidently said those Pistons will take a 1000whp. The side skirts are very very beefy which is what you want. They use a full steel ring set which is ideal for big power. @atvfreek; might be able to chime in a little more as I know he's got a set as well for a build.
Pic below is my upgraded H13 Tool Steel .260" wall wrist pin vs the .150" wall chromoly stock pin.
ImageUploadedByTapatalk1418923857.217470.jpgImageUploadedByTapatalk1418923998.832889.jpgImageUploadedByTapatalk1418924009.839111.jpgImageUploadedByTapatalk1418924020.427824.jpgImageUploadedByTapatalk1418924032.183088.jpg
Mauro_Penguin likes this.
10.36@148 Fastest Gen 2
The Following 12 Users Say Thank You to LumberJack For This Useful Post:
atvfreek (12-19-2014), Code Monkey (12-18-2014), DingoDave (02-06-2015), EdgeAutosport.com (12-18-2014), JgamB (12-18-2014), Lakespeed6 (12-18-2014), Mauro_Penguin (12-19-2014), mazdafreak (12-19-2014), shaneski (12-22-2014), taf0422 (12-18-2014), The Nut (02-07-2015), ttgeoff (03-10-2015)
 Old 12-18-2014, 10:40 AM   #12
acemanz's Avatar
Attachment 185234Attachment 185235Attachment 185236Attachment 185237Attachment 185238
i assume that means that anyone who isnt going for 800HP will be fine with the wrist pins they come with, but i think we are all still wanting to see if these resolve the silly oil squirter clearance issue
 Old 12-18-2014, 01:29 PM   #13
Ahh, oil squirter clearance!
Soon to come.
 Old 12-18-2014, 01:36 PM   #14
acemanz's Avatar
you dont wanna bend your squirter man, you wont shoot straight if you do... Giggity
 Old 12-18-2014, 01:44 PM   #15
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
Justin should have a set in my block in ... 2 weeks
taf0422, The Nut and smr87 like this.
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following 4 Users Say Thank You to Lakespeed6 For This Useful Post:
JgamB (12-18-2014), smr87 (12-19-2014), taf0422 (12-20-2014), Tokay444 (12-18-2014)
 Old 12-18-2014, 05:29 PM   #16
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Interesting there isn't any exhaust valve releifs.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 12-18-2014, 05:43 PM   #17
acemanz's Avatar
There don't need to be any unless you have after market cams, or so I have read
 Old 12-18-2014, 05:58 PM   #18
JgamB's Avatar
Posts: 2,566   (View Stats)
1-2-1 will fix the exhaust valve cutouts.
The Following 4 Users Say Thank You to JgamB For This Useful Post:
atvfreek (12-19-2014), EdgeAutosport.com (12-22-2014), Mauro_Penguin (12-19-2014), Tokay444 (12-18-2014)
 Old 12-18-2014, 10:37 PM   #19
LumberJack's Avatar
Groans: 57
That is correct. Our stock cams actually don't require valve relief pockets on the exhaust side. Even some mild after market cams like the CS spec cams don't require valve relief pockets.
atvfreek (12-19-2014), shaneski (12-22-2014)
 Old 12-19-2014, 01:24 PM   #20
atvfreek's Avatar
Posts: 7,787   (View Stats)
I normally use cp-e pistons in all the builds I do, as I have had excellent success with them. However they have been on back order forever so I couldn't wait any longer. After talking with Alan at edge he talked about these and I'm willing to give them a shot. These are similar to the cp- and pu pistons, have oil squirter cutouts (I will confirm they clear after xmas) and they have long skirts which will help reduce piston slap heard on cold start. I have two motors going together as we speak with these, and then they will also go into Bryce's motor.
Standard wiseco's don't either. No issues unless of course you over rev to the moon and float some valves
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Last edited by atvfreek; 12-19-2014 at 01:24 PM. Reason: MSF Database - Automerged Doublepost
The Following 11 Users Say Thank You to atvfreek For This Useful Post:
802MS3 (12-19-2014), 865ms3 (12-19-2014), Code Monkey (12-19-2014), EdgeAutosport.com (12-22-2014), JgamB (12-19-2014), Lakespeed6 (12-19-2014), LumberJack (12-19-2014), Mauro_Penguin (12-19-2014), shaneski (12-22-2014), SpeedRebirth (12-19-2014), taf0422 (12-20-2014)
 Old 12-19-2014, 01:53 PM   #21
acemanz's Avatar
Sweet, hope they work out so i can stick them in my gen1 MS6 that im building this time next year.
 Old 12-19-2014, 06:15 PM   #22
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Do they also make them in 40 over?
2013 CWP and Stock
 Old 12-19-2014, 06:22 PM   #23
Tokay444's Avatar
Groans: 793
Demodded.
The Seals
EdgeAutosport.com (12-22-2014), NCspecV81 (12-19-2014)
 Old 12-19-2014, 09:58 PM   #24
LatinKraze's Avatar
Posts: 804   (View Stats)
@VegasChef
2016 CX-5 GT AWD
 Old 12-20-2014, 06:32 AM   #25
Micha's Avatar
Posts: 3,436   (View Stats)
I might snag a set too for the spare motor I am building. LOL
I am slow again.
I modded it a little.
The Following 2 Users Say Thank You to Micha For This Useful Post:
atvfreek (12-20-2014), EdgeAutosport.com (12-22-2014)
 Old 12-20-2014, 06:42 AM   #26
atvfreek's Avatar
They are only made in 87.5mm and 88mm. I would not bore a stock sleeve over 88mm
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
EdgeAutosport.com (12-22-2014), Micha (12-20-2014)
 Old 12-20-2014, 09:46 AM   #27
NCspecV81's Avatar
Oh definitely not. Iron ductile sleeves ftmfw.
2013 CWP and Stock
 Old 12-22-2014, 03:35 AM   #28
shaneski's Avatar
Excellent info as usual guys, since CPE's are rare as shit these days have been eyeing these for a rebuild.
 Old 12-22-2014, 10:44 AM   #29
I can't wait to see some motors running with these. I have a feeling they will be an excellent option!
shaneski (12-23-2014)
 Old 12-22-2014, 10:59 AM   #30
865ms3's Avatar
Posts: 2,602   (View Stats)
im about to order a set after the holidays. time to get this build going.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
Justin@Freektune (02-05-2015)
 Old 02-03-2015, 02:59 PM   #31
l4nc3r's Avatar
Posts: 153   (View Stats)
l4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the worldl4nc3r is the leader of the world
Anyone install a set of these yet? Any issues you all have seen? Wanting to order some soon.
07 Red Speed3 - SHE'S ALIVE! SHE'S ALIVE!!!
GT3071R / HTP 4" Intake / Brentported Intake Manifold / CXRacing Piping with TR8L Core
DNP v2 Exhaust Manifold / Stainless Steelworks Downpipe/Test Pipe / HKS Hi-Power CatBack
FreekTuned E25 / HKS SSQV2 / JBR 88 Trio
Bilstein B8's / Eibach Prokit / Drag DR-34 18x8
Soon to be installed - Snow Performance Meth Kit with CM14 Nozzle
l4nc3r is offline   Reply With Quote
The Following User Says Thank You to l4nc3r For This Useful Post:
865ms3 (02-03-2015)
 Old 02-04-2015, 02:16 PM   #32
We've been selling quite a few and no one has let us know of any issues.
 Old 02-04-2015, 02:24 PM   #33
Lakespeed6's Avatar
Block is completed should have it running in about a week.
The Following 3 Users Say Thank You to Lakespeed6 For This Useful Post:
BLKSTIG (02-04-2015), EdgeAutosport.com (02-04-2015), JgamB (02-06-2015)
 Old 02-04-2015, 04:39 PM   #34
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Waiting patiently for mine to show up.
 Old 02-05-2015, 11:15 PM   #35
The Nut's Avatar
Posts: 1,571   (View Stats)
Subbed for feedback.
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 02-06-2015, 12:29 AM   #36
shaneski's Avatar
I just put my order in for a set, if they turn out shit we will be having a group ZZB lol
 Old 02-06-2015, 01:13 AM   #37
The Nut's Avatar
Everybody is afraid to go first, but Manley's rep for all the other platforms is pretty shiny.
 Old 02-06-2015, 08:56 AM   #38
Yeah I don't imagine we'll have any problems with these pistons...
shaneski (02-07-2015), The Nut (02-07-2015)
 Old 02-07-2015, 12:51 AM   #39
shaneski's Avatar
Speedperformance have done a few engines with them and haven't had a problem.Looks like CPE missed out on some business with slow restocking of their pistons
The Following User Says Thank You to shaneski For This Useful Post:
 Old 02-07-2015, 01:18 AM   #40
The Nut's Avatar
So no reason not to feel confident with the wrist pins the come with for a 500whp (tops) build?
Wiseco pistons question pistons squirters clearance JDMCRX MazdaSpeed 3 - Engine, Transmission & Driveline 6 11-27-2013 05:23 PM
Official: Mercedes-Petronas AMG W04 launched to little fanfare, lot of pressure [w/video] Haltech Automotive News 0 02-05-2013 12:50 PM
LA 2009: 2011 Ford Mustang V6 on show floor with little fanfare Haltech Automotive News 0 12-02-2009 05:10 PM
Page generated in 0.59559 seconds with 38 queries
