Like Tree21Likes
 Old 03-22-2015, 06:36 PM   #81
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
According to the sheet I got with the Pistons and rings it said to go bore x .007". I'm going off the 15-30psi street car row.
A) they call that for both top and 2nd ring.
B) seems odd to have both rings the same
C) bore x .007 comes out to like .024 that seems huge compared to other builds running .018 or .020.
And to note, I called Manley to discuss this and I got a generic response "if that's what the sheets says then that's right. Those measurements came straight from TotalSeal."
Last edited by jdmage_mx5; 03-22-2015 at 06:36 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-22-2015, 06:43 PM   #82
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
huge gap is huge. with a piston made from said material (between race and OEM) I would expect smaller gaps...but I am by no means experienced in this area. Smaller required P2W is a given but I don't understand the large ring gaps and especially 1st and 2nd rings being the same?
interesting.
 Old 03-22-2015, 06:49 PM   #83
jdmage_mx5's Avatar
Pwc was like .0035 for coated.
huge gap is huge. with a piston made from said material (between race and OEM) I would expect smaller gaps...but I am by no means experienced in this area. Smaller required P2W is a given but I don't understand the large ring gaps and especially 1st and 2nd rings being the same? interesting.
I started to follow the directions and really did not feel comfortable with such a huge gap. I have since ordered new ring sets from Manley and now trying to decide what gap I actually need to run.
Last edited by jdmage_mx5; 03-22-2015 at 06:49 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-22-2015, 07:31 PM   #84
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Bigger the better when it comes to ring gap.
Institution Of Diagnostic Engineers
Mauro_Penguin likes this.
"Exclusivity" - CP-enis
Demodded.
The Seals
Last edited by Tokay444; 03-22-2015 at 07:31 PM. Reason: MSF Database - Automerged Doublepost
The Following 6 Users Say Thank You to Tokay444 For This Useful Post:
Easter Bunny (03-23-2015), GrumpyMPS (03-22-2015), highwayrun (03-22-2015), King Scumbag (03-22-2015), Mauro_Penguin (03-22-2015), The Nut (03-23-2015)
 Old 03-23-2015, 07:19 AM   #85
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Would you mind sharing your thoughts on PWC and ring gap with these Pistons? I know you have installed a few sets. I'm just curious as to what the more knowledgeable are running spec wise with these.
Always use their recommendations as a guidleline and adjust each spec per customers engine use/goals.. Each engine is built to spec, so there is no one size fits all.
Originally Posted by acemanz View Post
So given that we are using what you consider to be a product that should really only be used in an engine with regular overhaul intervals, what is your thoughts about the realistic longevity of these in a Daily Driver car.
how long do we got doc?.. give it to me straight..
I have guys that have 40k+ miles on their engines, and as lex mentioned, short of louder piston slap, haven't had any ill effects. But things that do occur is more blowby and oil consumption. The key with keeping her healthy starts with a proper break in, maintenance, and definitely a good PCV system. I like big ports to let that CC vapor escape whether 10an fittings to a vented can, or breather cap.
I think Manley really hit it on the head by using the thicker top ring as opposed to the other pistons that are available right now. Each motor that I have used them in, is running, and all were pulling crazy manifold vacuum within just as few miles. I gave one of the engines a little boost (1-2psi) about 5 miles into my road test and that thing just wanted to pull. Made me all giddy inside. lol
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 7 Users Say Thank You to Justin@Freektune For This Useful Post:
Easter Bunny (03-23-2015), EdgeAutosport.com (03-23-2015), Mauro_Penguin (03-23-2015), Micha (03-23-2015), shaneski (03-24-2015), SpeedRebirth (03-23-2015), The Nut (03-23-2015)
 Old 03-23-2015, 12:17 PM   #86
Trail of Fail
Dano's Avatar
interesting theory and testing results.
 Old 03-23-2015, 01:21 PM   #87
Lots of good info going on in here! Thank you Justin, Alex, and Tokay! Oh and jdmage_mx5 as well!
Justin@Freektune (03-23-2015), Tokay444 (03-23-2015)
 Old 03-23-2015, 04:50 PM   #88
Tokay444's Avatar
Groans: 793
The absolute LAST thing you want, is ring butting. Then you get what happens to the stock motor, but with a lot more work and at a higher cost.
I went .020" top ring and .025" second.
Left the oil control ring as it were.
Demodded.
The Seals
 Old 03-23-2015, 05:29 PM   #89
Trail of Fail
Dano's Avatar
yup and IIRC I went with .018-.019 top and .022 2nd.
I just don't want oil consumption and with the above gaps on my 90mm wisecos, I have none, with a 5% leakdown after 4K miles on 28-30PSI tune.
I think it can be a balancing act for sure.
Easter Bunny (03-23-2015), Justin@Freektune (03-23-2015)
 Old 03-23-2015, 05:45 PM   #90
You ever going to turn that motor on?
Mauro_Penguin (03-23-2015), Tokay444 (03-23-2015)
 Old 03-23-2015, 05:57 PM   #91
Trail of Fail
Dano's Avatar
it won't build enough compression to start...
Easter Bunny (03-24-2015), Mauro_Penguin (03-23-2015)
 Old 03-23-2015, 06:01 PM   #92
Lol..... If your first built motor ran he should be fine.
Dano (03-23-2015), Justin@Freektune (03-23-2015), Tokay444 (03-23-2015)
 Old 03-23-2015, 06:54 PM   #93
Tokay444's Avatar
Groans: 793
Shipping head for FreekBuilt this week.
The oil control ring is what keeps the majority of the oil out of the combustion chamber.
There isn't a lot left to get past a gap smaller than the thickness of a finger nail in two compression rings. Especially since there is more pressure trying to push past the rings in the opposite direction than there is pulling oil from underneath.
Demodded.
The Seals
Easter Bunny (03-24-2015), EdgeAutosport.com (03-24-2015), Justin@Freektune (03-23-2015), Mauro_Penguin (03-23-2015)
 Old 03-23-2015, 07:50 PM   #94
Trail of Fail
Dano's Avatar
don't you mean 2nd? or 3rd? I lose track...lol
I guess I should state my objections more correctly...I don't want consumption for sure but what I really meant was I don't want blow-by filling up my OCC and/or my VTA filter getting soaked. both my 2nd and 3rd (current) builds are as dry as a powder house...well not that dry but you get the point.
Last edited by Dano; 03-23-2015 at 07:51 PM. Reason: MSF Database - Automerged Doublepost
Easter Bunny (03-24-2015), Tomas (03-24-2015)
 Old 03-23-2015, 07:57 PM   #95
Tokay444's Avatar
Groans: 793
In that case, I refer back to the document I posted.
I even actually considered pinning the rings.
A differnce of a couple thou isn't going to be what pressurizes your crank case or not, but it can be the differnce between end butting or not.
We've seen broken lands on forged pistons.
Demodded.
The Seals
Easter Bunny (03-24-2015), Mauro_Penguin (03-23-2015), Tomas (03-24-2015)
 Old 03-23-2015, 08:03 PM   #96
2nd counting the drop and pop.
1st "virgin" even though we know now she was a slut.
Man I forgot how much fail you had.
Tomas (03-24-2015)
 Old 03-24-2015, 09:37 AM   #97
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
The words Dano and Virgin are equivalent to the words Anti and Christ.
As separate entities they are harmless.
Together mayhem ensues.
Justin@Freektune likes this.
The Following 5 Users Say Thank You to Tomas For This Useful Post:
Dano (03-24-2015), Easter Bunny (03-24-2015), EdgeAutosport.com (03-24-2015), Justin@Freektune (03-24-2015), Mauro_Penguin (03-24-2015)
 Old 11-08-2016, 04:07 PM   #98
alfre127's Avatar
Posts: 291   (View Stats)
alfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond reputealfre127 has a reputation beyond repute
so anyone push this pistons with more than 600whp, with stock wristpins?
GTX3076 EWG // Tial Waste Gate // Sure 3.25 Big Mouth // // JBR Side Motor Mounts // JBR, SS Kit, Corksport RMM Inserts // Cobb Pipping with TRL8 // CNT DP // CNT Cat back // DNP Mani // Autotech HPFP // Rota G-force 18x8.5 // Eibach Pro Kit Springs // Cobb AP, // Auto meter boost and vacuum gauges // AEM A/F gauge // AEM Meth Stage 2 kit // Hella Horns // PTP injector seals // PNP IM // TIGS // EGR Delete // ACT 6 Puck Sprung/Streetlite // Superskaterex 74MM TB //
alfre127 is offline   Reply With Quote
 Old 11-10-2016, 06:12 PM   #99
Tokay444's Avatar
Groans: 793
Is there something inherently wrong with the stock wrist pin?
Demodded.
The Seals
 Old 11-11-2016, 12:10 PM   #100
Bob Ross Fanclub
Tomas's Avatar
The Pu wrist pins have a smaller wall thickness then the Gen1 pistons. They are also lighter.
None have ever failed however.
Mauro_Penguin (11-11-2016)
 Old 11-12-2016, 06:39 AM   #101
bdm665's Avatar
Posts: 101   (View Stats)
bdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to behold
the MSF3 coupon code isnt working. what am i missing?
2007 ms3 gt w/ 23000mi. New timing assembly and Rebuilt trans. With brass pads and new syncros and luk clutch at 22000. Mazdaspeed intake, ported intake manifold, vtcs delete, egr delete, fmic, ported and rebuilt k04 turbo, forge bpv w/ yellow spring, corksport hpfp, jbr 88 duro rmm, jbr balance shaft delete, oil pan baffle, catless dp, xt-m5-qs trans oil, mobile 1 full synthetic motor oil. Coming soon: cs injector seals, manley h beam connecting rods, a/c delete, alternator relocation, main egr delete, forged pistons...
bdm665 is offline   Reply With Quote
The Following User Says NO Thank You to bdm665 For This Un-useful Post:
InkedInspector (11-17-2016)
Wiseco pistons question pistons squirters clearance JDMCRX MazdaSpeed 3 - Engine, Transmission & Driveline 6 11-27-2013 05:23 PM
Official: Mercedes-Petronas AMG W04 launched to little fanfare, lot of pressure [w/video] Haltech Automotive News 0 02-05-2013 12:50 PM
LA 2009: 2011 Ford Mustang V6 on show floor with little fanfare Haltech Automotive News 0 12-02-2009 05:10 PM
Page generated in 0.45009 seconds with 29 queries
