| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
![]() | | #41 | ![]() |
![]() Join Date: Apr 2013 Location: Keystone,CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score |
| The Following 3 Users Say Thank You to lookback For This Useful Post: |
![]() | | #42 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
. Its probably a safe bet to say it wont fit with the ETS TMIC either. What was making contact? Thanks for the info.
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
| The Following User Says Thank You to ItsNox For This Useful Post: | Code Monkey (05-04-2015) |
![]() | | #43 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
(Thread Starter) | Not Ranked : 0 score Double EDIT: At this point, we have to assume that it won't fit with any TMIC. We are going to address this with DOC Race though. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | ItsNox (05-04-2015) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Truth be told I'm not surprised. I've seen this EM in person and although beautiful and performance proven, does look like it flares too high to fit any TMIC. He already had a FMIC installed so that was not an issue with his. I love the simplicity of a TMIC setup but after seeing what this mani can do I needz this later in my life. Hrmmmmm.....
| The Following User Says Thank You to ItsNox For This Useful Post: | EdgeAutosport.com (05-05-2015) |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score This is one heck of a manifold! Hand welded and extremely well built. We can officially say now that it will not fit with a TMIC though. |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score These are proving to be rather popular! We can't keep them on the shelf! But no worries cause we have more on the way! |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | Micha (06-10-2015) |
![]() | | #47 | ![]() |
Sent via Tapafail
| The Following User Says Thank You to ItsNox For This Useful Post: | EdgeAutosport.com (06-11-2015) |
![]() | | #48 | ![]() |
| Not Ranked : 0 score EWG yet?
| The Following User Says Thank You to Code Monkey For This Useful Post: | ItsNox (06-10-2015) |
![]() | | #49 | ![]() |
| The Following User Says Thank You to ItsNox For This Useful Post: | Code Monkey (06-11-2015) |
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score No EWG option. If somebody wants donate their car for some fab work, I'm sure DOC Race wouldn't mind making an EWG option... |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score This is a great bang for the buck manifold! |
![]() | | #52 | ![]() |
![]() Join Date: Jul 2011 Location: Danvers, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,418
| Not Ranked : 0 score It's been a while, do these come with an option for V Band yet, or are they still only stock flange? Either way, curious if they're in stock.
__________________ 2006 Black Mica MS6 GT FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob Stock motor w/ GT2871r: 380 awhp, 375 awtq @ 24 psi (e85 only) ![]() - 13.1 @ 110, 2.1 60 ft |
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score Still just stock flange for options, and we just sold our last one. We'll have more on the way soon though. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | Fail_6 (09-21-2015) |
| Full Race Exhaust Manifold/Exhaust Combo | mr.speedy3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 01-29-2015 07:56 PM |
| Full Race Exhaust manifold with Bnr? | onetechyguy | MazdaSpeed 3/6 - Big Turbo Builds | 2 | 04-02-2014 01:25 PM |
