 Old 05-31-2013, 10:22 AM   #1
bigmike's Avatar
Posts: 278   (View Stats)
bigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond repute
Talking Shoutout to Edge!!!
I'd like to take a minute to give a quick thanks and recommendation for Edge Autosports. If anyone is on the hunt for a certain product and Edge has it, buy from them. There is even a coupon in the VIP section! I've only placed one order from them so far but shipping was quick and they gave me a little gift....
(don't ask me why the picture isn't rotated; I don't know how to)
2/1 91 octane gasoline/E85, Stratified tuned, ~340 hp/360 ft·lb
AEM Water/methanol injection kit 550 ml/min nozzle ~5 psi/10 psi triggers 1/1 methanol/water Filter Autotech HPFP internals BrakeBest Brake pads Front Clarion XC1410 car amplifier COBB Tuning Downpipe Catback exhaust Front mount intercooler v2.0 XLE bypass valve Hybrid mode Short ram intake Turbo inlet hose Airbox Sport springs Short throw shifter Shift knob Shifter weight AccessPORT V3 Corksport Mid chassis brace Oil catch can Rear sway bar Radiator shrouds LED light kit cp-e SAFEseal injector seals Excalibur Wheel Accessories Black acorn bulge lug nuts 3/4" Echlin Ignition Parts Tire pressure monitoring system Left, right tire Firehawk Wide Oval Indy 500 tires 225/40R18 XL Ground Control Frim strut bump stops Front Interstate Mega-Tron battery James Barone Racing Rear motor mount 88 durometer Transmission side motor mount 80 durometer Passenger side motor mount 80 durometer EGR block off kit Thermal insulating intake gasket kit Thermal insulating throttle body gasket Coolant bypass kit Solid shifter bushings Bypass valve hose Kicker 40CSS684 component speaker system Front KS68 speakers Rear 11PT10CA powered subwoofer enclosure Koni Sport yellow shock absorbers Front 540 degrees LLumar ATR 35 film Mazda 2004-2008 RX-8 rims 18" x 8" FL22 engine coolant Monroe Sensa-Trac shock absorbers Rear Motorcraft XT-M5-QS transmission fluid NGK Iridium IX 6510 LTR7IX-11 spark plugs ~0.28" gap Shell Rotella T6 5W-40 motor oil SSP Primary EGR delete kit Stratified Tuning Guardian Angel ~21.5 psi trigger Visual Garage Shark fin antenna
bigmike is offline   Reply With Quote
The Following 2 Users Say Thank You to bigmike For This Useful Post:
EdgeAutosport.com (06-02-2013), trancehead (05-31-2013)
Thanks edge! esestak EdgeAutosport.com 1 04-16-2013 05:24 PM
Thank you JP@Edge ms3blackmica EdgeAutosport.com 24 01-18-2013 01:40 AM
Edge Down? Airman3454 EdgeAutosport.com 37 06-18-2012 04:22 PM
Chicago 2010: New Ford Edge becomes cutting edge CUV Haltech Automotive News 0 02-10-2010 10:30 AM
Page generated in 0.22480 seconds with 22 queries
