Mazdaspeed Forums
-   EdgeAutosport.com (http://www.mazdaspeedforum.org/forum/forum/f539/)
-   -   Stage 3 MZR Motor Build Kit???? (http://www.mazdaspeedforum.org/forum/forum/f539/stage-3-mzr-motor-build-kit-220432/)
juantaburger 04-22-2019 07:22 AM
https://edgeautosport.com/stage-3-mz...d-6-2006-2007/
Anyone purchased this? Planning on getting it for my build.. not sure if you guys think it's worth it or not.
Thanks!!!!!
5doorsoffury 04-22-2019 09:56 AM
I think i got that one then added the vvt and the cam washers and the bolts for cam/crank. You still need injector seals. It worked out to be a better price once you add in the valve seals and injector orings.
You also need the obvious. It dosent come with bearings btw.
Page generated in 0.16782 seconds with 11 queries
