 Old 12-10-2014, 08:53 AM   #1
Default Supertech Valvetrain Kit at EdgeAutosport
Hey guys, we are always looking to make things easier for you when purchasing stuff on our site. We want to make sure you get everything you need. In some cases people don't know exactly what they need and that's why we have put together kits for motor build, VVT, and OE clutch as well as a few others. For our latest "kit" we have the Supertech Valve Train. Its nothing crazy, and is just to save you a step when ordering parts for your head.
The Supertech Valvetrain Kit comes with guides and seals as well as the springs of your choice. With this kit, we are just trying to make it a little bit easier and save some people having to call back and order again after they realize they need the valve guides and seals as well.
The Supertech Valvetrain Kit is $496.98 and you can have your choice of 55lb, 70lb, or 83lb springs.
As always, let us know if you have any questions, and we'll be happy to help!!
The Following 11 Users Say Thank You to EdgeAutosport.com For This Useful Post:
dan7225 (12-10-2014), Hammology (12-23-2014), hatchedspeed3 (12-16-2014), jack_hammer (12-16-2014), kbz0129 (12-10-2014), Micha (12-10-2014), Mr. T (12-11-2014), rob ms6gt (12-10-2014), SparkySparks (12-10-2014), SpeedRebirth (12-10-2014), WetzMS3 (12-16-2014)
 Old 12-16-2014, 12:35 PM   #2
kvg823's Avatar
Posts: 58   (View Stats)
kvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant future
Default Reading my mind
@EdgeAutosport.com; you all know how to make the decision to buy or not to buy a whole lot easier....
I noticed that the Exh valve and Intake valve you sell from supertech (their catalog here: Exh and Intake) difference in valve dimensions:
Exhaust - Supertech
Head Diam: 30mm(std)
Stem Diam: 5.48mm
Length: 104.7mm
Exhaust - OEM spec from manual-
Head Diam: 28.3 (not accounting for margin thickness)
Stem Diam: 5.965-5.980mm Minimum: 5.935mm
Length: 104.25--105.05mm
Intake- Supertech
Head Diam: 35mm(Std)
Stem Diam: 5.48mm
Length: 103.40mm
Intake - OEM spec from manual
Head Diam: 33.5mm (not accounting for margin thickness)
Stem Diam: 5.970-5.985mm Minimum: 5.940mm
Length: 102.99--103.79mm
I am assuming that the supertechs head diameter are larger because they account for the seat length while Mazda does not, but why the difference in stem diameter? I saw in an earlier post from you all that supertech valve guides are needed, and I assume this valve stem diameter is the reason?
2006 "GTMO Green" Speed 6
{ Corksport TBE w/ resonator }{ COBB AP }{ Corksport Max-Flow internals }
{ TWM STS Stg 2 w/ bushings }{ Primary/Secondary EGR Deletes }{ JBR Motor Mount Trilogy}
{TurboSmart BPV }{ COBB TIP }{ SS Brake/Clutch Lines }{ ARP Head Studs }
HTP 4" intake w/ 51R }{ FMIC }{ Enkei PF01 Rims }{ Stoptech Slotted rotors }{ AEM Wide-band AFR gauge }
AEM TRU-Boost Controller }{ Gauge pod (Block8head) }{ Bnoon Bolt }
{ Turbo-timer (yeah...) }{ PERM Plate }{ JBR Intake/TB TIGs }
{ Coming Soon: install GT3071r EWG setup, CPE Seals, tune, and re-paint }
kvg823 is offline   Reply With Quote
 Old 12-16-2014, 01:02 PM   #3
Exhaust - Supertech
Stem Diam: 5.48mm
Length: 104.7mm
Intake- Supertech
Stem Diam: 5.48mm
Length: 103.40mm
It probably has something to do with the manufacturing process. These valves are most likely used in a few other platforms so its easier and more cost effective for supertech to make a valve with a certain stem thickness and just change the the seals to fit the different applications.
 Old 09-29-2015, 11:42 AM   #4
Valvtrain kit comes with everything but the valves might as well build your engine once and build it right!
WetzMS3 (09-29-2015)
 Old 11-02-2015, 02:04 PM   #5
Doing a build? Build it right the first time!
Supertech Valvetrain Info holeinmypocket MazdaSpeed 3 - Engine, Transmission & Driveline 27 03-06-2015 11:29 AM
E30 UOA results with SuperTech 5w-30 Synthetic cld12pk2go MazdaSpeed 3/6 - E85 Fueling 6 08-27-2014 10:31 AM
Supertech Valvetrain at EdgeAutosport EdgeAutosport.com EdgeAutosport.com 5 05-28-2014 05:12 PM
Supertech valve into jracer Mazdaspeed3/6 General Discussion 28 09-25-2012 03:20 PM
Supertech wants our head zx2man MazdaSpeed 3 - Engine, Transmission & Driveline 38 07-17-2011 07:03 PM
Page generated in 0.28154 seconds with 21 queries
