 Old 11-15-2013, 03:40 PM   #1
Default Whats in stock at EdgeAutosport
Just wanted to start this thread to let you guys know some of the less common items that we like to keep in stock here at EdgeAutosport. Keep in mind this is not all we have in inventory it but it is just some of the stuff you might not think we would have and I will update this thread as stuff continues to come in.
DriveShaftShop Rear Axles MS6 (both right and left in stock)
Product Description
DriveShaftShop has created a monster rear axle for the Mazdaspeed 6 capable of handling 500HP. This axle features our aerospace grade torsional axle bars, a proprietary direct fit outer CV and billet inner CV. The axles are complete and ready to install with no modifications required.
SuperTech Valvetrain for MS3/6 (complete valvtrain in stock)
Product Description
- Standard Size Head
- Standard Length
- Dished Face
- Inconel
Product Description
- Standard Length
- Flat Face
- Nitride
We apply more than 30 years of experience in the development of each and every Supertech racing valve we sell. Combine this experience with state of the art equipment such as ultrasonic tests, x-rays, laser measurement equipment, and applications like computerized Finite Element Analysis (FEA) and it is no wonder why supertech has some of the best performance products on the market.
Product Description
-Supertech valve springs are made with premium Superclean Chrome Silicon Vanadium Steel alloy for higher performance & durability at high rpms and better memory.
-Computer designed to ensure that wire stress levels do not overpass the limits of stress defined in the diagrams of fatigue for long durability under extreme conditions.
-Computer software also allows us to make sure that the harmonics arewell under control.
-The retainers are manufactured with high quality military certified Titanium alloy, CNC machined for a tight fit that will ensure a long durability.
Type: Single Spring
Press.Seat: 55 @ 35
Press.Open: 150 @ 10
Max Lift: 14.3mm
Coil Bind: 20.7mm
Rate: 9.6mm
Retainer: RET-TS5.5/T1+Fact Seat + SEAT-DUR1
OutSpr.OD: 27.5mm
OutSpr.ID: 20mm
(guides and seals not pictured but those are in stock as well)
Boosted Beluga (11-15-2013), Jh8909 (11-15-2013), LumberJack (11-17-2013)
 Old 11-16-2013, 04:57 PM   #2
Airman3454's Avatar
Posts: 567   (View Stats)
Airman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the world
Free bump.. We will see how those dual springs will work on this build!!
Airman3454 is offline   Reply With Quote
 Old 11-17-2013, 10:21 PM   #3
LumberJack's Avatar
Groans: 57
Should be plenty plenty for the build. I'm normally overkill central on all my builds and I still stayed with the 55lb single setup. Should be plenty to rev to our Table limits with comfort.
@JP@edgeautosport.com; those look awfully familiar to what we talked about on the phone friday
10.36@148 Fastest Gen 2
EdgeAutosport.com (11-18-2013)
ACT Clutches In Stock at EdgeAutosport. EdgeAutosport.com EdgeAutosport.com 7 09-30-2013 03:42 PM
CP-E Downpipes In Stock at EdgeAutosport EdgeAutosport.com EdgeAutosport.com 13 09-06-2013 10:37 AM
K1 Rods In Stock at EdgeAutosport!! EdgeAutosport.com EdgeAutosport.com 3 04-02-2013 12:22 PM
Whats a stock hpfp with stock internals worth? mutiger93gt MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 01-15-2012 08:14 AM
Page generated in 0.25641 seconds with 22 queries
