  • 1 Post By sheston
 Old 06-27-2016, 07:55 AM   #1
Default When do you need a bigger intake?
Hey guys, check out our latest blog!
On a turbocharged car, the intake is often sized according to the stock turbo from the factory. It will be designed to dampen noise, and fit with relative ease into a certain area of the engine bay. This comes before performance and this is why upgraded intakes are such a huge benefit to making power on a turbocharged car. Smoother tubing with a high flow filter will reduce restriction and make less work for your turbo. However, sometimes even these upgraded stock replacement intakes are not enough. Read More!
hermz (06-28-2016), KiwiFlavor (06-28-2016), SpeedRebirth (06-27-2016)
 Old 06-27-2016, 05:04 PM   #2
GCPhotographers's Avatar
Posts: 1,198   (View Stats)
Nice article. I needed that info because I have the jrb 3.5 and wanted to go bigger. It looks like it wouldn't be much different unless I am pushing big power.
2012 Black MazdaSpeed3
Fuel: 91 & 93 Octane /
COMING SOON
EdgeAutosport.com (06-29-2016)
 Old 06-28-2016, 11:08 AM   #3
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
For a street driven or daily driven car going larger than 3 is counter-productive. 3.5" may work though. Remember a 3" ID intake is good for well above 400whp. So adding a 3.5" intake (probably good for 600hp) on a car that doesn't have the supporting mods even for 350whp is not ideal because at low air flow (think idle, bumper to bumper traffic, and so on) the air speed is so small that may cause erroneous MAF readings. Still, a 3.5" intake may still be acceptable, but 4" is overkill for anything street driven.
Later edit: sadly, this is something that article is not mentioning about. "the bigger - the better" works well only when you're pushing for the maximum all the time (say, track). When still using the car for it original purpose the things became a bit more complicated.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 06-27-2016, 06:09 PM   #4
sheston's Avatar
Posts: 1,847   (View Stats)
I thought the answer to the question was always :-)
EdgeAutosport.com likes this.
 Old 06-28-2016, 11:28 AM   #5
I know a local here has a 4in intake on his daily.
And i have a 3.5in with no issues with driving (idle and everything) either.
sent from my Nexus 6P
The Following 3 Users Say Thank You to MS3Shadow For This Useful Post:
EdgeAutosport.com (06-29-2016), TRBLSM (06-28-2016), WetzMS3 (06-28-2016)
 Old 06-28-2016, 03:25 PM   #6
Well since my hp goal is 600-650, I guess I am going.
COMING SOON
 Old 06-28-2016, 05:41 PM   #7
rocknrolla47's Avatar
Posts: 77   (View Stats)
rocknrolla47 is just really nicerocknrolla47 is just really nicerocknrolla47 is just really nicerocknrolla47 is just really nice
Groaned at 14 Times in 6 Posts
I'm rockin a jbr 3.5 wide path full aluminum intake. Daily driven and no idle or driving issues after calibration. Plus the sound it makes is awesome
I feel like 4in intake is better used for a huge turbo like a precision turbo. If you have a ko4 but plan on upgrading to a bnr , a Garrett or corksport turbo , 3in or 3.5 will do. Plus I heard of idle issues with the 4in intake.
Corksport hpfp- Corksport long catted downpipe-Ultimate racing catback- tr6 front mount intercooler w/ cx racing piping- Jbr 3.5 tru wide path aluminum intake- Jbr 3port bcs- Jbr rear and passenger mount-Bosch 3 BAR MAP sensor- Jbr shifter bushings- Matt Damond shift plate-
rocknrolla47 is offline   Reply With Quote
The Following User Says Thank You to rocknrolla47 For This Useful Post:
 Old 06-28-2016, 05:58 PM   #8
sheston's Avatar
I have a 4 in on my K04 DD and love it. Wouldn't do it any other way :-)
 Old 06-28-2016, 06:01 PM   #9
How's the fitment with the coolant line under the turbo inlet hole ?
 Old 06-29-2016, 07:43 AM   #10
Very tight with any larger than stock intake. But still doable...
I ran a 3.5" on my daily speed 3 back in the day. Ran perfect at idle and I didn't even run higher idle speeds. I think going up to 4" is where you might start to see some issues, but even then they are minimal.
The biggest issue I've seen from bigger intakes is popping the P0335 code. Since bigger intakes need to be scaled so high, when you turn the key on but the motor is still off, the ECU will see the higher voltage and think the car is running. It has a crank position sensor check that happens when g/s is over a certain amount and it looks to see the crank sensor pulse after a certain time frame. When that doesn't happen since the engine is off, it throws the code.
 Old 06-29-2016, 07:41 PM   #11
sheston's Avatar
Most find it fairly easy to splice in some extra coolant line so you don't have to worry about it. I find it helps me to have extended it every time I have to remove the intake
Upgrade to bigger intake--Order new tune or recalibrate myself? TORQUERULES 2010 MS3 - ECU Computer Tuning 12 03-19-2016 01:07 AM
Going bigger FMIC core to support bigger power KCi 2010 MS3 - Turbo Induction 9 08-06-2015 10:07 AM
bigger tip and intake? cocoleveo7686 MazdaSpeed 6 - Engine, Transmission & Driveline 14 03-13-2014 05:59 PM
Bigger intake/exhaust or new turbo? KevMS6 MazdaSpeed 3/6 - Turbo Induction 19 08-22-2013 11:40 PM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 09:50 AM
Page generated in 0.32353 seconds with 25 queries
