| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
(Thread Starter) | Not Ranked : 0 score On a turbocharged car, the intake is often sized according to the stock turbo from the factory. It will be designed to dampen noise, and fit with relative ease into a certain area of the engine bay. This comes before performance and this is why upgraded intakes are such a huge benefit to making power on a turbocharged car. Smoother tubing with a high flow filter will reduce restriction and make less work for your turbo. However, sometimes even these upgraded stock replacement intakes are not enough. Read More! |
| The Following 3 Users Say Thank You to EdgeAutosport.com For This Useful Post: |
![]() Join Date: Sep 2014 Location: SoCal from NC and NYC
| Not Ranked : 0 score Nice article. I needed that info because I have the jrb 3.5 and wanted to go bigger. It looks like it wouldn't be much different unless I am pushing big power.
__________________ __________________ 2012 Black MazdaSpeed3 Power: GTX3076R IWG / COBB EBCS / Bosch MAP Sensor Adapter Harness / Bosch 3 Bar T-MAP MAP Sensor with IAT / JBR TRU-3.5 / DM EGR Delete Kit / FORGE V1 BPV / AUTOTECH HPFP INTERNALS / UR TBE / UR DP / UR SP / NGK IRIDIUM IX / COBB SW / UR FMIC / MD OCC V1 & V2 / BrassCraft Coolant Bypass / RC IM Mani / cp-e Exi Mani / ZZB REPLACEMENT / Handling: DM TMM / DM RMM / DM PMM / JBR FSB / JBR RSB / JBR RTA / CS FEL / SPC CAMBER ARMS / BCRacing COILOVERS / GTSPEC STB /FRONT EBC YELLOWS / FRONT EBC SLOTTED ROTORS / GOODRIDGE SSL / TWM STS /RPF1 17x9 Wheels / 225/45-17 Toyo Proxes S4 / ACT ZX4-HDG6 / Extra Safety: COBB AP V3 / AEM WIDEBAND FAILSAFE (AFR) / V1 / AEM TRU BOOST / CS Skidplate / Innovate Motorsports MTX-D: Oil Pressure & Temperature / Fuel: 91 & 93 Octane / Looks: VENTPOD / JTMS3 DUAL POD / RB MUD FLAPS / Black Glossified Dipped Stock Wheels / GV OPEN MOUTH GRILL / JBR SHIFT KNOB / Black Powder Coated Front Calipers with Green MazdaSpeed Decals / Green Cabin and Trunk 8K Lights / Green Demon Headlights with black painted housing and RBG halo rings / RC signature VC / JTMS3 Stealth Sub Enclosure with a 10" JL Swallow Sub / baysonR MS-Style Lip Kit / COMING SOON AEM METH KIT / Anti Laser Priority /CS Radiator Panel / CS Rear Chassis Brace / CS Mid-Chassis Brace / CS Hood Scoop / DYNO TUNED by HYPNOTIC 93 and STREET TUNED on 91 soon e85 mix |
| The Following User Says Thank You to GCPhotographers For This Useful Post: | EdgeAutosport.com (06-29-2016) |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score I thought the answer to the question was always :-)
__________________ Max Bolted and Built Stock K04 |
| The Following User Says Thank You to sheston For This Useful Post: | EdgeAutosport.com (06-29-2016) |
Groans: 111
Later edit: sadly, this is something that article is not mentioning about. "the bigger - the better" works well only when you're pushing for the maximum all the time (say, track). When still using the car for it original purpose the things became a bit more complicated.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| The Following User Says Thank You to mituc For This Useful Post: | EdgeAutosport.com (06-29-2016) |
| I know a local here has a 4in intake on his daily. And i have a 3.5in with no issues with driving (idle and everything) either. sent from my Nexus 6P
| The Following 3 Users Say Thank You to MS3Shadow For This Useful Post: |
| Not Ranked : 0 score Well since my hp goal is 600-650, I guess I am going.
![]() Join Date: Dec 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 14 Times in 6 Posts
| Not Ranked : 0 score I'm rockin a jbr 3.5 wide path full aluminum intake. Daily driven and no idle or driving issues after calibration. Plus the sound it makes is awesome ![]() I feel like 4in intake is better used for a huge turbo like a precision turbo. If you have a ko4 but plan on upgrading to a bnr , a Garrett or corksport turbo , 3in or 3.5 will do. Plus I heard of idle issues with the 4in intake.
__________________ Corksport hpfp- Corksport long catted downpipe-Ultimate racing catback- tr6 front mount intercooler w/ cx racing piping- Jbr 3.5 tru wide path aluminum intake- Jbr 3port bcs- Jbr rear and passenger mount-Bosch 3 BAR MAP sensor- Jbr shifter bushings- Matt Damond shift plate- |
| The Following User Says Thank You to rocknrolla47 For This Useful Post: | EdgeAutosport.com (06-29-2016) |
| Not Ranked : 0 score I have a 4 in on my K04 DD and love it. Wouldn't do it any other way :-)
| Not Ranked : 0 score How's the fitment with the coolant line under the turbo inlet hole ?
I ran a 3.5" on my daily speed 3 back in the day. Ran perfect at idle and I didn't even run higher idle speeds. I think going up to 4" is where you might start to see some issues, but even then they are minimal. The biggest issue I've seen from bigger intakes is popping the P0335 code. Since bigger intakes need to be scaled so high, when you turn the key on but the motor is still off, the ECU will see the higher voltage and think the car is running. It has a crank position sensor check that happens when g/s is over a certain amount and it looks to see the crank sensor pulse after a certain time frame. When that doesn't happen since the engine is off, it throws the code. | |
| Not Ranked : 0 score Most find it fairly easy to splice in some extra coolant line so you don't have to worry about it. I find it helps me to have extended it every time I have to remove the intake
| Display Modes | |
| Upgrade to bigger intake--Order new tune or recalibrate myself? | TORQUERULES | 2010 MS3 - ECU Computer Tuning | 12 | 03-19-2016 01:07 AM |
| Going bigger FMIC core to support bigger power | KCi | 2010 MS3 - Turbo Induction | 9 | 08-06-2015 10:07 AM |
| bigger tip and intake? | cocoleveo7686 | MazdaSpeed 6 - Engine, Transmission & Driveline | 14 | 03-13-2014 05:59 PM |
| Bigger intake/exhaust or new turbo? | KevMS6 | MazdaSpeed 3/6 - Turbo Induction | 19 | 08-22-2013 11:40 PM |
| Video: Fórmula Truck - The bigger they race, the bigger they crash | Haltech | Automotive News | 0 | 08-02-2010 09:50 AM |
