> 2010 MS3 - Big Turbo Builds
Closed Thread
 Old 04-15-2013, 01:25 PM   #1
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Default Build me a BIG Turbo Build for MS3
Wanting to go big turbo instead of waste away money and time performing mods to a k04 powered mzr. I do want some expandability in the future for more HP, but this is a daily driver so anywhere between 350-380whp will completely suffice. I'm open to ideas, but my hope is to retain a majority of the stock look and sound, which I'll list below.
Here are a couple of caveats to the build you must be aware before making recommendations:
1.) Stock exhaust retention. At most I'd be willing to upgrade to a catted DP.
2.) Must work with the CorkSport TMIC as I want to retain the stock shroud (stock is better but not required)
3.) I do not have access to e85 locally. Max is 93
4.) Reliability is paramount. Again, Reliability is of utmost importance.
5.) stock internals and sensors and NO CEL. This car must pass emissions w/o me spending the weekend getting it ready to pass.
some parts I've already purchased:
1.) cobb accessport
2.) denso itv22's
3. CS intake (purchased before deciding to go BT so not necessarily a required use, but if it could be incorporated it would be nice)
anyways. Thanks for your time.
Please do not ask me to donte for answers. I'll donate when I'm ready.
NCspecV81 is offline
The Following 11 Users Say NO Thank You to NCspecV81 For This Un-useful Post:
ANITIX87 (04-15-2013), Easter Bunny (04-15-2013), Fatguy729 (04-15-2013), Hush (04-15-2013), Kyle Undefined (04-15-2013), MADDOG 20/20 (04-15-2013), mazdafreak (04-15-2013), p057 (04-15-2013), Pu Manchu (04-15-2013), Raider (04-15-2013), SofaKingAwesome (04-15-2013)
 Old 04-15-2013, 01:26 PM   #2
sLow6's Avatar
Posts: 503   (View Stats)
sLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the world
Groans: 34
Oh lord reekress this is gonna be bad
But seriously. Edgeautosport.com. Call those guys they will take care of you.
BT Build in process, should have engine running in a couple days.....knock on wood.
sLow6 is offline
The Following 3 Users Say Thank You to sLow6 For This Useful Post:
Kyle Undefined (04-15-2013), Raider (04-15-2013), VulgarKyle (04-18-2013)
 Old 04-15-2013, 01:28 PM   #3
NCspecV81's Avatar
not sure what your first comment eludes to, but that they were on next on my list of contacts.
 Old 04-15-2013, 01:30 PM   #4
StayBroke's Avatar
Posts: 2,075   (View Stats)
Are you in north carolina?
StayBroke is offline
 Old 04-15-2013, 01:31 PM   #5
NCspecV81's Avatar
yes I am.
 Old 04-15-2013, 01:36 PM   #6
lilred's Avatar
Posts: 5,792   (View Stats)
Would you be inclined to use meth?
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
lilred is offline
 Old 04-15-2013, 01:39 PM   #7
NCspecV81's Avatar
tapafuck
I'm not opposed. I'd like to leave that as a last option type deal, but I would definitely do it if required.
 Old 04-15-2013, 01:51 PM   #8
mrshoulders's Avatar
Posts: 652   (View Stats)
mrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the world
Groaned at 86 Times in 51 Posts
I cant believe i am saying this but...
DO SOME FUCKING RESEARCH!!!!!!!!!!!!!!!!!!
2010 Speed3 w/tech
Bolted E85 FREEKTUNE
mrshoulders is offline
The Following 2 Users Say Thank You to mrshoulders For This Useful Post:
Kyle Undefined (04-15-2013), sLow6 (04-15-2013)
 Old 04-15-2013, 01:53 PM   #9
NCspecV81's Avatar
Done some research, but looking for experienced minds for input.
The Following 3 Users Say NO Thank You to NCspecV81 For This Un-useful Post:
Easter Bunny (04-15-2013), Kyle Undefined (04-15-2013), Raider (04-15-2013)
 Old 04-15-2013, 01:58 PM   #10
blah blah blah
Please do not ask me to donate for answers. I'll donate when I'm ready.
Fuck that shit man.
You joined, and obviously skipped reading the welcome PM and the knowledgebase.
So STFU. Stop posting. Start reading. If you did, you would know you need at bare minimum, a fuel pump solution.
Donate.
Raider is offline
Kyle Undefined (04-15-2013), mrshoulders (04-15-2013)
 Old 04-15-2013, 01:59 PM   #11
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Wait, let me get this straight. You have an AP and an intake and think you know what the KO4 is capable of...?
Ahahahahahahahahahahaha.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
The Following 5 Users Say Thank You to CWP_MS3 For This Useful Post:
johnredding (04-15-2013), Kyle Undefined (04-15-2013), mazdafreak (04-15-2013), mrshoulders (04-15-2013), VulgarKyle (04-18-2013)
 Old 04-15-2013, 02:01 PM   #12
You will need WMI to get to that power level regardless of turbo you use (for 380whp). For 350, a GT3071 will do it at lower boost on good 93. The turbos I would consider for this are the BNRS3 or GT(X)3071.
For the BNRS3 you will need an upgraded MAP sensor for the GT30, you may be able to scrape 350whp at 21-21.5psi on the stock MAP sensor on a cooler day.
The GT30 is more obvious than a BNR install due to the larger intake and inlet.
You will need an upgraded HPFP and likely a larger intake than stock.
You will also need to control boost via either the OEM EBCS and a Boost Dial, or a 3 port EBCV.
Lex is offline
zedekias (04-16-2013)
 Old 04-15-2013, 02:03 PM   #13
Theres a reason why i send huge PM's to new users. You failed to read it. Goodluck
Haltech is offline
 Old 04-15-2013, 02:03 PM   #14
But guys, he has IVT22's. I bet SURE told him that is the mod list for success, lol
Raider is offline
Fatguy729 (04-15-2013), Kyle Undefined (04-15-2013), mazdafreak (04-15-2013), VulgarKyle (04-18-2013)
 Old 04-15-2013, 02:16 PM   #15
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Don't buy any more CS parts because @TexanMS3; likes to jizz all over their parts before they're shipped......after blowing everyone over there. Cuz, you know you're better than a group after you learn everything there is to know about the ms3 from a salesman at a parts company.
07 MS3
The original Genpoo Hater
Chimmike is offline
Closed Thread
MX-5 EFR Turbo Build Andy@Killshot Miata - Forced Induction 40 12-28-2011 04:01 PM
Turbo Build UKMPS3MK2 2010 MS3 - Turbo Induction 12 05-10-2011 09:53 AM
Page generated in 0.34769 seconds with 29 queries
