> 2010 MS3 - Big Turbo Builds
Like Tree61Likes
 Old 06-09-2014, 06:44 AM   #81
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Originally Posted by thricestrat View Post
This, makes all the difference.
I would have on hand 2 sets of impact swivels 3/8" and 1/2" (and various extensions). Also, I assume ATP turbo came with new crush washers for oil and coolant lines (2) sizes 8 total, may wanna check just to be sure
Hmmm...not sure on the crush washers...
I'll have to double check tonight, but I don't beleive it did. Can I get these from the dealership?
 Old 06-10-2014, 08:09 AM   #82
Groans: 51
Crush washers Included!
thricestrat likes this.
 Old 06-10-2014, 03:57 PM   #83
Groans: 51
How exciting.
 Old 06-10-2014, 04:11 PM   #84
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I wouldn't use that.
Standard coolant.
70% water 30% coolant in summer.
50/50 winter.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-10-2014, 04:35 PM   #85
Groans: 51
Standard coolant.
50/50 winter.
Why is that? This is supposed to be oe replacement.
 Old 06-11-2014, 01:19 PM   #86
Sebs6's Avatar
Posts: 201   (View Stats)
Sebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the worldSebs6 is the leader of the world
I was looking thru ur thread very cool man. I'm going to be running a similar set up. uploadfromtaptalk1402514249567.jpg
Sebs6 is offline   Reply With Quote
 Old 06-11-2014, 08:11 PM   #87
Tokay444's Avatar
Groans: 793
I realize now that you're just topping up. If you have fl22 in the system, then I guess you're stuck.
When it comes time for a full system flush, don't waste the money.
MazdaBoy2.3 likes this.
Demodded.
The Seals
MazdaBoy2.3 (06-12-2014)
 Old 06-12-2014, 07:34 AM   #88
Groans: 51
Thanks brock.
Originally Posted by Sebs6 View Post
I was looking thru ur thread very cool man. I'm going to be running a similar set up. Attachment 163077
I know. I told you to hop on that deal! ;-)
Last edited by MazdaBoy2.3; 06-12-2014 at 07:34 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to MazdaBoy2.3 For This Useful Post:
Sebs6 (06-12-2014)
 Old 06-12-2014, 07:36 AM   #89
Sebs6's Avatar
Thanks brock.
Oh fuck didn't realize it was u. Face palm.
The Following User Says Thank You to Sebs6 For This Useful Post:
 Old 06-12-2014, 07:43 AM   #90
Groans: 51
INSTALL IS 2 DAYS AWAY!!!!!!!!
@smoogs12; - all that quick work from you and now it's been sitting for a month. Sorry!
The Following 2 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
Jester2552 (06-12-2014), smoogs12 (06-12-2014)
 Old 06-12-2014, 07:57 AM   #91
Groans: 51
Performed a ghetto test of the wastegate with my bike pump (reads 0-120psi). The arm seemed to move every time right below 15 psi. Probably do a more official one tonight with a boost gauge T'd into the line.
 Old 06-12-2014, 08:27 AM   #92
alextheguineapig's Avatar
Posts: 827   (View Stats)
There's a pump you can buy at HF for 10 bucks that plugs into the cig outlet. I'm going to buy one for a boost leak test on my car, I can't figure out where my leak is coming from. Bike pump is super ghetto
Edit: I don't know what the pressure on that pump is!
Current
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
Damond Motorsports: RMM
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 06-12-2014, 08:48 AM   #93
Groans: 51
It may be super ghetto but in theory it's doing exactly the same as a hand pump. I do have an electric pump that tops out at 30psi maybe I'll give that a try too.
alextheguineapig likes this.
 Old 06-12-2014, 07:47 PM   #94
Groans: 51
Wastegate test.
 Old 06-13-2014, 04:26 PM   #95
Groans: 51
Won't be on day of install.
But it's in the mail.
File Type: jpeg received_m_mid_1402659961454_a89edf6585acc75608_1.jpeg (96.8 KB, 33 views)
 Old 06-15-2014, 03:22 PM   #96
Tokay444's Avatar
Groans: 793
So, how is?
Demodded.
The Seals
 Old 06-17-2014, 06:32 AM   #97
Groans: 51
So, how is?
It's in, but having issues with the return line.
Apparently this is not designed for the stock dp...
 Old 06-17-2014, 07:42 AM   #98
Groans: 51
So, how is?
Rob found this. Should help with the angle.
Turbo Oil Drain Flange Angled , Billet Aluminum CNC Made, AN10:Amazon:AutomotiveTurbo Oil Drain Flange Angled , Billet Aluminum CNC Made, AN10:Amazon:Automotive
 Old 06-17-2014, 10:31 AM   #99
Tokay444's Avatar
Groans: 793
How did you manage turbo, and stay stock dp?
Demodded.
The Seals
 Old 06-17-2014, 11:23 AM   #100
Groans: 51
With all the whispers of creep on the Internal wastegate ATP turbos, I decided a little extra protection from the stock cat/dp would be a good idea. I'm also only targeting 350 hp so I should be able reach that without upgrading. Sent a batch of logs to @rfinkle2; and all seemed good, so it appears to be working.
ItsNox (06-19-2014), lilred (06-17-2014)
 Old 06-20-2014, 11:52 AM   #101
Groans: 51
This came in the mail yesterday, and the adapter that hopefully gives me the clearance I need for my oil line is sitting in my mailbox atm!
The Following 3 Users Say Thank You to MazdaBoy2.3 For This Useful Post:
ItsNox (06-20-2014), JgamB (06-20-2014), tbcota25 (06-20-2014)
 Old 06-20-2014, 06:29 PM   #102
Groans: 51
Fail....
Looks like it's down another few days...
 Old 06-20-2014, 06:32 PM   #103
Fail....
What was the adapter for?
Current
SOLD!
BNR: S3 V2
Cobb: V3 AccessPort
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 06-20-2014, 07:19 PM   #104
Groans: 51
For the block. I was hoping the angle would help but this was clearly the wrong size. Looked so promising too!
 Old 06-20-2014, 08:02 PM   #105
Damn that sucks sorry. Maybe grab a catless eBay dp for now and just clear the cel? Might be the cheapest and fastest way to get you going again.
Current
SOLD!
BNR: S3 V2
Cobb: V3 AccessPort
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 06-20-2014, 08:15 PM   #106
PoweredByDeez's Avatar
Posts: 42   (View Stats)
PoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to beholdPoweredByDeez is a splendid one to behold
Groaned at 3 Times in 1 Post
Wow, that escalated. lol
2008 Mazdaspeed 3 GT Metropolitan Grey Mica
RPF-1 17x9 +45 rear +37 front 245/45/17 BF Goodrich, CP-E 3.25 Intake and TIP, 3" HKS Exhaust with Catless 3" DP, AutoTech HPFP, TR8 FMIC w/ JBR Underside piping, GT3071 w/ Tial 44mm EWG and XS Exhaust Manifold, Overspeed Built engine, AEM Meth kit, JBR ECBS, JBR EGR DEL, Damond OCC, JBR TMM & PMM w/ CP-E Stage 2 RMM, AP V3, HKS VTA,
2008 Mazdaspeed 3 GT Metropolitan Grey Mica Total Loss
2006 Mazdaspeed 6 GT- Total Loss.
PoweredByDeez is offline   Reply With Quote
 Old 06-20-2014, 08:18 PM   #107
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Fail....
Elongate the holes, and bolt it on.
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
ItsNox (06-21-2014), Tokay444 (06-21-2014)
 Old 06-21-2014, 09:25 PM   #108
Groans: 51
Got it together!
Heat tape looks like shit. But I think a smart add.
kritz likes this.
kritz (06-26-2014), tbcota25 (06-21-2014)
 Old 06-22-2014, 08:50 AM   #109
Groans: 51
Here are some early virtual dynos for my progress.
Was doing 3rd gear early on, but switched to 4th for the latest revision.
rfinkle2 and kritz like this.
 Old 06-22-2014, 09:18 AM   #110
Looks like it's coming along nicely. Im very interested in what your final 93 results will be.
Current
SOLD!
BNR: S3 V2
Cobb: V3 AccessPort
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 06-25-2014, 09:34 AM   #111
Groans: 51
Another log/revision, another 10 hp. Should be at 300+ with the next revision and then it's on to e85! Note: the 93 is just the dd tune, we aren't trying to push it crazy hard. Still on stock dp and 2.25" intake!
JgamB (06-25-2014)
 Old 06-25-2014, 10:09 AM   #112
twenty5psi's Avatar
Posts: 213   (View Stats)
twenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the world
Not bad considering that turbo is choked with that intake/stock dp.
2013 MS3 VRM w/Tech
-unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings
FlowTuned 2 Gallon E85 blend 307whp/336wtq
twenty5psi is offline   Reply With Quote
The Following User Says Thank You to twenty5psi For This Useful Post:
MazdaBoy2.3 (06-25-2014)
 Old 06-25-2014, 10:13 AM   #113
Groans: 51
The htp will be going on soon. This is more of a test than anything to see what we will be able to open up with the 3"intake.
kritz (06-26-2014), tbcota25 (06-25-2014)
 Old 06-25-2014, 10:44 AM   #114
I don't know that is the case tbh. The intake may be a small bottleneck, but there is sufficient data @ power levels < 350 that the stock DP actually performs better than many aftermarket DP's.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
JgamB (06-25-2014), kritz (06-26-2014), MazdaBoy2.3 (06-25-2014), tbcota25 (06-25-2014), twenty5psi (06-25-2014)
 Old 06-25-2014, 12:54 PM   #115
twenty5psi's Avatar
Fair enough on the DP; it doesn't seem to have a huge effect(if any) at lower power levels. That 2871 has a 4" inlet if I'm not mistaken, that's a big drop down right in front of it to 2.25", probably not huge either but I hope he can pull a bit more power out of it on 93.
2013 MS3 VRM w/Tech
rfinkle2 (06-25-2014)
 Old 06-25-2014, 01:36 PM   #116
ImGryssLOL's Avatar
Posts: 783   (View Stats)
ImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the world
I'm looking for a "BLT" myself so I'm very interested to see how it turns out with proper tuning, good luck
2013 CWP W/ Tech" LS/VTEC swap running 9's
ImGryssLOL is offline   Reply With Quote
 Old 06-25-2014, 02:16 PM   #117
I agree that a larger intake would stress the turbo less. The Garrett inlet designs are funny that way.
The 4" OD of the inlet is actually kind of a fake out, given the actual intake inlet is not much bigger than the compressor wheel.
Completely agree with you that this system could breath better, but we are trying to squeeze the goal out of minimal mods for a challenge.
kritz likes this.
donjohnk (06-25-2014), JgamB (06-25-2014), kritz (06-25-2014), twenty5psi (06-25-2014)
 Old 06-25-2014, 02:17 PM   #118
Groans: 51
Up to this point i have been very happy with my results. On pump gas my k04 I was struggling to hit 275hp (i blame it on crummy gas in my area). So this turbo is clearly working well.
kritz likes this.
 Old 06-25-2014, 06:12 PM   #119
I know you guys aren't trying to push this little guy hard, but I would be really interested to see how far you can get on a safe but aggressive 93 tune. When will the 3 inch intake be going in? Our mods will be very similar so I'm especially curious! Is there a target for the 93 tune?
Current
SOLD!
BNR: S3 V2
Cobb: V3 AccessPort
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 06-25-2014, 06:21 PM   #120
Groans: 51
I'll have to defer to Rob @rfinkle2; on what he thinks is left in it.
Initial goal was 300 though.
Matt
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f540/mazdaboy2-3-s-gt2871-build-170081/
GTX2867r part-out - Page 2 - Mazda 3 Quebec This thread Refback 07-27-2014 03:55 PM
gt2871 best $? myfirstturbo MazdaSpeed 3/6 - Turbo Induction 4 06-04-2013 07:10 PM
Reworked K04 or GT2871 manofhonor24 MazdaSpeed 3/6 - Turbo Induction 76 09-23-2009 05:41 PM
Page generated in 0.60091 seconds with 29 queries
