| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
4Likes ![]() |
![]() Join Date: Jul 2017 Location: Houston
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Only thing is I’m not really sure what to put in there. I am going to buy a Kozmic vented catch can kit but I’m not sure if I need a new PCV plate as well or a breather cap, etc. I have a new PCV valve ready to go in as I’m sure it’s either clogged or broken, but I’m not sure if that will fix the crankcase pressure. I don’t really understand how all the plumbing works and if I even need a PCV valve after the catch can install, or if the catch can replaces the PCV valve entirely. Any help, need some guidance. |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Not Ranked : 0 score Yes, you need a PCV valve, even after a catch can install. You dont need a vented catch can either. Sealed catch can with a check valve between Intake manifold and catch can is a good place to start. |
Groans: 106
| Not Ranked : 0 score Yes. You just interrupt the hose exiting the PCV valve and route it to the CC, the CV, then back to the IM like normal. |
| Not Ranked : 0 score A sealed can between the PCV plate and intake manifold does NOTHING to vent crankcase pressure in when in boost unless it's connected to the turbo inlet pipe.
(Thread Starter) | Not Ranked : 0 score So how would I route a vented catch can? From the PCV to the can then to the intake? Or back into the manifold? |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Go with a Damond Motorsports dual catch can setup with a stock PCV (new) and you'll be golden.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
Running an oil restrictor bolt as a first resort may have starved my S4 of oil causing slight damage, because even to this day with a dual vented catch can setup, and sp63 oil breather cap, my S4 still smokes, but not nearly as bad as when I had no crankcase pressure relief. Many have mentioned that running an oil restrictor bolt on journal bearing turbos is not a good idea. Start with CC pressure relief first. The simplest setup would be to try a Gen 2 VC with SP63 oil breather cap
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) | |
I have a Gen 2 lol, what I’m going to do is have a single vented catch can with two ports, one for the valve cover breather and one for the PCV. Then plug off the intake manifold port and the inlet pipe port. That should bring my crank case pressure way down and completely eliminate the possibility of oil getting into my intake. What I think is happening is because I’m running so much boost it shuts the PCV valve closed and builds crank case pressure, forcing oil out through the valve cover breather and into my intake. | |
| Not Ranked : 0 score Your going to put a can between your valve cover and PCV valve?
(Thread Starter) | Not Ranked : 0 score A vented can yes. They both emit crankcase pressure so leading them to a vent to atmosphere can seems like a wise idea. I know a sealed can pulls pressure from vacuum but my priority is to rid the oil and vapors from my intake. I guarantee it will still have lower crankcase pressures than the stock PCV system. I don’t even have a vented oil cap. |
| Not Ranked : 0 score I think your going to create more problems with that setup.
| Not Ranked : 0 score Sealing the manifold port & TIP port and plumbing the VC & PCV plate to a single VTA OCC won't be a problem. Bonus, you won't need any restrictive check valves.
In regards to your PCV considerations, I think keeping both the valve cover and intake manifold vacuum sources in place will benefit much more at both part throttle and wide open throttle. If you remove the oil cap with the engine idling, you can feel quite a bit of pressure (although this may all be in my head as I haven't actually measured CC pressure). Now imagine removing all the vacuum sources :/ This is the setup I run. I've done some editing in paint to show my exact setup. It's quite over kill in most cases, but this was when I was trying everything I could to stop my S4 from smoking, and found that running an oil restrictor bolt may have been the first mistake that prolonged issue. Custom PCV_route_4_grande.png The reason why I like this setup is because there are several places for pressure to vent and it retains all OEM style vacuum sources on the crankcase. But the real kicker is that during WOT, the inlet pipe pulls a strong vacuum the crankcase through the can on the right side.
| Not Ranked : 0 score I don't have a catch can between my VC and TIP. I used to and it never had oil in it, so I took it out. Figured if it's not catching anything then all that extra tubing and a baffled catch can is hurting flow. The other catch can drawn above is how mine is plumbed, except I don't use the PCV valve. I put a cap over the PCV and hooked the OCC hose to the center port. This provides a wide open/unrestricted flow to the VTA catch can, although it still has to flow through another restrictive check valve to vent out. Gen2 VC would be nice to have in order to use the VTA oil fill cap/breather.
Groans: 60
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
| Not Ranked : 0 score I don't see any leak potential.
I'm wondering if using just a check valve without the PCV valve actually pulls more vacuum on the crankcase due to potentially less restriction, and if it might correct my smoking turbo issue. Sorry to thread jack, but it's PCV related so I'll continue ![]() With my over kill PCV setup posted above, WOT pulls don't look to be smoking nearly as bad as they used to. I'm not sure if running the restrictor bolt for quite a while caused damage to the turbo or not, but with this over kill PCV setup switching back to the stock oil feed bolt seems to have reduced the smoking. I've noticed that the smoking issue seems worse during mid to high rpm deceleration, whether I go into boost or not, I will see quite a bit of blueish white smoke out the tailpipe in my rear view. I can get it to happen easily by slowly bringing the rpm up to about 5k, and then letting off the gas. As soon as it starts decelerating, about 2 seconds go by, and then smoke starts trailing out behind me for a few seconds before it dissipates. I will say that although this turbo is a great value and performs well, I have been spending quite a bit of time and money trying to totally stop it from smoking. I'm almost at the point of accepting the fact that I will just have to carry around a 5 liter jug of Rotella T6 for top up's lol, or send it out to BNR to get rebuilt/inspected and hope it doesn't smoke after that. My guess as to why this is happening during deceleration is simply because I have a full 3" catless high flow turboback exhaust. During deceleration the injectors turn off, causing only air to be pumped through the engine. Without sufficient back pressure from combustion in the downpipe, a potential venturi effect from only air flowing through might be pulling oil past the turbine seal causing it to burn up. Many other internet sources have suggested valve seals, but I doubt it since the car doesn't have any other smoking issues other than in he circumstances of deceleration and WOT pulls. I'm thinking that maybe by using just a check valve instead of the PCV valve, a stronger vacuum can be pulled on the turbos oil drain that might over come the strength of that potential venturi effect in the exhaust during deceleration.
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 11-07-2018 at 07:38 PM. | |
| Not Ranked : 0 score Yes, still using check valve at the intake manifold...which makes the PCV valve redundant and an unnecessary restriction.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | BuddySpeed3 (11-07-2018) |
Thanks man I might have to try this out and hope it stops my smoking during deceleration. What did you use to cap off the PCV valve?
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 11-07-2018 at 07:33 PM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score Generic nipple cap. It came in an assortment pack from Advance Auto.
| Not Ranked : 0 score Ouuu my favorite kind of cap, Thanks man!
![]() Join Date: Mar 2018 Location: Orange County CA
Rep Power: 0 ![]() ![]() Thanks: 4
__________________ 06 Speed6 AP V3| CS TIP/SRI |CS 50/50 BPV |CS Test Pipe |CS FP internals|CS high pressure SS fuel line |CPE EGR delete |CPE TMIC |JBR Boost Tubes |JBR Trilogy race mounts |JBR short shift kit |Grimmspeed EBCS |GA V3|Custom FREEK tune | |
| The Following User Says Thank You to Ds_06_Speed6 For This Useful Post: | BuddySpeed3 (11-09-2018) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Do u notice any negative side effects with this setup?
![]() | | #25 | ![]() |
| Not Ranked : 0 score No
| The Following User Says Thank You to Fstrnyou For This Useful Post: | BuddySpeed3 (11-09-2018) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Hararious.
| Salt questions and carpet questions | ikyn | Gen2 MS3 General Discussion | 33 | 03-14-2016 10:56 AM |
| Used questions | Jonb82 | Gen2 MS3 General Discussion | 46 | 08-31-2015 10:19 AM |
| Looking to buy a new MS3, few questions first | woodfloor | Gen2 MS3 General Discussion | 82 | 09-10-2012 09:19 AM |
