![]() Join Date: Dec 2016 Location: DFW, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
![]() Join Date: Apr 2011 Location: HOFFMAN ESTATES IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Worse case scenario go to the dealer, sometimes we have no choice ![]() Sent from my SM-G900P using Tapatalk |
![]() Join Date: Nov 2016
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Is it throwing any codes... It may be a faulty abs sensor or the dreaded module fail Sent from my E6653 using Tapatalk |
| Not Ranked : 0 score Only had an issue once with the abs and traction control light together but Not the E light, so i checked under the front wheels where the brake system is and the wire was loose, I used the soldering tool to put them together and elct tape over it and everything was fine, but sounds like you have more issues also with the brake, not sure about the cable underneath and some other sensor Sent from my SM-G900P using Tapatalk |
![]() Join Date: Aug 2015 Location: Santiago, Chile
| Not Ranked : 0 score Did you check the brake lights? Did you change the incandecent light by led w/o canbus? |
| Neutral : +1 score The abs module fails..... Mines just gone 509 pounds to replace at mazda Sent from my E6653 using Tapatalk http://www.ecutesting.com/mazda_3_ab...le_ate_mk.html Sent from my E6653 using Tapatalk Last edited by wastedrainbow; 12-20-2016 at 06:50 AM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score Well...FWIW, no codes related to this. It`s wet outside so I took it out and forced it to happen, no codes. Hooked up the scanner to run a real time code log, nothing triggered. It only does it when the tires lose forward traction, so I`m going to guess it has to do with whatever controls the traction control. I`ll investigate further, just sharing as I go in the event someone else stumbles across this with the same problem. By the way, it runs perfectly fine while the lights are on. It`s almost like they`re just a reminder saying "hey, you lost traction recently". |
Groans: 438
| Not Ranked : 0 score If you're constantly spinning tires, you might want to look into a driver mod.
__________________ All good things must come to an end... |
Not that I don`t enjoy the occasional burnout, but I wouldn`t say `constantly` is a word I`d use here. It`s happened three times. The first was totally my doing; I was horsing around. The second was a particularly notorious uphill stop sign and damp pavement. I could have probably avoided that one with a bit of elegant clutch work. Then today it was very intentional for the purpose of triggering the lights to come on. It`s again rainy outside and I knew I could break the tires loose in a semi-controlled environment. Keep in mind the car is still relatively new to me. It`s by no means the fastest or most powerful car I`ve owned, but I do get out and push it a little harder up front to see how it behaves and reacts so I know what to expect from `er if god forbid I find myself in a situation where I`ve got to trust the car. | |
![]() Join Date: Oct 2019
| Not Ranked : 0 score Hello! Apologies for resurrecting a fairly old thread, but I just bought a 2010 Speed3 and ran into this exact problem under the exact same circumstances. Just wondering if this was ever sorted out? Similar to OP, I cannot find much other info about this issue online, and am hoping that either OP or someone else with experience with this issue can help point me towards a solution here. Thanks so much in advance! |
| 4WD and Traction control lights on | SpaceOrphan | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 08-21-2014 07:09 PM |
| MS6: Brake, Traction, DSC off & ABS Lights ON | Poohster | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 10-14-2013 08:14 PM |
| engine light & traction control lights HELP | gabegarcia956 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 10-18-2012 10:02 PM |
| can't stop, ABS/Traction Control lights, no cruise control...vacuum leak? | btstarcher | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 06-17-2011 11:06 PM |
| Traction control & brake light coming on | dutchbuffalo | MazdaSpeed 6 - Engine, Transmission & Driveline | 21 | 01-21-2011 07:14 AM |
