![]() Join Date: Jun 2013 Location: Gig Harbor, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
Groaned at 37 Times in 7 Posts
(Thread Starter) | Not Ranked : 0 score Been out to sea and been really busy lately so i haven't had a whole lot of time to do anything with my car. anyways though, i got around to doing the boost leak test today and I had to tighten up quite a bit. Once I got everything tight, I was getting about 20psi and I had air coming out of my crankcase. This was using a pvc cap with tire stem into my turbo inlet pipe. Is this normal and does this mean all my connections are good? |
![]() Join Date: Feb 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score That's not normal. Where exactly was the air coming out?
__________________ - 2008 Gen1 MS3 Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires. Self tuned on E85 |
(Thread Starter) | Not Ranked : 0 score well i thought it was coming out of my oil cap but it was the connection right below it. When I opened up the oil cap, all the pressure released through it. |
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,028
| Not Ranked : 0 score Subbing because the last boost test I did had the same results. Loss of pressure near the sensor below oil cap. Wondering if PCV is shot.
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score Cap the valve cover vent line while testing. or just run the boost leak test from the first hotpipe and not from the intake.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() | |
![]() Join Date: Apr 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
| Not Ranked : 0 score If you do it from the end of your intake (just by removing filter) you need to block where ur intake connects to the valve cover breather or your pressurising ur valve cover and thats why air is leaking out. Sent from my GT-I9300 using Tapatalk
__________________ 2012 Black Mazda 3 MPS ![]() CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC 2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks Versus Eurolace 19 x 8 +45 - Hankook RS3 Built & Tuned by Rob Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18 DBA T3 Rotors - Carbotech XP10 Brake Pads |
| The Following User Says Thank You to ledfootrob For This Useful Post: | doctavus (01-05-2014) |
| Not Ranked : 0 score Yea blah. I didn't do that. I was in a hurry and tired from trouble shooting a leaky BPV.
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | doctavus (01-05-2014) |
| Trying to test for boost leak, could use some help | ChavesB1 | Mazdaspeed3/6 General Discussion | 6 | 03-31-2013 08:11 AM |
| Boost leak test | Laloosh | Mazdaspeed3/6 General Discussion | 17 | 07-06-2008 08:48 AM |
