> Gen2 MS3 General Discussion
Like Tree26Likes
 Old 07-14-2017, 06:48 PM   #1
mrshoulders's Avatar
Posts: 652   (View Stats)
mrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the worldmrshoulders is the leader of the world
Groaned at 86 Times in 51 Posts
Default Catch cans....are they really worth it.
Hey guys have a question, does having a catch can actually add any power via tune? Does it make the engine life last longer? I am at 90k, been tuned by Justin Brasil on e25 since around 25k miles. What would have been different had I got a catch can then.
2010 Speed3 w/tech
Bolted E85 FREEKTUNE
mrshoulders is offline   Reply With Quote
The Following 5 Users Say NO Thank You to mrshoulders For This Un-useful Post:
Easter Bunny (07-19-2017), g00s3y (07-15-2017), JSmith (07-16-2017), sharksinspace (07-19-2017), Vansquish (07-16-2017)
 Old 07-14-2017, 07:24 PM   #2
Jonb82's Avatar
Posts: 416   (View Stats)
Sent while probably pooping
kenny7821 likes this.
The Following 13 Users Say Thank You to Jonb82 For This Useful Post:
5doorsoffury (07-15-2017), Djohns (07-14-2017), Easter Bunny (07-19-2017), g00s3y (07-15-2017), Gnar'd Up (07-16-2017), JSmith (07-14-2017), KiwiFlavor (07-17-2017), monkey.bones.007 (07-14-2017), Pu Manchu (07-16-2017), sharksinspace (07-18-2017), ThOrZwAr (07-18-2017), Vansquish (07-16-2017), xfeejayx (07-14-2017)
 Old 07-14-2017, 09:44 PM   #3
distortion's Avatar
Posts: 66   (View Stats)
distortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud of
No power, should keep intake and such cleaner. Seems like an odd question...?
2011 Black Mica W/Tech Package
Cobb AP|CP-E HPFP|Corksport SRI/TIP|Corksport TMIC|UR Test Pipe|Corksport Cold Air Box|Corksport Rear Sway Bar|JBR Shifter Bushings|Corksport RMM|Techna Fit Stainless Brake Lines|Ultraguage|Stratified E85
distortion is offline   Reply With Quote
 Old 07-14-2017, 09:59 PM   #4
My friebds and I have a discussion if it's worth getting one. So I am just curious on the facts of its purpose
2010 Speed3 w/tech
 Old 07-15-2017, 12:07 AM   #5
Jega's Avatar
Posts: 118   (View Stats)
Jega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud of
Groaned at 39 Times in 10 Posts
https://youtu.be/PWz6vCnJ4CA
2007 Mazdaspeed3
Jega is offline   Reply With Quote
 Old 07-15-2017, 12:08 AM   #6
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
It's speculated that catching the oil vapor instead of allowing it to enter the cylinders prevents it from lowering the effective octane of the fuel/air mixture. The rationale is this: oil vapor, if allowed to burn in the cylinder, will ignite sooner than the fuel/air mix, which can lead to knock.
No idea if this is true or not. However, catch cans absolutely DO have a benefit for DI engines like ours: preventing the oily crud from building up on intake valves over time.
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 07-15-2017, 06:29 AM   #7
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Seems like you need to get new friends.
And with all the threads on OCC's, you had to make a new one to ask for info that has been posted many times before?
Thor Hammer (07-17-2017)
 Old 07-15-2017, 09:03 PM   #8
eliwwjd's Avatar
Posts: 518   (View Stats)
My recommendation is instruct yourself of what is really a oil catch can and its purpose before you post here because you are going to get groaned. It is not a power tuning mod.
It is to filter blow by oil mist and other gunk that could reach your engine intake and affects you from having a clean combustion or cleaner gases into your engine.
Here i a link with some info
Oil Catch Cans | Everything you need to know and more!
All i did was search on google and bam! this link came up. Just trying to help you so next time you don't get groaned
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
The Following User Says Thank You to eliwwjd For This Useful Post:
Jonb82 (07-16-2017)
 Old 07-15-2017, 09:08 PM   #9
Jonb82's Avatar
 Old 07-15-2017, 09:31 PM   #10
NCspecV81's Avatar
Posts: 2,867   (View Stats)
I just ran a hose straight to ground. I didn't run a catch can for the longest time. I'll also be going back to this method as well.
MZRSPEED likes this.
2013 CWP and Stock
 Old 07-16-2017, 12:29 PM   #11
I guess I am looking for quantifiable proof in performance like better gas miliage, hp, or anything. All I see is "emptied a ton of oil from my catch can posts"
2010 Speed3 w/tech
 Old 07-16-2017, 01:39 PM   #12
Jonb82's Avatar
So you are beating a dead horse. I started out making jokes. Now I'm going to be a dick. You have had your car tuned for how long? So either you are a fucking premenstrual-blood-quiff that tunes and upgrades your car with out reading and researching on the what's and whys. Or you are a fucking backwards-incest-having-butt-fucking-ignorant-jenkum-huffing-person. The fact that you just wrote that a "catch can emptied a ton of shit" tells you of what they are catching and not letting back into the engine. I apologize for what you just read. But your wanting to be spoon fed after so long of owning the car has pissed me the fuck off for some reason. Actually I'm not sorry. Use google
Pu Manchu (07-18-2017)
 Old 07-16-2017, 01:52 PM   #13
Neutral  :  -1 score
Lol yet you still can't show me numbers that backs anything up
2010 Speed3 w/tech
The Following 6 Users Say NO Thank You to mrshoulders For This Un-useful Post:
Cataphract_40 (07-16-2017), Easter Bunny (07-19-2017), eliwwjd (07-16-2017), g00s3y (07-17-2017), JSmith (07-16-2017), Vansquish (07-16-2017)
 Old 07-16-2017, 02:28 PM   #14
Groans: 30
Your tone indicates that you already had your mind made up before you even started this thread.
So why did you?
1995 Miata
 Old 07-16-2017, 02:31 PM   #15
Because if it actually shows concrete evidence then I'll get one. Kind of like a tune, you clearly see a difference. Catch can I have yet to see any performance evidence
2010 Speed3 w/tech
 Old 07-16-2017, 03:33 PM   #16
eliwwjd's Avatar
Dude some people here are letting it pass but you are still here are arguing about proof of performance. Plain and simple! don't buy one and call it a day!
Next time take some time to read how an engine functions and its combustion process, before you demand proof of performance, some things are just common sense if you know about the subject.
 Old 07-16-2017, 03:41 PM   #17
Jonb82's Avatar
"But I need numbers" so the reason there are no numbers is because people don't have the time or money to take two cars, run them identical miles with and without a catch can. Then take off the IM and inspect the valves. Common sense, which you are obviously lacking, will tell you the "tons of shit in the catch can" never made it back into the engine. Yes that was a big fucking run on sentence. Don't care. So again pretend you have common sense and put 2+2 together, and realize that a catch can works. If your brain can't handle that, or you have doubts, just shut the fuck up and go on your marry way. Btw I don't know you, and you might be an alright guy. But this post and your reasoning is what I'm attacking. Hope you have a great day.
Last edited by Jonb82; 07-16-2017 at 03:41 PM. Reason: MSF Database - Automerged Doublepost
monkey.bones.007 (07-16-2017)
 Old 07-16-2017, 04:18 PM   #18
Lol not taking anything personal. I guess at the end of the day I am curious if ovee a period of say 60k miles, woukd my car perform any different having a catch can and not. I understand what it does and how it works. But does having that "shit" in the engine affect my auto x times, 1/4 times, roll racing outcome.
2010 Speed3 w/tech
 Old 07-16-2017, 04:39 PM   #19
eliwwjd's Avatar
Dude seriously! you must be joking. Cmon this is like a say we have locally" dude you are looking for a 5th leg on a cat". Seriously don't buy one if it doesn't convince you, Jesus!
 Old 07-16-2017, 04:50 PM   #20
Dude! It's just a discussion, relax. You still can't answer me
2010 Speed3 w/tech
 Old 07-16-2017, 05:02 PM   #21
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Don't buy one and be the guinea pig. Our job is not to provide you with proof or evidence something works or doesn't. Pleasant regards and have a nice day.
crapatalk it sucks for free
Jonb82 likes this.
 Old 07-16-2017, 06:05 PM   #22
eliwwjd's Avatar
Oh im relax, what surprises me is how you change things around now by saying its just a discussion when on the first post you are asking a very noobish question that you should of read first and now are arguing. Question is already been answered, the problem is that your brain is not capable of understanding or simple, you are on total denial of what has been informed to you and want proof of something that is common sense. For the last time , don't buy one and have piece of mind since you do not have proof. Have a wonderful evening and have peace in your mind.
willbeblack likes this.
 Old 07-16-2017, 07:33 PM   #23
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
You were a faggot back im the day and im glad to see you haven't changed.
Better to remain silent and be thought a fag than to speak and remove all doubt. Thankyou for speaking.
Also fuck photobucket.
MECP
2012 BM
Rfinkle tune in progress
The Following 3 Users Say Thank You to 5doorsoffury For This Useful Post:
Easter Bunny (07-19-2017), monkey.bones.007 (07-16-2017), sharksinspace (07-19-2017)
 Old 07-16-2017, 07:47 PM   #24
Lol
2010 Speed3 w/tech
The Following 4 Users Say NO Thank You to mrshoulders For This Un-useful Post:
Easter Bunny (07-19-2017), g00s3y (07-17-2017), JSmith (07-16-2017), sharksinspace (07-19-2017)
 Old 07-16-2017, 07:49 PM   #25
Jonb82's Avatar
Lol
Can we please ban this guy?!
Last edited by Jonb82; 07-16-2017 at 07:49 PM. Reason: MSF Database - Automerged Doublepost
JSmith (07-16-2017)
 Old 07-16-2017, 08:00 PM   #26
Ok so still no real answers. Gotcha
2010 Speed3 w/tech
 Old 07-16-2017, 08:17 PM   #27
Yup, nothing to see here at all. Just keep hipstering on.
willbeblack (07-16-2017)
 Old 07-16-2017, 08:31 PM   #28
tmillner's Avatar
Posts: 621   (View Stats)
I'll play along. You will be leaving performance on the table not having one over a period of time. I went a good 70k without one with a good 20k of that on a bnrs4 turbo on e85. Valves looked pretty bad when engine was torn apart. Wish I ran one earlier.
Just my opinion
Sent from my SM-G935P using Tapatalk
ss_1777 likes this.
 Old 07-16-2017, 08:36 PM   #29
Just my opinion
Thank you for a sensible answer.
ss_1777 likes this.
2010 Speed3 w/tech
 Old 07-17-2017, 06:53 AM   #30
g00s3y's Avatar
Groans: 438
OP is clearly the type who complained about having to buy HPFP internals "because it doesn't increase HP"...
fucking idiot
The Following 3 Users Say Thank You to g00s3y For This Useful Post:
Easter Bunny (07-19-2017), sharksinspace (07-18-2017), ThOrZwAr (07-18-2017)
 Old 07-17-2017, 07:06 AM   #31
speed23's Avatar
Posts: 1,480   (View Stats)
IIRC, cobb reported they were able to run more timing after cleaning intake valves. Catch can keeps valves cleaner. Not going to try to find thread, but it was a fact. That said, I bought a catch can, installed and then uninstalled due to cold weather issues, so not a big catch can proponent - at least in cold climates.
 Old 07-18-2017, 08:56 AM   #32
ABOSWORTH's Avatar
Posts: 467   (View Stats)
Yeah, I've read about cold weather issues as well, which has me very hesitant to install one. I'm in Vermont and it gets pretty cold here. I don't want to have to worry about it in the winter so I just haven't bothered with it. Definitely need to clean my valves soon though. I'm at 78k and have not done this yet. :
Current Mods
 Old 07-18-2017, 11:13 AM   #33
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
OP has AIDS.
Genpoo stuff
 Old 07-18-2017, 11:55 AM   #34
Carskick's Avatar
Posts: 315   (View Stats)
Carskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond repute
Against my better judgement, I'll participate.
I have gone back and forth on the catch can. I still don't have one, but I do plan on one eventually. As other's have said, it's a preventative to keep the intake valves & tract clean. That's really it. I've talked to people with MS3s with over 160k miles who have never even cleaned the intake valves and have no OCC.
The dealer chemically cleaned my valves at 60k, I'm currently at 78k. At some point, I'll need a clutch. When that happens, I'll probably have Mazda Medic in Tampa do a bunch of stuff at once, including clutch, manual intake valve cleaning, install catch can, any other valve-train work needed, and possibly Fuel Injector seals. As of now, my dirty valves don't seem to be causing any trouble, so I'll leave it at that for now.
Remember, not every engine mod directly adds power, but cleaner valves will flow better and an OCC should theoretically keep them cleaner longer, preventing power loss. If you take apart your engine every 10k to clean out everything, you probably don't need an OCC. If your valves are already all gunked up, an OCC may not provide much benefit since the "damage" is already done.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Carskick is offline   Reply With Quote
 Old 07-18-2017, 02:54 PM   #35
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
Mrs Houlders, 80% of your mods don't increase power, they just facilitate, now stop being a faggot and fuck off.
Jonb82 likes this.
94 M
MS6
IS350
The Following 2 Users Say Thank You to Pu Manchu For This Useful Post:
 Old 07-18-2017, 06:28 PM   #36
Ok so if I don't clean valves and install catch can I will have some loss of power correct? My question is how has this not been tested and tanginably proven?
2010 Speed3 w/tech
The Following User Says NO Thank You to mrshoulders For This Un-useful Post:
 Old 07-18-2017, 06:35 PM   #37
Groans: 126
Feel free to buy a second car for comparison, clean both sets of valves to a base starting point, install a can on one of them and then run both to 100k miles in order to perform whatever arbitrary buttfucking performance tests you're so hung up on seeing the results of. Or if common sense isn't enough to tell you that carbon buildup in the engine is bad, just go ahead and keep running without an occ.
Genpoo stuff
 Old 07-18-2017, 06:43 PM   #38
So what you're saying is there is no actual evidence of power loss or gain correct?
2010 Speed3 w/tech
 Old 07-18-2017, 06:52 PM   #39
Groans: 126
I've never bothered to look for a quantifiable POWER gain because it doesn't take a rocket scientist to know that valves that are sticky, or that won't fully seal, because of buildup will have a detrimental effect on driveability.
What oil do you run? Rotella? PP? Mobil 1? Royal Purple? Or just the cheapest shit you can find at Walmart because it doesn't give you a measurable power gain? You are coming at this from the wrong angle.
Genpoo stuff
ThOrZwAr (07-19-2017)
 Old 07-18-2017, 06:59 PM   #40
I use pp, but see that doesn't require me to pay extra and no headaches (to empty) out all the time. It's just kind of crazy there isn't actually tests done or something to show power loss/gain.
2010 Speed3 w/tech
Catch cans in winter riflex Mazdaspeed3/6 General Discussion 2 05-05-2016 04:59 AM
While looking for 'cheap' oil catch cans... Yatta Gen2 MS3 General Discussion 3 11-07-2012 12:41 AM
oil catch cans nick779 Gen2 MS3 General Discussion 24 04-05-2011 03:34 PM
Catch cans Special--k 2010 MS3 - Engine, Transmission & Driveline 5 06-22-2010 09:00 PM
Page generated in 0.58037 seconds with 36 queries
