> Gen2 MS3 General Discussion
Like Tree4Likes
  • 1 Post By tc0308
  • 2 Post By GODspeed7
  • 1 Post By tc0308
 Old 02-28-2013, 06:26 PM   #1
tc0308's Avatar
Posts: 95   (View Stats)
tc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond reputetc0308 has a reputation beyond repute
Default Cobb AP "stock" tune Turbo PSI
Hey Everyone,
While waiting for my JBR SRI to arrive I decided to load the 91 safe stock tune to see what it is like. I must say, the throttle response is EXTREMELY improved. I felt like I was in a totally different car. I didn't notice too much of a difference in power, but I wasn't expecting anything radical since it was the safe tune. With this run, I really just wanted to see how to datalog with the device.
One thing I did notice while data logging was that I reached max boost of ~12.5psi at 4400rpm and tapered off at ~10-11psi at about 5500-6k.
Does anyone know if this is how the car is supposed to respond? I thought the car stock was supposed to be able to reach 15psi. Could this mean I have a leak or crappy turbo? Attached is a datalog of the run.
As this is my first time running a log, I am also very interested in if my Fuel pressure and any knock that registered. It seems that at WOT the fuel keeps up, and doesn't go below 1500, so I think I am safe. I am however, not too sure about when I am coasting and not on the throttle. Is it ok for it to dip a lot lower than that? I'm guessing it is ok since there is no need for a lot of fuel. As soon as I do hit the gas it responds immediately .
During the run I noticed a few instances of knock. While none of these values are above 1.0, I am still concerned that anything is registering on this "safe" tune.
Any help would be greatly appreciated. I've attached the run incase anyone is interested in taking a look.
The JBR SRI/TIP actually arrived today, and I plan on installing it along with the stratifed tune this weekend. However the slight knock that showed up in addition the lack of turbo boost has me a little worried.
SaveMelMac likes this.
CWP 2012 MS3
JBR SRI/TIP // Cobb AP // Autotech internals // CP-E Stage 2 RMM // CS racepipe (still in box)
tc0308 is offline   Reply With Quote
 Old 02-28-2013, 06:39 PM   #2
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Stop! Seriously man just stop. You need to READ MORE. Don't just pull the AP out and start flashing maps. While you did go the safe route and flash the 91 safe mode, you don't know why you flashed it and don't know what to expect.
The safe map does target less boost.
The map is designed to taper boost at redline.
Knock below 2* is nothing to worry about. Addressed, yes but not worry.
With the car in idle rev the gas and watch the fuel pressure. That is what is normal. Around 400psi at idle and up to sometimes 1900psi at WOT is all normal depending on how much gas you are giving it.
Only be worried if you see below 1600psi at WOT.
READ Abilors tuning guide, bucker's ATR cheat sheet, Lex's knock retard explained and Dano's boost tuning. When you are done reading those, read them again. And again.
Your asshole and engine are a little safer now!
Happy reading!
Tapatalk LIKE A BOSS!
Kdawg207 and acey like this.
2012 Mazdaspeed3 Black Mica
 Old 02-28-2013, 06:52 PM   #3
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Kdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the world
What he said
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 02-28-2013, 07:04 PM   #4
tc0308's Avatar
Will do; thanks for the thread topics. I'll make sure to throughly read them multiple times. The low boost kind of threw me for a loop. I know it is supposed to taper to readline, but I thought it at least would hit a little closer to 15psi and then taper.... oh well
CWP 2012 MS3
 Old 02-28-2013, 07:12 PM   #5
GODspeed7's Avatar
It will but not on a "safe" map. The stock tune is load limited so that's why you will see the stock boost gauge lose a bar sometimes. The stratified map that comes with the intake will most likely address all your problems and concerns.
 Old 03-01-2013, 02:28 PM   #6
Speed3in215's Avatar
Posts: 459   (View Stats)
Speed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond repute
at least you bought a AP as your first mod. Next is to donate , read read and read!!!
2012 Mazdaspeed3~~Cobb AP~Corksport SRI+Tip~CNT cbe~JBR Red Spherical Knob~JBR SSP w/bushings~Autotech Internals ~ JBR 88 duro RMM~ Ultimate Racing Race Pipe ~Ultimate racing catless downpipe ~ forge v1 BPV~ denso ivt22 one step colder plugs~Rokblokz mud flaps
Freek tuned on 93 pump gas
Virtual Dyno - 3rd gear 285whp 326tq
4th gear 270whp 352tq
Speed3in215 is offline   Reply With Quote
 Old 03-01-2013, 02:38 PM   #7
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
To do a log only do a WOT run. start the log at 2500-3000 rpm and floor it until redline then stop logging.
The knock retard you are seeing is partial throttle knock...completely normal.
1996 Miata
 Old 03-01-2013, 05:33 PM   #8
tc0308's Avatar
Awesome; thanks everyone for their advise. I'll definitely make sure to donate next paycheck. I just purchased the AP and JBR SRI/TIP, so I am a little strapped for cash. Next logs I run I'll make sure to only do WOT.
Happy weekend everyone!
jdm_dudebro likes this.
CWP 2012 MS3
The Following User Says Thank You to tc0308 For This Useful Post:
CWP_MS3 (03-04-2013)
 Old 03-01-2013, 06:08 PM   #9
GODspeed7's Avatar
Donating also gets you access to the for sale section which will save you hundreds if not thousands over time as well as the service and maintenance manuals which are worth WELL over $25 and access to all the nudes provided by fellow members and even nudes of fellow members both male and female depending on what you are into.
 Old 03-07-2013, 12:56 PM   #10
oakley990099's Avatar
Posts: 246   (View Stats)
oakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the worldoakley990099 is the leader of the world
Thank god for search.. Needed the same kind of info actually now I can just read up on those articles . Mostly iffy about even putting a tune into my car at all with a stock fuel pump. Wish I could get it sooner
oakley990099 is offline   Reply With Quote
 Old 03-07-2013, 05:09 PM   #11
tc0308's Avatar
Yea, I'm glad I wrote this post... I've been reading like crazy lately!!!!
CWP 2012 MS3
Can I "Tune" my stock MS3? Speedee3 MazdaSpeed 3/6 - ECU Computer Tuning 16 03-08-2010 09:40 PM
Page generated in 0.33929 seconds with 26 queries
