![]() Join Date: Nov 2010 Location: Westminster, CO.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 66
(Thread Starter) | Not Ranked : 0 score I haven't been able to fix the issue with my A/C, so I need to take it in. I really don't trust some run down mechanic shop, and performance shops won't deal with it (not performance related, pfft). I want to resort to the dealer, but am extremely nervous about them seeing my car since I'm BT. I don't mind paying for repairs, but don't want them doing anything sketchy so that later when I stock out the car and I take it in for warranty work they deny it based on previous "history". Any advice, recommendations, etc.? Thanks fellas
__________________ 2010 Mazdaspeed3 - Garrett GT3076R Turbo, SteedSpeed Manifold, Tial 38mm External Wastegate w/ Dump Tube, ATP Big MAF Housing, ATP 3" TIP/Intake, HKS SSQV BOV, Ultimate Racing FMIC, Ultimate Racing Catless DP, CS Test pipe, CS Catback Exhaust, Autotech HPFP Internals, Hallman Pro Boost Controller, Cobb AccessPORT, BC Coilovers, DDM 8000k HID's, Red Brake Calipers w/ Decals, Custom Smoked Headlights, Smoked Taillights, 18% Window Tint. 2011 Mazda2 Sport - OEM Fog Lights, OEM Touring Rear Spoiler, Sport Edition F2 Silver Wheels, Green Brake Calipers, 18% Window Tint, Social Engineering - Because there is no patch for human stupidity. |
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
| Not Ranked : 0 score Hey, why don't you try to go to a A/C shop (not sure if this is the right english term for this), but they may be some companies just specialized doing car A/C's. I guess it'll be your best bet for now before throwing your self to the dealership. Good luck....
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. |
![]() Join Date: Jan 2011 Location: Vero Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
Groaned at 50 Times in 30 Posts
| Not Ranked : 0 score Get some local reviews. Sometimes the "run down" shops are actually the best in the business. Don't discount a mechanic because his shop has been around a while and isn't state of the art. Chances are he's been in business long for a reason. As bertrand said, check for HVAC shops too. A lot of times some shops specialize in it. Your dealership will rip you a new one for A/C repair if you've even touched one A/C component with your BT install/setup. Don't always trust the dealership to be the best bet working on your car anyway, just because they work for a Mazda dealership doesn't mean they know their way around your Mazda better than anyone else. Ace_Protege here on MSF works at a Honda dealership, he didn't know shit about them before they hired him. Any reputable shop will have access to a database that includes the shop manual information and will be able to work on your car as efficiently as your dealership.
__________________ '12 Ford Focus SEL |
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
| Not Ranked : 0 score I don't think a dealership will over look a fully bolted bt ms3. They will most likely blame the mods
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 546
| Not Ranked : 0 score 1. Your BT setup has nothing to do with the A/C system HOWEVER (and I dont know your specific issue) 2. In the process of doing your installs you might have nicked a line, hit the condenser, etc etc. R134a is colorless so you wouldnt really see any leaks. That was what they could deny a warranty claim for. You can deny any further work of course if it isnt under warranty, sans the initial diag fee for figuring out whats wrong in the first place. But being realistic, is it Mazdas fault you hit something in your a/c system? And even if you stock out and go in for engine related warranty work, why should the mazda foot the bill for the car youre obviously running on parameters not intended from factory nor covered under the warranty? The dealer they will most likely note in their system (not mazdas) that they car was modified if in fact your modifications did damage the A/C system in anyway. A story gets written up about every car that gets written up by the technician. Its for records sake, that way if you end up coming back for more a/c work or something, they can look back in the history and see what was worked on prior.
__________________ 2008 Cosmic Blue Mazdaspeed3 1986 Mazda RX7 2002.5 Sunlightsilver Protege5 (sold 12/26/09) Hey you should read this: http://www.mazdaspeedforum.org/forum/foru...ler-you-58361/ |
Thanks for all the advice so far, everyone. I just dropped it off at a shop with a few friend recommendations, so we'll see how things go. I'll update you as I know more.
__________________ 2010 Mazdaspeed3 - Garrett GT3076R Turbo, SteedSpeed Manifold, Tial 38mm External Wastegate w/ Dump Tube, ATP Big MAF Housing, ATP 3" TIP/Intake, HKS SSQV BOV, Ultimate Racing FMIC, Ultimate Racing Catless DP, CS Test pipe, CS Catback Exhaust, Autotech HPFP Internals, Hallman Pro Boost Controller, Cobb AccessPORT, BC Coilovers, DDM 8000k HID's, Red Brake Calipers w/ Decals, Custom Smoked Headlights, Smoked Taillights, 18% Window Tint. 2011 Mazda2 Sport - OEM Fog Lights, OEM Touring Rear Spoiler, Sport Edition F2 Silver Wheels, Green Brake Calipers, 18% Window Tint, Social Engineering - Because there is no patch for human stupidity. | |
![]() Join Date: Mar 2011 Location: Boca Raton, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,500
Groans: 669
| Not Ranked : 0 score There's no such thing as a record or log of your mods. Warranties cannot be voided. Only claims can be denies on a case by case basis.
__________________ Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq |
| Not Ranked : 0 score By log I mean in the dealers own system. The tech will most likely note it in the story. For example, it would go something like this: Customer states malfunction in A/C system, found bend and slight tear in A/C due to aftermarket intercooler piping installation. Leak confirmed with dye. etc etc There isnt a national "flagging" database for mods ( Ive worked with advisors whove worked for mazda and theyve never heard of that). But if he brought it into the dealer, most likely when the technician does his story on the repair order he will note whatever the causal aftermarket parts were.
Anyways, no, they would absolutely not cover it if I blew my engine and tried to get it covered under warranty if they saw that I had brought it in with mods in the past. Which is exactly why I started this post. To answer the mystery of whether or not I should chance it. Obviously now that I've gone through a third party mechanic, once I blow my engine and take it to the dealer, they'll have no track record...make sense? Either way cross your fingers with me that it doesn't happen ;-) And if it does, please contribute to my part out thread
| The Following User Says Thank You to spoof3r For This Useful Post: | NCZ13 (09-03-2011) |
![]() Join Date: Feb 2010 Location: Knox, TN
| Not Ranked : 0 score I would take it to an A/C shop. My question is, if you blow your engine and put it back to stock, will the dealership go back to warranty the vehicle? I would imagine based off experience they will be quick to deny you and void the remaining warranty based on your sig.
__________________ 2010 MS3: |
![]() Join Date: Apr 2010 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35,474
Groans: 131
| Not Ranked : 0 score turbo blanket, how smart can they be?
__________________ Cobb SRI CPE 75 duro RMM AP - tune in progress broke ass college student |
![]() Join Date: May 2011 Location: Vero Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 417
| Not Ranked : 0 score if they are a speed certified dealer I'm pretty sure they'll know somethings going on. lol and yes, when a tech gets a car for a repair, he has a cause line he needs to fill out and a correction line. He would most likely say, "aftermarket parts caused A/C component to fail" correction "evac a/c system, replace line, recharge system" then if you came in 3 months later with all stock parts but the same problem occurred they would most certainly deny it due to the fact that you brought it in before with that problem and it was cause by aftermarket shit. I wouldn't bring your car to a dealer modded and have anything done and expect to go to that dealer and claim warranty on stuff. Unless of course it's not powertrain related which engine mods would have no effect on |
| Report: VW CEO says Seat getting its last chance | Haltech | Automotive News | 0 | 05-18-2010 08:30 AM |
| Any MS3 or MS6 that had a chance to run a G35/37? | SayNoToPistons | Street Racing Stories ( Bench Racing ) | 33 | 05-06-2009 10:40 AM |
