> Gen2 MS3 General Discussion
 Old 11-17-2018, 01:54 PM   #1
Bautista's Avatar
Posts: 22   (View Stats)
Bautista has a spectacular aura aboutBautista has a spectacular aura aboutBautista has a spectacular aura about
Default HELP! Fuel injector torx bolt won’t come off
Hey,
Need some help, i’m doing my CS injectors seals and i went through 3 T40 torx bits and still get get the bolt loose. Can someone please help. I used 2 from zutoaone and 1 from habor freight.
Bautista is offline   Reply With Quote
 Old 11-17-2018, 08:20 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Buy a torx bit from a quality manufacturer, or use an extractor.
 Old 11-17-2018, 08:37 PM   #3
Bautista's Avatar
I’ll try a quality one tomorrow. Would an extractor ruin the bolt? Do you know the part number?
 Old 11-18-2018, 10:44 AM   #4
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
You can replace with studs too. Dims in thread below.
How To CPE Injector Seals + Studs + EGR Delete
The Following User Says Thank You to JSmith For This Useful Post:
cyclist20 (10-25-2019)
 Old 10-22-2019, 01:10 PM   #5
AngryOrchard99's Avatar
Posts: 8   (View Stats)
AngryOrchard99 is an unknown quantity at this point
How can you take them out once their stripped
AngryOrchard99 is offline   Reply With Quote
 Old 10-22-2019, 01:15 PM   #6
Police - Grammarhead
Vansquish's Avatar
Originally Posted by AngryOrchard99 View Post
How can you take them out once they're stripped?
There. I fixed it for you.
You'll need some creativity and finesse. You may even need to weld a bolt to the bolt, though I'd be cautious about doing that with the potential for localized thermal expansion.
 Old 10-22-2019, 03:44 PM   #7
Bautista's Avatar
I used some irwin bolt grip bolt extractor set from lowes and they came off right off .
The Following 2 Users Say Thank You to Bautista For This Useful Post:
AngryOrchard99 (10-24-2019), Vansquish (10-22-2019)
 Old 10-23-2019, 10:11 PM   #8
Really? I went to Lowes and the Irwin bolt extractor set didn't carry one that fit around the head of the T40 Torx bolt. Do you know what size extractor worked for you?
 Old 10-24-2019, 03:38 PM   #9
Bautista's Avatar
[QUOTE=AngryOrchard99;3171758]Really? I went to Lowes and the Irwin bolt extractor set didn't carry one that fit around the head of the T40 Torx bolt. Do you know what size extractor worked for you
Don’t remember which size. I used one where the groove would grab on to the bolt once you start taking it off if that makes sense . Use alot of PB blaster.
 Old 10-24-2019, 09:55 PM   #10
Groans: 60
How bad is the actual torx fitting. Mine were a pita to remove, but a little heat on the bolt head and slow pressure with a 1/2" breaker bar and they all came loose eventually.
If you have to use extractors you can find sets from 19mm to 25mm on amazon for around $50.
https://www.google.com/url?sa=t&sour...Mmih27JwAqM4W3
 Old 10-26-2019, 07:35 PM   #11
[quote=Bautista;3171785]
Interesting, one of the Irwins bolt extractors barley fits on the bolt head so I’m going to hammer it on and hopefully it will work
Stripped Torx bolt while working on fuel pump Buffeloni MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 15 02-25-2017 08:25 PM
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.32197 seconds with 24 queries
