> Gen2 MS3 General Discussion
 Old 11-20-2017, 06:59 PM   #1
jaugustavo's Avatar
Posts: 4   (View Stats)
jaugustavo will become famous soon enough
Default Intermittent knock/rattle/chatter at idle (youtube)
As the title suggests, I have an intermittent knock/rattle/chatter from the area around the hpfp or it could be coming from behind/under the engine. In the video you can hear that it comes and goes, and I can really only hear it at idle, especially after the car has been driven for awhile. Fuel pressure holds at WOT, experiencing slight increase in knock retard spikes up to 3 or 4, at low rpms, once or twice per drive, but car drives and sounds fine besides at idle.
Mods: CS SRI, CS hpfp internals, CS TMIC, Cobb AP
Any help or ideas would be much appreciated.
jaugustavo is offline   Reply With Quote
Is there always a chatter at idle? (VVT vs. Normal vs. HPFP)? milkyway CX-7 > Issues & Troubleshooting 3 08-21-2016 11:42 AM
Intermittent 9:1 AFR at idle BuddySpeed3 MazdaSpeed 3/6 - ECU Computer Tuning 14 04-24-2016 06:38 AM
Intermittent Clack / Rattle, Timing Chain Area Eskareon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 04-22-2016 11:43 AM
Intermittent metallic rattle from driver front corner Dumbguy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 08-06-2014 10:02 AM
High STFT at idle... Intermittent fault. KevMS6 Mazdaspeed3/6 General Discussion 11 07-24-2012 06:34 PM
Page generated in 0.23942 seconds with 20 queries
