![]() Join Date: Jul 2017
Rep Power: 0 ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score Last week I was on my way home on the highway and went to merge off the on ramp in 5th gear. Made it to about 3500-4000 rpm and shifted, after I shifted it refused to build any boost at all. I can hear the turbine spin but nothing happens. It's not throwing any codes at all and drives normal besides no boost ( drove it home) as far as I can tell it's only running rich which I assume is from the lack of air. I've checked the fmic (treadstone tr8), all the intercooler piping (jbr), wastegate seems to be fine(stock), boost controller is working (grimspeed), and the bov (gfb respons) is brand new. Any other ideas on what to check I'm barely making 0.5psi. other mods include hpfp internals (Autotech) Corksport down pipe and race pipe with stock catback and jbr sri along with a v3 access port on ots stage 3 93 octane. I know I need a tune but this comes first obviously. |
![]() Join Date: May 2016
Rep Power: 53 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Do a boost leak test. |
Groans: 438
| Not Ranked : 0 score If you aren't making boost, it isn't driving normally. As said, boost leak test.
__________________ All good things must come to an end... |
| Boost cut problem | RedDevilMs3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 36 | 04-17-2019 09:13 AM |
| Boost problem | BooSTed_Hatch | 2010 MS3 - Troubleshoot/Diagnostics | 2 | 07-02-2014 06:23 AM |
| ms6 boost problem...2 psi | Stealthvr4 | MazdaSpeed 3/6 - Turbo Induction | 17 | 06-14-2014 01:36 AM |
| Had a boost problem :/ | Evolution99 | MazdaSpeed 3/6 - Turbo Induction | 2 | 03-29-2013 05:43 PM |
