![]() Join Date: Apr 2010 Location: Weston, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,011
Groans: 214
Groaned at 15 Times in 13 Posts
(Thread Starter) | Not Ranked : 0 score To make a long story short, I installed the new KMD internals on my car, when I first tested them after 100 miles, they held at 1700+psi through 3rd gear pulls. Once I started doing some tuning with the help of @rfinkle2 1500 miles later, he noticed that I was getting as low as 1250psi in the 3000-4000rpm range. I immediately thought my internals had failed/ were failing. With the help of @adlpb, we took my pump out to inspect the internals, only to find that they were flawless. We recleaned and oiled them, and put them back in. After 60 miles, I just took this log (Stg 2 CS + TIH) and my pressure dropped into the 1500s in the lower RPM range. Do you guys have any idea why this could be? Are they just bad internals, is there a bad/clogged fuel line, etc? At higher RPMs I am solid 1700-1800psi. Any advice or suggestions on where to start would be great. Cliffs: KMD internals look flawless, used to get 1700psi for 3rd gear pulls, now drops to 1500psi (probably lower if I commanded more boost) at low rpms. What to do? Attached is a 3rd gear pull with cobb stg CS + tih. Pull starts around line 85.
__________________ 2013 Evo X - Stock (for now) 2010 Speed 3 - Sold |
| Not Ranked : 0 score @kmac, could you give us a hand when you have a free moment? |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | CCC (09-09-2011) |
| Not Ranked : 0 score when you cleaned them and put them back did your pressure go normal again for those 60 miles?
Groans: 214
(Thread Starter) | Not Ranked : 0 score I didn't do any wot pulls because it was my understanding that it was a good idea to give them 50 miles to settle in. I was/am idling around 380-400psi and cruising around everything seemed ok as far as I know.
| The Following User Says Thank You to CCC For This Useful Post: | rfinkle2 (09-09-2011) |
| Not Ranked : 0 score Lines 101 -112 are what look a bit wacky. (to me @ least) |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | SLOWHATCH (09-09-2011) |
![]() Join Date: Mar 2011 Location: Boca Raton, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,500
Groans: 669
| Not Ranked : 0 score @CCC , did you try reverting back to stock map and taking a log?
__________________ Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq |
| The Following User Says Thank You to adlpb For This Useful Post: | rfinkle2 (09-09-2011) |
Groans: 214
__________________ 2013 Evo X - Stock (for now) 2010 Speed 3 - Sold | |
Groans: 669
| Not Ranked : 0 score Yeah try that. Just to focus on the issue. Could be a faulty AP...you never know
I would be happy to post a screenshot of the stock commanded fp when I get home tonight, but all stage 2 maps use 1749 psi. Last edited by rfinkle2; 09-09-2011 at 08:42 AM. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | adlpb (09-09-2011) |
Groans: 214
Are we talking stock, stock map, or the stock cobb map I am using? What map are you recommending that I try to log off of?
If you flash a stock map, fuel pressure is going to be lower in general than any of the Cobb ots maps, so looking @ the logs will also require looking @ commanded fp, regardless of map. I would, however, like to see if you dip below 1600 psi on the stock map (stage 0). | |
Groans: 669
| Not Ranked : 0 score If need be, we can divorce (AKA unmarry) our AP's and I'll give you mine. Just to discard the possibility of AP logging issues.
| The Following User Says Thank You to adlpb For This Useful Post: | SLOWHATCH (09-09-2011) |
![]() Join Date: Aug 2011 Location: Canada
| Not Ranked : 0 score Hi guys, about theses hpfp issues, i had same problems with my mods, so ive ordered a pump from cp-e. Them ive spoke with my buddy who works for mazda(technician) if he wanted to install it. So whe talked about hpfp issue on ms3 2010 and i told me that mazda released a new tsb for those pump. So i took an appointement and after testing the pump they saw it was not consistent and they changed it on WARRANTY. And its an upgraded version of the old one.....Yes ive flash with stage 2 map with my ap and did a road test...and guest what, it never went under 1700psi !!! Ive just saved mysefl 700$. And cars run big map with absolutely no problems!! SO i think everyone should take a look into this. By the way..i did not bring the car and told them: hey i have mods and my hpfp cant do the job. When temp gets colder at wot the car was runnig leaner and the engine was cutting and runnig bad idle.... |
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
| Not Ranked : 0 score I have heard that the relief valve I think its called goes bad prematurely and starts to bleed off pressure. I noticed mine was acting weird and prompted me to get upgraded pump. When I sent it in for core charge I was told that sensor had shit the bed. I'm sure lots of others here would appreciate more info on the tsb. |
@ this point, I think that flashing the stage 0 map as suggested by adlpb would help us find out if you are having a relief valve problem like slowhatch mentioned. If you are confident the internals look good after reinstallation, the stage 0 map, if it dips below 1600 would tell us there is something else (like the prv) that needs attention. I'm sure kmac will hit us with his ideas too. | ||
| Not Ranked : 0 score why not just lower the pressure targets in his current map?
| The Following User Says Thank You to superskaterxes For This Useful Post: | rfinkle2 (09-09-2011) |
| Not Ranked : 0 score There is some strange ecu logic specific to gen2 that causes the ipw to crank up when fp < 1600 psi. I don't see evidence of it on his logs, but am apprehensive to turn up the wick if fp commanded isn't sustained. Hit me with your advice @superskaterxes... Last edited by rfinkle2; 09-09-2011 at 09:48 AM. |
Groans: 274
| Not Ranked : 0 score Strange that it only dipped in pressure in that one spot. Either do a log on stock map and see how it looks or re log with current map. Pressure seems to be fine in the higher rpm range. |
| The Following User Says Thank You to SLOWHATCH For This Useful Post: | rfinkle2 (09-09-2011) |
i was just saying to lower them back to stock values (1669.7 i think) and see whats up rather then swapping to a whole different map. then you have too many variables that changed which may not lead you to your solution.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
Groans: 214
(Thread Starter) | Not Ranked : 0 score Hey guys, thanks for all the advice. I will try the stage 0 map tonight, as well as any other suggestions that you might come up with. @adlpb I may take you up on that offer if we can't figure something out soon, thanks!
Groans: 214
@CCC, if the map that created the logs in this thread is OTS, let me know the skinny on the map name etc., and I'll adjust the fp tables accordingly (to 1669.7). We can certainly try the same tune @ 1669.7 and see how things react. | |
Groans: 214
(Thread Starter) | Not Ranked : 0 score So @rfinkle2 adjusted my map again, and I am still having the same fp drop between 3k-4k rpm. As far as I can tell, everything else on my log seems good. So at this point I am completely lost. I am hoping I am not killing my car by driving around in it, but I am staying out of boost as much as possible and monitoring my fp, any insight on this would be appreciated. @adlpb helped me take out my internals last week and put them back in, they looked flawless but this issue still seems to be happening. @Cobb Tuning @Lex @kmac @David@COBB Do any of you have any insight on this problem? edit:here is a log Thanks to anyone who can help/try to help!!
| The Following User Says Thank You to CCC For This Useful Post: | adlpb (09-14-2011) |
![]() | | #24 | ![]() |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,511
Groans: 39
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs | |
![]() | | #25 | ![]() |
Groans: 214
So people usually lose fuel pressure where I am when there stock pump is crapping out? I always thought it was at higher rpms, guess I was wrong.
![]() | | #26 | ![]() |
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score Your pump is no good. If it drops at peak torque It's no good. Just because they look good doesn't mean they r. You r talking about tolerances beyond anything you can see. Last edited by kmac; 09-15-2011 at 07:34 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 5 Users Say Thank You to kmac For This Useful Post: | 86AmishMs3 (09-18-2011), adlpb (09-15-2011), CCC (09-17-2011), rfinkle2 (09-15-2011), SLOWHATCH (09-16-2011) |
![]() | | #27 | ![]() |
CCC has tried everything to diagnose the issue, and having you pop in seems like the definitive answer. Kmac to the rescue (again). | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | kmac (09-15-2011) |
![]() | | #28 | ![]() |
Groans: 669
| Not Ranked : 0 score So CCC, looks like it's time to show those logs to KMD and warrantee the parts
| The Following User Says Thank You to adlpb For This Useful Post: | rfinkle2 (09-16-2011) |
![]() | | #29 | ![]() |
or would like to see the fuel pressure tables that correspond with a solid log, I could give you a shit ton. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | SLOWHATCH (09-16-2011) |
![]() | | #30 | ![]() |
Groans: 214
(Thread Starter) | Not Ranked : 0 score @kmac @rfinkle2 thanks for all of the help. I will call KMD on monday and see about getting these warrantied. I wasn't sure if there was a common sensor/fuel line issue that could be causing this, but that seems to not be the case.
| The Following User Says Thank You to CCC For This Useful Post: | rfinkle2 (09-18-2011) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score No problem, glad I could help. |
![]() | | #32 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
Inserted 2nd grade picture for reference
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 09-18-2011 at 05:47 AM. | |
![]() | | #33 | ![]() |
Groans: 214
The other thing I was concerned about was the housing, but I guess that is less likely. Thanks again.
![]() | | #34 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| Not Ranked : 0 score OK who wants to take bets its the relief valve? wait is this for a genpu? fuck But seriously, replace the relief valve
__________________ 2012 WRX HB w/mudflaps yo! |
![]() | | #35 | ![]() |
Groans: 214
(Thread Starter) | Not Ranked : 0 score Whats the relief valve?
![]() | | #36 | ![]() |
Groans: 105
| Not Ranked : 0 score It's on the fuel rail and bleeds excess pressure back to the fuel pump. It's located right next to the feed line on the rail itself.
![]() | | #37 | ![]() |
Groans: 214
(Thread Starter) | Not Ranked : 0 score Is there any way to test this aside from replacing it? Where can I get one/how much are they usually? Thanks for your opinion.
![]() | | #38 | ![]() |
Groans: 105
| Not Ranked : 0 score Your local Mazda dealer or streetunit.
![]() | | #39 | ![]() |
| Not Ranked : 0 score If it holds pressure upstairs and doesn't bounce like crazy and unable to get stable pressures It's not the valve. |
| The Following 4 Users Say Thank You to kmac For This Useful Post: |
![]() | | #40 | ![]() |
Groans: 105
| Not Ranked : 0 score Ok Don't replace the valve Let me know when you find the problem kmac
| Anyone else have 80,000 psi of DI fuel pressure? | mdd5148 | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 09-03-2011 10:04 AM |
| More fuel pressure not enough? | Enki | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 36 | 06-21-2011 10:55 AM |
| Oil Pressure Gauge... issues.. pls help | :: Gusto :: | MazdaSpeed 3/6 - ECU Computer Tuning | 16 | 04-18-2011 07:07 PM |
| Fuel Pressure PID | bewsted | 2010 MS3 - ECU Computer Tuning | 16 | 02-03-2011 10:45 AM |
| fuel pressure | Super Unique | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 10-31-2008 05:27 AM |
