![]() Join Date: Oct 2011 Location: Madison WI
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Pretty new to the forum just looking for some ideas. I have a 2010 MS3 with CSRI Corksport TIH, Boost Tubes, Magnaflow Exhaust and Cobb AP. When I get on the gas im only hitting 12 or 13 pounds of boost any ideas? Thanks Guys |
![]() Join Date: Feb 2012 Location: Quantico, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,434
| Not Ranked : 0 score 1. What map are you running on the AP? (OTS)? 2. Check and make sure everything that flows air in the engine bay is tight! 3. Posting a log would help! 4. Make sure you are actually pressing the throttle all the way down...
__________________ [SIGPIC][/SIGPIC] 2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_Nameless Race Pipe_RBF600_Ferodo DS2500_PTUNING Tuned Less parking more racing |
| The Following User Says Thank You to leon78 For This Useful Post: | rfinkle2 (03-28-2012) |
2) I have checked that but I will check that again. 3) I will try and get some logs later on today. 4) I don't think that's an issue lol 5) would it be possible i damaged the boost control solenoid when installing the TIH would that cause low boost? | |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
| Not Ranked : 0 score Well you have the car in front of you. Look to see if the nipples are broken off. Posting a log will get you a definet answer. And to save you some time in case you dont know: 3rd or 4th gear start at 2500 rpm slam foot down untill 6500. Good luck.
__________________ TEAM LUXURY ![]() |
(Thread Starter) | Not Ranked : 0 score You were correct hose from intercooler to motor came off. Hitting 20 pounds no problem now! Thank You! |
| The Following User Says Thank You to KrishyC For This Useful Post: | leon78 (03-28-2012) |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 310
Groaned at 38 Times in 16 Posts
| Not Ranked : 0 score Why is there no FP on this list of mods! |
![]() Join Date: Jun 2010 Location: NoVA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 412
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score Whoa, you're hitting 20 pounds on an OTS Stage 1 map? You should probably lower your WGDC values... a lot.
__________________ 2010 LSM Speed3 Twinscroll .82 A/R GT3071 | Boost Junkyz Mani | 44mm TiAL MV-R CXRacing/RPM Piping + TR8 | HTP 3.5" Intake | AT Internals | Forge V1 ![]() Premier Auto Modified ATP Long DP | JBR RSB | Other Miscellaneous Shit Tuned by Me |
| RIP: November 21, 2012 ![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
Groaned at 20 Times in 12 Posts
| Not Ranked : 0 score In before blown rod or blown head gasket. I told you guys, with just intake mods, anything over 17psi just creates heat and not power. Log log log. Look at BATs vs MAF airflow, You have yourself there a Borg-Warner flame thrower. Until you get exhaust side freed up (Magnaflow exhaust does not count, sorry) leave the boost targets at 16.5psi or less! An occasional spike to 18 or even 19 psi is ok but on stage1 you should never see 20psi or more even during a boost spike. I personally wouldn't even log that car until you bring the boost targets to 16.5psi or less and wgdc to no more then 80% !!!
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
Unless you've changed your commanded boost levels, the OTS Stage 1 maps shouldn't go above 17.5lbs I don't think. If you're running 20lbs of boost, then you're asking to grenade your motor, as you don't have the supporting mods to make that level of boost safe.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | ||
| Stage 2... Not hitting full boost | 2010Speed3 | 2010 MS3 - Troubleshoot/Diagnostics | 27 | 06-14-2018 07:47 PM |
| OTS Map Not Hitting Boost Targets | kahunab14 | MazdaSpeed 3/6 - ECU Computer Tuning | 53 | 02-18-2012 10:30 AM |
| Not hitting boost targets again (AP).. | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 28 | 08-01-2011 05:35 PM |
| HELP!!!!Not Hitting full boost anymore!!!! | dadon1985 | 2010 MS3 - Troubleshoot/Diagnostics | 22 | 04-10-2011 09:19 PM |
| Not hitting full boost | Post pwned | 2010 MS3 - Turbo Induction | 10 | 11-28-2010 01:22 PM |
