![]() Join Date: Sep 2011 Location: Cape Town, South Africa
Rep Power: 237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
(Thread Starter) | Not Ranked : 0 score With threads like this it is often asked, “Which is the best?” This is difficult to answer as some consider best quality at any price, personal preference / bragging rights / street cred (popular brand), best value (quality at a good price), popularity (local Nator), cheapest price, etc. This is just a list in descending Genpu purchased popularity order. You may be able to find better deals from various websites. It is up to you to find the best price. See MSF Wiki Glossary for any terms not understood: Glossary - Mazdaspeed Forums Mazdaspeed 3/6 Wikispeedia]MSF Wiki ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ Upgraded Exhaust Manifold (EM) The stock manifold should be just fine until you go big turbo (Calvin@Cobb) as usually this manifold does not align with the BT for installation. Basically, any improvement in air flow into or out of the engine results in more performance. Improving the exhaust flow has the added benefit of more VE, which translates into better fuel consumption, less backpressure for transitioning from deceleration to acceleration and faster turbo spooling. CP-E LTRmani Cast 304 SS, durable, good to 700 HP, zero chance of cracking (weld-less), integrated external wastegate (can be used immediately or at a later date) (~44mm opening), optional Block Off Plate and clamp, cast merge collector spike. equal length runners, Tial waste-gate flange options Inside Diameter (ID): 1.6” Available from: CP-E LTRmani MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $943.95 DNP SS: SS-321 Designed to maximize the exhaust flow increasing the quickness of the turbo spool up into boost, requires no porting, one-year crack free warranty, DNP DISCONTINUED as company is no longer in business Available from: No longer available MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $581 when was available Full Race EFR Robotic-TIG welded SS, equal length runners, direct bolt-on upgrade replacement designed to work with any B1 frame EFR turbo such as EFR6258 and EFR6758 Inside Diameter (ID): 1.25” Available from: Full Race EFR MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $1,075.65 + $120 black or silver manifold coating Full Race Pro Robotic-TIG welded SS, equal length runners, direct bolt-on upgrade replacement designed to work with any stock or stock-frame upgrade turbocharger up to 500whp, i.e.: ATP Garrett GT28R, 30R, etc. Inside Diameter (ID): 1.25” Available from: Full Race Pro MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $886.88 + $120 black or silver manifold coating Steedspeed Note: stock flange flows less than Mazda EM CAD designed to direct the exhaust at the turbo using the most direct tubular route possible retaining the kinetic energy in each exhaust pulse, machined on a Makino out of 1018 steel, finished with a thick ceramic coating that can stand up to 2,000 degrees, bolt-on stock replacement. Although all passages are fairly equal in length, for turbo applications, equal length is not important for making power. DISCONTINUED Available from: No longer available MS6 (), MS3 Gen1 (), MS3 Gen2 () $750 when was available AFI Turbo Manifold Stock Mazda turbo flange, T3 frame, or V-band with EWG option in either 38mvs or 44mvr Available from: AFI Turbo Manifold MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $849 or Race $1,139 OBX Racing Sports Turbo Manifold (eBay) Note: no guarantee to fit 99% of turbos T-321 SS (v T-304, which is prone to cracking), lifetime warranty from manufacturing defects and cracking Available from: OBX Racing Sports Turbo Manifold MS6 (Not found), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $287.50 JDM (eBay from Hong Kong) WARNING This manifold appears to be a Chinese clone of the V1 XS Power manifold, but produced with thin, 1.4mm thick, low-grade (T-409?) SS as rust was seen inside the poorly welded collector. The eBay seller made XS Power V2 claims, which seems suspect. Available from: JDM MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $249 XS Power version one (V1) / V2 V1 on left V2 on right *** BOTH ARE DISCONTINUED ALTHOUGH STILL FOUND ON XS POWER WEBSITE *** Both versions were T-304 SS tubing and flanges with 3mm thick tubing- V1 had a more restrictive runner on cylinder number 4 and V2 corrected this. Issues: 1 Early V2s had a fitment issue. The turbo location was moved 1/2 inch, which only seemed to affect MS6's when using an M2 downpipe, but this was corrected; 2 Do not use the XS Power gasket, but do use copper spray (LumberJack) 3 Reports of cracking were related to ceramic coating, using heat wrap or installing the turbo support bracket; 4 Wrong thread for EGT bung required modification; and 5 Some warped flanges that were not properly resurfaced initially. XS Power claims a 15 HP gain, 28% better and more balanced flow V1 and V2 available from: XS Power V2 but wait for V3, which is expected in April 2015. See: XS Power Turbo Manifold is here... Install pics & Dyno results to follow soon. Inside Diameter (ID): V3 1.65” (42mm) expected MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $475 Treadstone Highest grade ductile iron, coated with a high temperature paint to prevent rusting, iifetime warranty Available from: Treadstone MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $339.15 DOC Race Schedule 40 SS, hand crafted, TIG welds, improves exhaust flow, thick flanges, includes 4 studs, nuts and the OEM manifold to turbo gasket Inside Diameter (ID): 1.38” Available from: DOC Race MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $795 Boost Junkyz Stock placement, options: external waste-gate, 44mm, T3 and VBand turbo inlet Available from: Boost Junkyz MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $725 ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ Port and Polishing (PNP) Un-tick Codes P2006 and P2009 when doing a VTCS delete. The purpose of porting, polishing and usually also ceramic / powder coating, is to increase the intake flow capacity. PNP intake manifold with VTCS Delete: usually done locally Available from: check with your local speed shops MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $? NJSpeed Available from: @NJSpeed; MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $? snailD Available from: @snailD; MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $ upon request, but note that this is a non-professional side-line and no core is available SpeedPerf6manc3 Available from: SpeedPerf6manc3 MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $90 / hour Relentless Customs Available from: Relentless Customs MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $359.95 ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ Upgraded Intake Manifold (IM) In addition to PNP’s increasing the intake flow capacity, IM also improves the balance between the runner lengths. The OEM intake manifold (MAPerformance) has a variance of 25.23% between the runners. JM Fabrication (JMF) Sheet-metal Intake Manifold: 8 HP, 11 ft-lbs on K04, TIG welded from high quality 6061 T6 aluminium, CNC machined flanges and radiused inlets into each plenum bottom to improve airflow by 10-15%. Included with each manifold is all new stainless steel hardware, brass vacuum fittings, fittings to relocate your fuel pressure sensor, vacuum hose and a check valve for the EVAP line preventing you from having to destroy the OEM line. Options available are a "BRUSHED / UNPOLISHED" finish or a mirror like "POLISHED" finish. The TB elbow and inlet do not get polished. They are not visible once installed. There are additional throttle body flanges, a mount for the OEM MAP sensor, NOS bungs which are pre-drilled with a centring hole, but not tapped or drilled through the runners. That is left to the customer due to the many different nozzles on the market. Also, 1/8" NPT bungs are available for WMI, which are drilled through the runners completely. The throttle body can be installed rotated 180° from OEM for more clearance from the wire harness on the starter. Note: will NOT work with the stock top mount intercooler. Requires two to three weeks to make Available from: JM Fab (JMF) MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $1,036.67 options: throttle body flange (stock or 75mm bore), OEM MAP mount, polished James Barone Racing Available from: MS6 (), MS3 Gen1 (), MS3 Gen2 () MAPerformance (Modern Automotive Performance) Rev3 Intake Manifold 26 HP gain, will take your core in exchange. This is included here as the stock plenum is cut open and reshaped to achieve a decreased 5.8% variance between the runners while improving the flow capacity by 7.31% to 1073 CFM. Available from: MAPerformance (Modern Automotive Performance) Rev3 Intake Manifold MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $649.99 + options: ceramic coating $150 (black or blue), $400 (core) Street Unit High Flow Intake Manifold with PNP option WARNING: read http://www.mazdaspeedforum.org/forum/foru...3/#post1927730 Available from: SU MS6 (?says all MS), MS3 Gen1 (?says all MS), MS3 Gen2 (?says all MS) $395 I have included the discontinued items (DNP, Steedspeed) as you still find them in signatures and they may be “for sale” when un-installed for selling the vehicle. Also, note the Warnings. I could not find a link to JBR’s IMs, although several MSF members state they have installed these. Please provide these to me if you can. Let me know if I have missed anything. Discuss here: The Official Turbo Manifold Thread
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass Last edited by Inquisitive; 02-12-2015 at 10:02 PM. |
| The Following 15 Users Say Thank You to Inquisitive For This Useful Post: | 09TrueRedGTX (02-06-2015), ArmanRus (03-18-2015), ASHMS3 (02-06-2015), Cevaes_64 (02-11-2015), cshunter (02-09-2015), CWP_MS3 (02-06-2015), dsb_chicago (02-06-2015), Easter Bunny (02-08-2015), ibcrusn (02-06-2015), Ingle (02-06-2015), Jtaylor (02-11-2015), MD1032 (02-07-2015), mxlplx71 (02-06-2015), SpeedRebirth (02-06-2015), Vansquish (02-06-2015) |
![]() Join Date: Nov 2011 Location: hollywood Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,448
Groans: 42
| Not Ranked : 0 score Theres a few more exhaust mani to add up. Boost junkies and DOC, even rape built lol Nice write up
__________________ i got a useless big fucking turbo Fuck mazdaspeeds Fuck shayne |
(Thread Starter) | Not Ranked : 0 score Thanks
If you can provide the links, I will update.
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass | |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score The full race to suit Mazda OEM flanged turbos Full Race Prostock Turbo Manifold MZR DISI Turbo Mazdaspeed 3 6 MS3 MS6
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score As a FYI, steed speed was found to flow else than stock, at least for the stock flange one...
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
Addition and amendments made
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass | ||
Groans: 438
| Not Ranked : 0 score The OBX manifold is not guaranteed to fit our cars. It was just some prototype that uses a different turbo setup, and they decided to sell it. Definitely will not bolt up to about 99% of the turbos that are common for MZR. Alos XS Power no longer sells the v1, they are currently selling a v2, with the v3 on the way, which according to people on here will be amazing.
__________________ All good things must come to an end... |
(Thread Starter) | Not Ranked : 0 score Thanks for both Is it just me or does it seem like the warnings may exceed the offerings? Is the XS Power V2 still as prone to cracking / leaking due to thin metal, bad welds, fitment problems and dimpling primaries as reported by @aaronC5Z;?
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score @Inquisitive; you may want to add a break between exhaust and intake mani's. Your post just rolls straight from one to the other. Most people will be able to figure out the difference, it's just a suggestion.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
Groans: 438
__________________ All good things must come to an end... | ||
| The Following User Says Thank You to g00s3y For This Useful Post: | Inquisitive (02-06-2015) |
++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++ Thanks
| The Following User Says Thank You to Inquisitive For This Useful Post: | ASHMS3 (02-06-2015) |
Rep Power: 6574 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Added to the knowledge base. Well done.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post: | ASHMS3 (02-06-2015), Inquisitive (02-06-2015) |
Groans: 42
| Not Ranked : 0 score DOC DOC Race Turbo Exhaust Manifold Mazdaspeed 3 2007-2013 / Mazdaspeed 6 2006-2007 Boost junkyz Boost Junkyz Metal Fabrication
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
Change the blue to a different color, it's very hard to read against the dark msf background. Makes my eyes hurt ![]() RED perhaps? Or brighter BLUE Good job compiling this info
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi | |
| The Following User Says Thank You to SpeedRebirth For This Useful Post: | BeastlyZoomZoom (09-04-2018) |
(Thread Starter) | Not Ranked : 0 score Thanks - incorporated
The pleasure is all mine. (funny "local?" expression)
| The Following User Says Thank You to Inquisitive For This Useful Post: | SpeedRebirth (02-06-2015) |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
The only issues I have seen with cracking were on manifolds that had been coated. Or the installer didn't remove the turbo support bracket and caused extra stress on the mani. V1 & v2 had 3mm thick piping which is not thin at all. The eBay knockoff / jdm parts manifold is thin tubing. Maybe people are mixing them up. I don't really think it was a problem on the v2, but when I helped with the v3 design they went even thicker to 3.2mm Pipe because the new builder said it was just a better option. Oh, and if this is the thread you are using to put up a warning about the xs manifold, you really need to 're read it. Glowing catted down pipe after after market exhaust manifold install Also in the thread the pictures are of the eBay knockoff manifold not an xs power. I sort of became an expert on this. Op is pretty much using general opinion statements from someone who never had first hand knowledge with this particular part. He obviously does not know how these were built... Calling 3mm thick pipe "thin" is hillarious. That eBay jdm manifold however is 1.4mm thick pipe.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! Last edited by Turbo_Steve; 02-06-2015 at 07:31 PM. | |
| The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post: | Easter Bunny (02-08-2015), g00s3y (02-07-2015) |
(Thread Starter) | Not Ranked : 0 score Wow, not sure, but have I just been flamed in my own thread? If so, no wonder I have seen so many noobs in Who’s Online that were too afraid to post.
I stand corrected, but I thought that the main problem with JDM was, as stated just above in the OBX product, JDM’s use of T-304 SS and not T-321 SS. My personal experience with cracking is more related to OEM cast EMs. I think the main point that has been missed is the descending order of popularity by Genpu owners. Genpu owners should have gleaned the experience of the MS6 and Genwan pioneers. The main complaint that I have seen with the most popular EM by CP-E has been the price, certainly not the quality. The next most popular purchase was the now discontinued DNP, etc. XS is far down the line. So, my challenge to you is to write a concise summary of your “expert” opinion on the products which you have personal experience or quote your source, not just a link to a thread, such as moving “thin” from XS to JDM. This is now the place for it.
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass Last edited by Inquisitive; 02-08-2015 at 06:30 AM. | ||
| Not Ranked : 0 score Lol....
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
| Not Ranked : 0 score Just pointing out that some of your facts are not facts. More just opinions about a brand in general.
V1 on left V2 on right *** BOTH ARE DISCONTINUED EVEN THOUGH STILL ON XS POWER WEBSITE*** Both versions were 304SS tubing and flanges with 3mm thick tubing- V1 Had a more restrictive runner on cylinder number 4 and v2 was implemented to correct this. Forum member StayBroke was helping xs power with test fitment of the v2 and reported no issues with the samples, when in fact there was an issue with fitment. Xs power had 60 manifolds built based off of the info from StayBroke. The turbo location was moved 1/2 inch which only seemed to affect mazdaspeed 6's when using an m2 downpipe. Many users have reported no issues with v1/v2 manifolds and have been running them for quite some time. There were only a couple issues reported with cracking but those issues were in cases where the installer either ceramic coated the manifold, used heat wrap or installed the turbo support bracket. There were issues as well with the egt bung being the wrong thread and requiring modification to add an egt sensor, as well as some warped flanges that were not properly resurfaced initially. @Turbo_Steve worked with XS power to re-design the manifold and fixed all issues that were known. V3 Manifold is to be released april 2015 See XS Power Turbo Manifold is here... Install pics & Dyno results to follow soon. for more info. Was Available from: XS Power V1/V2 MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $475 Here we go - Please feel free to tweak the format as you see fit.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! Last edited by Turbo_Steve; 02-08-2015 at 10:36 AM. | ||
| The Following User Says Thank You to Turbo_Steve For This Useful Post: | Inquisitive (02-08-2015) |
| Not Ranked : 0 score Also since xs power bought one of these "JDM" Manifolds and sent it to me to check out and therefore I have first hand knowledge, here is a proper re-write JDM (eBay from Hong Kong) WARNING This manifold is a Chinese clone of the v1 xs power manifold. They produced it with thin 1.4mm thick low grade stainless steel that @Turbo_Steve claims to not be 304ss because in a manifold he obtained to check out there was rust inside the poorly welded collector. Also it's most likely 409SS which would explain the rust & not 304ss as specified but further testing is needed. Ebay seller of the Jdm manifold copied xs powers specs for the v2 as follows for this manifold which pretty much makes them meaningless ... "15 HP gain, T-304 SS, mandrel bends for K04 and BNR, improves outflow by 30%, more balanced flow from all runners, TIG Welded CNC Machine Flange, faster turbo spool. The factory turbo bracket may need to be removed for fitment." Includes gaskets which will fail and leak and 4 useless nuts and bolts that can't be used on this install. Poorly made part and not suited to long term use on a turbo application. Available from: JDM MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $249
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! Last edited by Turbo_Steve; 02-08-2015 at 10:37 AM. |
| The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post: | Inquisitive (02-08-2015), manu (06-01-2017) |
(Thread Starter) | Not Ranked : 0 score @shaneski; I placed the Full Race EFR on top as that is the one that I have seen in signatures and personal profiles, but the Full Race Pro immediately follows to keep them grouped together. @Turbo_Steve; I like summarising, but please check me, especially on the MS6 / M2 point. I know that technically, each bullet point should start with the same grammatical syntax. Is the XS Power gasket still a problem as reported by @LumberJack; in XS Power Turbo Manifold is here... Install pics & Dyno results to follow soon.?
| The Following User Says Thank You to Inquisitive For This Useful Post: | shaneski (02-09-2015) |
![]() Join Date: Nov 2011 Location: Clarksville, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,001
| Not Ranked : 0 score Some other info to add to a few of those, not sure which Full Race manifold that is in reference to.
__________________ 2013 CWP That's slow ![]() 2012 LSM Totaled by an asshole red light runner Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )Previous: MILTUNED E85 K04 |
anyways, your edits above for the xs manifold and the jdm look good!
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! | |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score I removed the UR and Beachshoer IMs as I confirmed with the MSF members that they do not exist. @beachshoer; did some PNP work for some local Nator members. I’m just waiting for someone with a JBR IM to provide the link so that I can update the stub / placeholder. I have added an image for the IM table because I couldn’t get any of the MSF editors to accept it native. Thanks @cshunter; - I have added your three IDs. Hopefully, others will add the remainder. Perhaps @shaneski; knows if 1.25” applies to both Full Race EMs.
If the quality and fitment improves in the XS Power V3, it could be the obvious choice for price and value. Any idea on the ID of V3? I see that you ported your intake. Would you be willing to PNP for others – for a fee?
| The Following User Says Thank You to Inquisitive For This Useful Post: | cshunter (02-11-2015) |
![]() | | #25 | ![]() |
Tubing should be 42mm ID I have zero interest in porting more manifolds. I am developing a bolt on manifold.
| The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post: | cshunter (02-12-2015), Inquisitive (02-11-2015) |
![]() | | #26 | ![]() |
![]() Join Date: Oct 2009 Location: Andersen AFB, Guam
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score @Inquisitive; Regarding the CP-E EM Fitment after getting it down past the cowl portion at the bottom of the windshield is good. The part where the turbo bolts to the manifold is such a pain in the dick. Also, the nuts they provide strip easily. Ease of install: < no such thing. If you follow there directions to the "T", you are practically taking your entire top portion of your motor apart. If you don't follow their directions, then you either have to disconnect the RMM or TMM to rock the motor forward after bending the shit out of the body molding at the bottom of the windshield to get it to slide down and onto the manifold studs. Also, if you try setting the turbo (assuming you did a turbo swap at the same time) on the front sway bar (i think) then putting the manifold in and having someone lift the turbo up it is a huge pain in the dick to thread the nuts and tighten all the nuts evenly.. As for quality and performance: both are great and provide much better flow. Also, it isn't such an eyesore to look at like the factory manifold
__________________ RichTuned Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG 11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected 4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected |
| The Following User Says Thank You to BlueDmnSpeed For This Useful Post: | Inquisitive (02-17-2015) |
![]() | | #27 | ![]() |
![]() Join Date: Aug 2011 Location: Murrieta, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,535
Groans: 60
| Not Ranked : 0 score Here is my experience with the CP-E EM. The easiest way to install it, well there isn't an easier way, the thing is heavy as shit. After asking for knowledge from a few OGs, i learned that by removing the valve cover and loosening the pmm makes the install way easier, the manifold slides right in. The manifold to turbo bolts are a pain in the ass to install (thank god for my tiny pussy hands) i suggest cutting a wrench in half and have bandaids close by. the kozmic motorsports dump tube will not fit if you have a UR downpipe. The manifold is amazing, other than the fact that it is heavy as fuck. I hope this helps.
__________________ 2011 MS3. Cobb AP V3, GTX3071, CPE LTR mani, Tial 44mm EWG, 3 bar MAP sensor and PnP harness, JBR WP intake, HTP battery tray with a 51 Optima Yellow battery, ITV22s, GFB BOV, Autotech internals, CPE injector seals and studs, VTCS delete, COBB FMIC, UR DP and TP, CNT CBE, JBR TIGs and Coolant bypass, JBR EGR delete, JBR RMM, PMM, and TMM, JBR OCC, PERM Plate, JBR RSB, JBR Rear Camber arms, 17X8 RPF1, TWM full replacement shifter with a PERM buttplug shift knob. Waiting to install:Built block, NJspeed PNP IM, Prosport boost and water temp gauges, coilovers and shit. |
| The Following 2 Users Say Thank You to BPASPEED For This Useful Post: | 09TrueRedGTX (03-11-2015), Inquisitive (03-11-2015) |
![]() | | #28 | ![]() |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
| Not Ranked : 0 score FullRace I think with my build engine ... soon
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 Last edited by Atomic41; 05-29-2017 at 07:56 AM. |
![]() | | #29 | ![]() |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score Should add the DM mani.
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
![]() | | #30 | ![]() |
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 |
![]() | | #31 | ![]() |
| Not Ranked : 0 score I don't hence why I said it should be added....
![]() | | #32 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score I have yet to actually own and use any of these manifolds
__________________ 2013 CWP and Stock |
![]() | | #33 | ![]() |
| Not Ranked : 0 score I have the DM mani, and love it. Also have an EWG DNP awaiting install.
![]() | | #34 | ![]() |
| Not Ranked : 0 score well all of my manifolds have been custom and I'm proud to say NC made.
| The Following User Says Thank You to NCspecV81 For This Useful Post: | Djohns (05-29-2017) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Very nice!
![]() | | #36 | ![]() |
![]() Join Date: Sep 2016
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Is there an exhaust manifold you guys would recommend for a stock turbo car? I'm getting my gf's car back together after the exhaust valves touched the pistons, and found the original manifold had a crack in the flex section. I'd prefer to replace it with something cheap that'll maybe flow a bit better and not have a stupid crack-prone flex section. I'd prefer something made out of cast iron. I've never seen a 304SS last on a turbo daily driver, and the 321 and 316 manifolds tend to be pricey. It looks like most of the aftermarket options are built to fit larger turbos, so I'm guessing I'd be best off with an eBay stocker? Thanks for any help. |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Stocker with the K04 is fine.
![]() | | #38 | ![]() |
![]() Join Date: Aug 2017 Location: South Jersey
| Not Ranked : 0 score BUMP!! I read most of this thread and did my research before i swapped to the corksport turbo because i figured if i had the turbo out i might as well replace that ugly stock manifold. looking over all the options i could hear my credit card screaming NO from my wallet. then i was looking at the XSPower website and i couldn't say no. they were less than half the price of everything else. I installed it with the turbo and it mounted right up with no issues, and really a quality product. super happy with it. if you're looking for one like i was, i would recommend them 100% Mazda Turbo Manifolds, XS Power Inc. |
![]() | | #39 | ![]() |
![]() Join Date: Apr 2012 Location: West Palm Beach, FL
__________________ 2013 Mazdaspeed 3 91k miles and counting Freektuned since 17k at 21psi Power: HTP 3.5" intake - TR8 - CX piping - Snow Stage 2 @ 100% meth at 625mL/min- UR catless DP - UR testpipe - Corksport axleback - Turbosmart Dual port on recirc Supporting: Corksport HPFP - fresh blasted valves- 3Bar MAP+pigtail - Damond EGR full delete - Damond Trio - TB Coolant bypass - 51r battery w/box - Corksport shift bushings - Known Fails: Florida Heat - stock k04 - OEM Midpipe - shitty ebay catchcan | |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Yup. Again like all the research shows you truly won't see a HUGE difference, bit it sounds better and looks better for sure. |
| OFFICIAL Warranty Extension Program on turbo and VVT Actuator Thread. | SPEED6 KILLAH | Mazdaspeed3/6 General Discussion | 528 | 09-24-2017 06:36 PM |
| OFFICIAL Warranty Extension Program on turbo and VVT Actuator Thread. | SPEED6 KILLAH | MSF KB - Mazdaspeed 3/6 - Troubleshooting | 349 | 09-19-2012 01:32 PM |
| High strength studs for turbo (manifold to head and manifold to turbo) | bnoon | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-11-2009 10:26 PM |
| Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold | nobmood | Mazdaspeed3/6 General Discussion | 18 | 03-01-2009 08:14 PM |
