![]() Join Date: Jan 2011 Location: pittsburgh, pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
Groans: 32
__________________ '11 Speed 3 Black Mica (Sold unfortunately, going back to school) '12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it Licensed PA State Inspection and Emissions Tech |
![]() Join Date: Sep 2009 Location: Rosemead, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 717
Groans: 27
| Not Ranked : 0 score yes it will benefit from a OCC. the crankcase vent is routed to the intake mani so any blow-by will gunk up the intake mani and valves. Since direct injected motors don't inject into the intake mani like port injected, there is no fuel to wash off the gunk. It also vents out of the valve cover and is routed to the intake. You can put a catch can or a breather filter also.
__________________ 08 MS3 () Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX () Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms () Centric Slotted Rotors/ Posi-Quiet pad () Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90 |
Groans: 32
(Thread Starter) | Not Ranked : 0 score i just pmed matt damond on price and availability on a saikou michi, but what other options are out there and are they even worth it in comparison
![]() Join Date: Jan 2009 Location: NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 815
Groans: 46
| Not Ranked : 0 score +1
__________________ |2010 VRM Speed3| |CS SRI/TIP/TMIC|UR CBE/TP|CP-E HPFP|COBB AP Stg2 FREAKTune|SU BPV|TRZ MM|ITV22's| |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
| Not Ranked : 0 score It's basically just the catch can and two hoses. However, Matt includes a check valve with his and comes pre-assembled with hoses cut to length. It's good to support a member of the forum who is doing this for our platform. I'm not sure if buying a can from an online site will include hoses or just the can. I do no think they come with the check valve. |
![]() Join Date: May 2010 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score I have had Matt's kit for some time, works fine, I drain it when I change my oil, mounted on the tranny, drilled hole in CS skidplate. ![]() ![]() Z
__________________ Zman 2010 L MS3 GTX3076 w EWG | CPE BT SRI/TI | Cobb DP | HKS SSQ IV | CPE FMIC | CPE HPFP | IM SSPMod/PnP | GS 3P EBCS | CPE Inj Seals | Sure TIG | UR CBE | CPE RMM/SMM | BC Coilovers (8/5) w/ Rear Camber Arms | RR RSB | TWM SS replacement | Forgestar F14 10/9.5 | JVC KWAVX830 HU w/ XD 600/1 XD600/4 amps JL subs/components | AP and tuned w/ Freak Parts to install: DO Meth |
| The Following 2 Users Say Thank You to ZPrice For This Useful Post: | ChimmyChong (04-03-2011), nichall10 (04-04-2011) |
![]() Join Date: Feb 2010 Location: Albuquerque, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 606
| Not Ranked : 0 score I think CorkSport has one in the werks as well...
__________________ Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP|H&R Springs|Koni Yellows|Cobb FMIC/AP|Denso ITV22|Torque Solutions RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Continental DWS Extreme Contact 235/45-17|SURE IM/TB TIG|CP-e HPFP|Grimspeed ECBS|DO Stage 2 w/100% Meth|MD OCC |
Groans: 89
| Not Ranked : 0 score They have had one for a long time now. I'm sure it's not as high a priority as their FMIC is. But I don't want to assume. Go with Matt's, like I said, it's good to support the community and those select individuals who are designing parts for us. Tapawhat? |
| The Following User Says Thank You to 08.5MS3 For This Useful Post: | myt_tuf1 (04-04-2011) |
Groans: 27
the saikou catch cans are baffled. It makes the gases go through a media so that it condenses and catches more of the water, oil, and fuel. Most catch cans out there are not baffled. You can use a non baffled can but it just won't do as a good of a job as a baffled one. If you going to spend $80 and up on a brand name can that is not baffled .. might as just get the saikou cans from matt.
__________________ 08 MS3 () Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX () Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms () Centric Slotted Rotors/ Posi-Quiet pad () Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90 Last edited by easy; 04-03-2011 at 10:48 PM. | |
| The Following User Says Thank You to easy For This Useful Post: | 08.5MS3 (04-03-2011) |
Groans: 136
| Not Ranked : 0 score You can turn a non-baffled catch can into a baffled one by adding stainless steel wool kitchen scrubbing pads. I did it to my catch can. Sent from my iPhone using Tapatalk
Groans: 32
(Thread Starter) | Not Ranked : 0 score how many of you arent running with catch cans and do you have any problems? and where would you put it? between the valve cover and the intake or between the pcv and intake manifold? i was thinking between the pcv... also if you dont run a catch can what all will happen obviously the oil gas and shit will go back into the intake but what will that cause now and down the road?
__________________ '11 Speed 3 Black Mica (Sold unfortunately, going back to school) '12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it Licensed PA State Inspection and Emissions Tech Last edited by nick779; 04-04-2011 at 04:40 PM. |
![]() Join Date: Mar 2011 Location: Nor Cal- Pittsburg
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
Things that can happen vary from nothing more then nasty oil spitting out of the exhaust and getting the bumper dirty. Same with the intake manifold/piping. Worse case is you boost up, lift the head and pressurize the system and crack rings. Jason | |
Groans: 89
| Not Ranked : 0 score I have yet to install mine. My car runs fine, however, I have never taken off the intake manifold to see the possible 'damage.' Most put it between the PCV and the intake manifold, however, Lenny just made a thread of what he emptied. His is running from the valve cover to his intake. You could essentially run both, but the most popular, and usually the most beneficial, will be to run it from the PCV. You pointed out what will happen without one. Being we are not port injected (with fuel injectors spraying fuel into the intake manifold), we do not get the benefit of the fuel 'cleaning' up all that gunk. With the OCC, all that gunk will go into the can and air will go back into the IM, therefore, no contaminants will be going back into your IM. Over time there will be a layer a gunk build up which will decrease performance and cause an increase in detonation. |
| Not Ranked : 0 score Most likely not. Remember the fuel is injected directly to the cylinders. It is a "dry" manifold. I was actually going to start fabricating a catch can this week with filters on it as well. Going to get some aluminum tomorrow. Jason Last edited by SFWD 1934; 04-04-2011 at 05:30 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score Check this out. Nataphen opened up some of his intake stuff after only 5000 miles. It is pretty nasty in there. There are also some pics of what he and I have drained from our cc's. Do you need an OCC for gen 2?
Otherwise all the crap gets sucked through your intake system. Last edited by wolly6973; 04-04-2011 at 05:33 PM. Reason: MSF Database - Automerged Doublepost | |
Groans: 32
how long did it take you guys to install yours? 1-2 hours?
__________________ '11 Speed 3 Black Mica (Sold unfortunately, going back to school) '12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it Licensed PA State Inspection and Emissions Tech | |
![]() Join Date: Dec 2010 Location: Phoenix, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,160
| Not Ranked : 0 score lemme know what price Matt Damond charges I would most likely buy one from him
__________________ [SIGPIC][/SIGPIC] |
Groans: 386
You could do it in a lot less time if you have someone with tiny hands around. There is not much space up by the IM/PCV. | |
Groans: 32
im waiting on my refund from another store before i go for it
__________________ '11 Speed 3 Black Mica (Sold unfortunately, going back to school) '12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it Licensed PA State Inspection and Emissions Tech | ||
![]() Join Date: Feb 2009 Location: Crete, IL.
| Not Ranked : 0 score $160?? That's quite a bit. How do we get in touch with Matt? What's so different about his than any others out there? Thanx |
| Not Ranked : 0 score 160 isn't too much, I was hoping for around $80, I don't have the genpu, i haz genwon
Groans: 89
| Not Ranked : 0 score |
Groans: 386
![]() | | #24 | ![]() |
![]() Join Date: Nov 2009 Location: Los Angeles, CA
| Not Ranked : 0 score It's quality tube that doesn't disintegrate from the fluid/vapor it's carrying nor compress under vacuum. That check valve is also a lot beefier than a second $20 OEM green plastic PCV you'd have to get so you don't pressurize the can. It was a bitch and a half of an install for me but it's worth it. The only problems you'll have once it's installed correctly? If you don't close the drain up, you'll have a rough idle and eventually throw a P0171. Don't ask how I know. I drained about 4oz of shit after 1700 miles in four months. Glad that's not flying through my intake manifold.
__________________ Purveyor of misinformation. |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Thanx to all, I have now read and have found Matt's website and already set him an email detailing my request. Oh, and I have already donated some time ago. . . |
| Brand name Mud Flaps vs. Garbage Cans | gtarman77787 | MazdaSpeed 3/6 - Appearance | 63 | 03-16-2011 12:04 PM |
| Red Bull's racing app lets you create your own track out of cans | Haltech | Automotive News | 0 | 03-14-2011 07:30 AM |
| Catch cans | Special--k | 2010 MS3 - Engine, Transmission & Driveline | 5 | 06-22-2010 09:00 PM |
| Abusive Lab Test: 5 Gallon Gas Cans | Haltech | Automotive News | 0 | 04-21-2010 03:20 AM |
| Under The Influence: Pop Top Can Cars are tin cans on wheels | Haltech | Automotive News | 0 | 09-17-2009 05:40 PM |
