> Gen2 MS3 General Discussion
 Old 09-17-2019, 11:57 AM   #1
ditchrat's Avatar
Posts: 13   (View Stats)
ditchrat is an unknown quantity at this point
Default Oil return line bolts
I have a leak that appears to be coming from my oil return, at the block. One of the bolts is pretty rounded and will need to be replaced. The diagram for it doesn't show the bolts part number tho. Anyone know?
I did find another diagram for the cx7, that showed two different part numbers for bolts. 9XF002147L and 9XF002127L. Will those work?
ditchrat is offline   Reply With Quote
 Old 09-17-2019, 12:00 PM   #2
andale927's Avatar
Posts: 193   (View Stats)
andale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant future
I bet that it's m6x1.00 20mm
Sent from my Pixel 3a XL using Tapatalk
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
turbo oil return pipe bolts speed23 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 11-06-2016 04:41 PM
Need help, bolts on steel line from CDFP shawn. Mazdaspeed3/6 General Discussion 4 03-02-2016 03:48 PM
Issue with 1 of 2 bolts on Turbo's Oil Return/Drain Pipe Zoomer_Esiason MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 11-14-2015 07:13 PM
Page generated in 0.23854 seconds with 22 queries
