![]() Join Date: Jun 2016
Rep Power: 0 ![]() Thanks: 2
![]() Join Date: Oct 2013 Location: Vermont
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 139
| Not Ranked : 0 score I had this code pop up as well, along with a P0455.
__________________ 2012 Speed3 - Velocity Red Mica Current Mods JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob |
(Thread Starter) | Not Ranked : 0 score Here's a 3rd gear pull after cleaning the MAF, first log was before in 2nd gear |
| Not Ranked : 0 score you have a rich code at idle but it get lean under boost, i would be careful until you solve the problem as small knock can be seen under boost probably related to this bad afr. it is usually related to a piping leak or ecm tune not compatible with the installed intake. cheap one without air straightener is likely to make this of different size etc...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | ItzCroix (01-09-2020) |
![]() Join Date: Jun 2009
If that is a Cobb OTS Stage 1 93 octane tune, what mods are you running with it? We need a LOT more information.
| The Following User Says Thank You to MSMS3 For This Useful Post: | ItzCroix (01-09-2020) |
(Thread Starter) | Not Ranked : 0 score Mods: Autotech HPFP COBB SRI COBB Turbo Inlet COBB CBE Corksport Solid Motor Mounts Corksport Short Shifter and Bushings |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| What map are you running? We can't tell you anything if we don't know what calibration you're using.
(Thread Starter) | Not Ranked : 0 score Stage1 93 v260, Sorry I thought it was in the datalogs at the top |
| Not Ranked : 0 score Did you add any of those mods or make any changes right before throwing that code? How long had it been running well before hand? Do you have older logs made before the problem we can review for comparison?
(Thread Starter) | Not Ranked : 0 score No Older Logs, I had to reformat my PC and lost all of my logs. It has been running great for 3-4 years now. Newest Parts added was the Solid Motor Mounts about 6 months ago. Just recently has that code popped up. |
| P0172 | AlanSpeed3 | Gen2 MS3 General Discussion | 1 | 10-08-2019 10:14 PM |
| P0172 issues | Syrza | 2010 MS3 - Troubleshoot/Diagnostics | 2 | 01-15-2017 07:01 PM |
| 2013 GEN PU CEL P0172 | BadBish76 | 2010 MS3 - Troubleshoot/Diagnostics | 6 | 09-08-2015 09:22 PM |
| Replaced my turbo and FP, now getting p0172 | woodfloor | 2010 MS3 - Troubleshoot/Diagnostics | 3 | 02-07-2014 08:37 PM |
| Help p0172 code | Speedster13 | 2010 MS3 - Troubleshoot/Diagnostics | 10 | 10-22-2013 11:22 AM |
