> Gen2 MS3 General Discussion
Like Tree4Likes
 Old 11-21-2019, 10:57 AM   #41
Police - Grammarhead
Vansquish's Avatar
PPF is paint protection film.
Clintb3astwood (11-27-2019)
 Old 11-22-2019, 07:24 AM   #42
Clintb3astwood's Avatar
Posts: 45   (View Stats)
Clintb3astwood is a glorious beacon of lightClintb3astwood is a glorious beacon of lightClintb3astwood is a glorious beacon of lightClintb3astwood is a glorious beacon of lightClintb3astwood is a glorious beacon of light
Ahh yes, thats on the list as well. gonna make sure there are no leaks on the lights for condensation, once i confirmed that, then ill be using the Lamin-x film
Clintb3astwood is offline   Reply With Quote
 Old 11-22-2019, 10:38 PM   #43
Oshiguru's Avatar
Posts: 102   (View Stats)
Oshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to all
Originally Posted by Clintb3astwood View Post
What is PPF? So the passenger side light is actually a brand new OEM in box headlight i got from a guy, he bought if from the dealership but ended up not needing it. he tried to return it but because he opened the box they wouldnt take it. i got that for $300!!!! The driver side light lens is a brand new lens from a pair i bought of a site base in china that makes headlight lenses. Both have the clear coat on them already. what i am going to do is compound them, then polish and add Lamin-X Clear covers. They go right over the headlight lens and protect it from UV damage.
They are precut to fit our cars too, so perfect fitment.
https://www.lamin-x.com/precut-film-...ht-covers.html
You can wet sand yours and polish them back to brand new, just add a UV based clear coat and they will look like brand new dealership lights.
Watch this video, best headlight restoration example ive ever watched.
https://www.youtube.com/watch?v=UG54...&index=75&t=0s
PPF is the same thing you linked from lamin X
I did polish/compound off the yellow from my oem lights then brought it to my friends shop who used automotive clear coat on them. I'm just surprised how quickly they did peel on my oem set. I do reverse into my driveway and the sun arcs over it, so UV rays all day.
Oshiguru is offline   Reply With Quote
 Old 11-25-2019, 07:22 AM   #44
So do you think i should go with 2k Clear coat, like the clear they use on cars instead?
 Old 11-25-2019, 10:28 AM   #45
can a mod remove Robertmits comment? it looks like spam. @vansquish
I also see youre from BC! i visited south langley in 2015, the most beautiful place ive ever seen!!
Last edited by Clintb3astwood; 11-25-2019 at 10:28 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Clintb3astwood For This Useful Post:
Vansquish (11-25-2019)
 Old 11-26-2019, 09:26 PM   #46
Oshiguru's Avatar
Yep. I love driving through South Langley with the posh neighbourhoods where they eliminate bike lanes for horse lanes hah
To reply to your above comment. Do the 2k clear, give it some time to gas out, then cover with PPF. I wish I did PPF to my M2 and after 2 drives to the interior the front end/headlights are peppered and too far gone for PPF
 Old 11-27-2019, 08:22 AM   #47
If i ever won the Lotto, id definitely move to South Langley!!!
Also check this video i linked, start at 5:30 seconds, it explains the different methods of clear you can use, the guy explains that spray on clears can distort the refraction of light coming out of the headlight, but idk tell me what you think when it gets to that part.
https://www.youtube.com/watch?v=UG54...index=73&t=39s
 Old 12-02-2019, 10:28 PM   #48
Oshiguru's Avatar
With all my research I never stumbled upon that video. Nice find. I wonder how it will look if you distort the refraction but balance it out with really good projectors.
My opinion of PPF still stands; however, that video makes me second guess going with too heavy of a clear
 Old 12-03-2019, 07:30 AM   #49
Yeah man, definitely one of the coolest videos ive seen on headlight restoration and the methods for clearing it, well remember factory headlights all come with a "UV" clear coat on it and they project fine, but like you said i guess it all depends on how heavy you are with the clear.
i think im gonna try ceramic coating over my lenses since they are both brand new.
 Old 12-03-2019, 08:08 AM   #50
The UV mix with the UV light to harden is the best option sadly its also the most expensive.
 Old 01-10-2020, 02:53 PM   #51
Final Update guys, got the lights on months ago, just been too busy to find the time to upload these.
I also did a Corksport front lip which you'll see in one of the pictures, Corksport BBK, SS brake lines, new rotors and pads and a ton of things you cant see. Scale coilovers with swift springs and ISC coilover covers, Moog front lower control arms, Moog inner and outer tie rods, Scale end links, Rear lower moog control arms, SPC upper camber arms, Whiteline front sway bar bushings, Corksport Rear sway bar with bushings, White line bumpsteer kit, with all that suspension work now i have an annoying front end clunk i didnt have before so now i gotta address that. Eric yarborough Oil return line since my stock one was leaking, valve cover gasket leak, Corksport Big bore TB, got an HTP 3.5 intake i havent installed yet etc etc
So yeah lots been done to the car, but the lights are on the car done, so enjoy the pics.
I dont have many demon eye pics, because the bluetooth controller keeps draining the battery so i disconnected it, will be wiring a separate switch in the spring to cut the power from the battery when the car is off.
Anywho enjoy the Photos and videos will be last.
20191127_210828_resized by stephen martindale, on Flickr
20191127_210854_resized by stephen martindale, on Flickr
20191127_214233_resized by stephen martindale, on Flickr
20191127_214239_resized by stephen martindale, on Flickr
20191127_214344_resized by stephen martindale, on Flickr
Demon eyes
20191127_214457_resized_1 by stephen martindale, on Flickr
20191127_214522_resized_1 by stephen martindale, on Flickr
20191127_215415_resized_1 by stephen martindale, on Flickr
20191127_215424_resized by stephen martindale, on Flickr
20191127_215427_resized by stephen martindale, on Flickr
20191127_220129_resized by stephen martindale, on Flickr
20191127_220133_resized by stephen martindale, on Flickr
20191127_222558_resized_1 by stephen martindale, on Flickr
20191127_222604_resized_1 by stephen martindale, on Flickr
20191127_222605_resized_1 by stephen martindale, on Flickr
20191127_222613_resized by stephen martindale, on Flickr
20191127_223009_resized_1 by stephen martindale, on Flickr
20191127_223722_resized by stephen martindale, on Flickr
20191127_223728_resized by stephen martindale, on Flickr
Painted Passive Demon eyes doing their thing
20191127_223746_resized_2 by stephen martindale, on Flickr
20191127_224421_resized_2 by stephen martindale, on Flickr
Out the shop day time pics
20191130_130639_resized_1 by stephen martindale, on Flickr
20191130_130721_resized_2 by stephen martindale, on Flickr
20191130_130730_resized_2 by stephen martindale, on Flickr
20191130_130748_resized_2 by stephen martindale, on Flickr
Sittin Pretty
20191202_203729_resized_1 by stephen martindale, on Flickr
CS Front lip lookin good
20191205_172527_resized by stephen martindale, on Flickr
20191211_165155_resized by stephen martindale, on Flickr
20191211_221510_resized by stephen martindale, on Flickr
Sadly had some condensation, i did open and clean then resealed it.
20191214_104413_resized by stephen martindale, on Flickr
20191214_151717_resized by stephen martindale, on Flickr
Ended up swapping back to an OEM driver side lens, it needs to be redone, again lol
20191220_080420_resized by stephen martindale, on Flickr
20191220_080429_resized by stephen martindale, on Flickr
20191220_080542_resized by stephen martindale, on Flickr
20191220_080550_resized by stephen martindale, on Flickr
Videos
received_559830794794187 by stephen martindale, on Flickr
received_1203053016553414 by stephen martindale, on Flickr
20200110_160236_51000009967573 by stephen martindale, on Flickr
20200110_160441_51125485185285 by stephen martindale, on Flickr
received_430720330946590 by stephen martindale, on Flickr
Bertospeed3 (01-14-2020)
 Old 01-14-2020, 01:33 PM   #52
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
Bravo....*slow claps*..... fucking bravo...
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
The Following User Says Thank You to Bertospeed3 For This Useful Post:
Clintb3astwood (01-17-2020)
 Old 01-17-2020, 07:09 AM   #53
Lmaaaoooo Thanks man, the traffic on this site is slow so im probably not gonna post anymore pics but when summer rolls around and register her again maybe ill do professional shots.
i have a consistent oil leak which i think is now the rear main seal so i gotta assess that, gonna do a turbo manifold too one shot and retune.
Page generated in 0.49425 seconds with 23 queries
