| RIP: November 21, 2012 ![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
Groaned at 20 Times in 12 Posts
(Thread Starter) | Not Ranked : 0 score Anyway what happens is you get your map all setup and loaded, find some turd to race; you turn off traction control, you floor it at the red light ready to go, revs come up to 3k or whatever, you let the clutch out with a brief slip, and the car just dies completely. Then, you can't just start it up again using the normal method. You have to turn the car off completely, remove key, reinsert, etc. Sucks. I was able to recreate this every time. Now, by simply leaving traction control turned ON (the default) every time I start the car it performs flawlessly every time. ************************************************** ************ My current settings are as follows (in case anyone gives a rats ass): FFS Rev Limiter: - Set to "only" 6,000 rpms. The reasoning is this... Most shifts occur between 5,750 - 6,000rpms. By keeping your foot to the floor between shifts, the FFS Rev Limiter being set at 6,000 rpms will momentarily continue to feed the engine with a small amount of fuel (keeping boost up) but not enough to significantly raise the engine speed which, when unloaded, is a dangerous practice on an unloaded engine. LC Rev Limiter: - Set to 2,800 rpms. This is the "nut" number, the make or break value. I have found it better to err on the side of too high rather than too low for 2 main reasons. Reason 1: If the value ends up being too high for your launch conditions, it is easy to mitigate your botched launch by just short shifting into 2nd gear once the turbo starts frying the tires. Sure you'll lose a few tenths in the 60' time but it looks better and is more consistent than a bogged launch :-) and, Reason 2: The hysteresis (resolution) for the LC Rev Limiter is very course in this ECU. For example, if you were to set the LC Rev Limiter to 2,750rpms, you'd see the rpms sometimes go back and forth between as much as 2,500rpms and 3,000 rpms; I've seen the non-adjustable hysteresis for this as bad as 500 rpms. This is quite a bit of variance and it makes it hard to launch the car not knowing if you'll be catching the engine on the "upswing" (fueling) or the "downswing" (throttle closed). If you happen to release the clutch as the engine is on the downswing it is surprisingly easy to fully stall the car or bog terribly especiallly if the track is sticky enough. Trial and error has shown that a slightly high LC Rev Limiter combined with a tiny bit of clutch slip yields the best, most consistent manageable results. Rev Limiter: - Set to 6,700 rpms due to stock mechanical limit. Speed Limiter: - Set to stock value of 186.41 mph (no mechanical speed limiter). Speed Limiter Hysteresis: - Set to stock value of 3.5mph (has no effect unless you actually reach the Speed Limiter :-) ) Vehicle Speed Threshold for LC/FFS - Stock value is 6.21mph (where the f do they get these numbers, are they initially metric numbers?). I have this changed to 3mph. This means that launch control is essentially disabled after the car hits 3mph allowing for big burnout. Reasoning is this: - At the drag strip you (usually) have to go through water box necessitating at least a mini burnout to dry the tires (and I believe even radials enjoy a slight heating). By having VSTFLCFFS set at 3mph I can pretty much just dump the clutch even just creeping along whenever and dry the tires. The problem with the stock value of 6.21 mph is that if I ride through the water slowly and then try to force a burnout, LC might be on and limit me to 2,800 rpms or whatever restricting me from doing a 2nd gear (55mph) burnout. - On the street, it is too easy to get caught off guard by a WRX if the traffic light turns green just as you are about to stop. This means LC will be on forcing you into a pussy launch as the WRX eats your lunch. By lowering VSTFLCFFS to 3mph I have a bit more control as to what I want to do at that split second (get some tire spin or just roll it out) - Regardless, this setting is definitely a matter of personal preference and I can see some people liking it set as high as 10 or even 15mph if they are just unable to control wheelspin.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... |
| The Following 2 Users Say Thank You to fortressofcomfort For This Useful Post: | kunfu (03-17-2012), scorpiorc10 (10-04-2012) |
![]() Join Date: Apr 2010 Location: Temple, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 317
Groans: 42
Groaned at 53 Times in 14 Posts
| Not Ranked : 0 score Have not had this problem (Just recently got my AP and have been playing with the LC and FFS) Works flawlessly for me... BTW I Have FFS set to 4250 - When you FFS you don't want the RPM's pegged at 6K... 4250 is a good range, because that's about where you will be when you get into the next gear. If you got it pegged at 6K and drop it into the next gear quickly you stress the motor. I Have the LC rev limiter set to 3500, 2800 diddnt work too well for me. I got pretty sticky tires, and I don't dump the clutch. For the speed limiter hystersis I have this set to 3.5 as well... don't wanna be stuck in nanny mode once you get going. It's always better to control the wheel spin on your own.
__________________ Sold: 2010 MS3 - I'll miss ya Now: 2013 Mustang GT |
| The Following 2 Users Say Thank You to drenkel For This Useful Post: | Bucker (03-09-2012), LatinKraze (03-17-2012) |
(Thread Starter) | Not Ranked : 0 score LC Rev limiter at 2,800rpms ends up at about 3,000rpms on the tach. I'm sure it varies from car to car. But with FFS at 4250 doesn't your boost start to drop between shifts kind of negating the purpose of flat foot shifting? I thought the whole point of ffs esp on a turbo car was to keep boost up between shifts. I understand the stressing the motor part but we'd all shift at 2000rpms if engine life was our main goal. Thoughts?
Groans: 42
| Not Ranked : 0 score If your not hitting full boost at 4K RPM's your car is fucked up. There's no reason at all to drop the clutch at 6K RPM's.
With my old Mustang (I know different beast) I used to FFS (we called it power shifting) so that the engine would hit the rev limiter between shifts. What am I missing?
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... Last edited by fortressofcomfort; 03-09-2012 at 10:14 PM. | |
![]() Join Date: Aug 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 82
| Not Ranked : 0 score From my experience with FFS, I have it set at 4750 rpm and when I no lift shift the engine loses significantly less boost than if I were to lift to shift. I don't have any numbers to compare right now but know the premise. Hope that helps. Crapatalk
__________________ 2006 Speed6 <- SURE TIP & SRI, COBB AP Stage 1+ -> Next: DP, RMM, RDFM & Brace, HPFP Internals. |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
Groaned at 52 Times in 48 Posts
| Not Ranked : 0 score Someone wanna log a normal shift, ffs with 4750, and a 6k? That'll show us the difference real quick. I myself have my lc at 2700 on stock tires and it works pretty well. My ffs is at 5k and I shift at or around 6k. |
Even Braden @ Cobb says 6k ish is the correct number for the FFS limiter. But god knows you all know I'm a numbers/facts guy, I don't trust no bench racing, so I'd love to see a test like Dantes is proposing. My fear is, with my AP at least, that we won't see much of anything either way. My AP only grabs about 5 data points per second. I bet a quick FFS can be performed in like a half second. I think the bottom line is we don't want to see the throttle tpp close, or boost psi drop, more than a few tolerant pct, during a FFS. If we do then we might as well lift shift.
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... | |
(Thread Starter) | Not Ranked : 0 score F. We're def missing something here. Just ran a test and, even with my current FFS limiter set to 6,000rpms, the engine just slams right into its 6,700rpm limiter if u hold the clutch and accel pedal down together (at say 50 mph, simulating a shift to 3rd gear). Now I've gotta figure this shit out. Something tells me this FFS limiter is rather some kind of LOW limit, as if to tell the ECU that any FFS action above this rpm is indeed an attempt at FFS. Cuz setting it to 6000 and thinking it will keep the engine from revving past 6000 rpms just isn't how it works. More to come.
![]() Join Date: Mar 2011 Location: Gillette, Wy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 782
Groans: 64
Groaned at 18 Times in 6 Posts
| Not Ranked : 0 score I guess I am slow but I set mine to 4950 and if I Ffs I still hear it bounce a couple times. But it definately holds boost vs dumping it all. Imo, no need for 6k when even lower you can still hear the limiter/bpv working.
__________________ COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS |
And the COBB docs are not correct! They say if FFS conditions are met (vehicle is traveling faster than LC vehicle speed limiter / Vehicle Speed Threshold for LC/FFS and clutch is depressed) then fuel delivery is blocked and other overrun parameters are enabled to keep the engine speed below the value set in the FFS limiter value. This is clearly not happening. Atr docs pg 56
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... Last edited by fortressofcomfort; 03-11-2012 at 06:19 PM. | |
| Not Ranked : 0 score Back to the OP's problem tho, i did a tcs off lc burnout just fine yesterday. i was at the car wash and wanted to dry tires. Turned off traction control, hit LC at 27 and dumped the clutch...burn out came as requested. |
| The Following User Says Thank You to dantes5823 For This Useful Post: | fortressofcomfort (03-17-2012) |
Groans: 64
| Not Ranked : 0 score This week I will try and post a vie of how mine is working, because I haven't experienced any issues similar to yours.
Groans: 433
| Not Ranked : 0 score why are you using LC on the ms3 anyways? just learn how to launch. This isn't a two-step or anything, it's just a lower rev limit if you suck at throttle control. When you say you turn off traction control, you just hit the button or are you pressing and holding during start to partially disable SWAS?
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
See comment above regarding the tach. No the FFS is to make driving the car more fun. What you truely desire is anti-lag. The AP is capable of adding this in. HOWEVER, it causes extremely high EGT's and will wear the shit out of everything. To do anti-lag properly you would need full control of the EGR to help keep combustion temps down. I think most people assume LC/FFS is anti-lag when it's not. The LC/FFS is just a fun and simple rev limiter, that's all. Anti-lag is what sounds like a machine gun, and makes 20psi of boost standing still, and between shifts.
__________________ Fueled by the haters. | ||||
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
| Not Ranked : 0 score I build boost with AP LC....
__________________ |
| The Following 2 Users Say Thank You to triplejumper18 For This Useful Post: | Boosted Beluga (03-12-2012), breakfstincluded (04-13-2012) |
| Not Ranked : 0 score Using the AP's LC will not build boost, you will hear your BPV but that's "fake" boost. If you are building boost, please supply a log I'd like to see it. Give ATR a look see. If you know who the anti-lag works you will see how to do it. I don't want to tell because I don't want a blown motor on my conscience if you do it wrong.
| Not Ranked : 0 score You can build boost with LC, lots of cars do. My buddy's sti builds like 10psi at the strip. And IIRC anthony (superskater) used to build a significant amount as well. The throttle plate is open, the turbo is spinning, and boost is possible.
| The Following 4 Users Say Thank You to djuosnteisn For This Useful Post: | Boosted Beluga (03-12-2012), breakfstincluded (04-13-2012), Nataphen (03-12-2012), triplejumper18 (03-12-2012) |
Groans: 196
| Not Ranked : 0 score http://www.mazdaspeedforum.org/forum/foru...-lc-ffs-90471/ "COBB Tuning is pleased to announce the availability of Launch Control and Flat-Foot Shifting for 2nd Gen (2010-2011) MAZDASPEED3s. Launch Control limits engine RPM to a user-set value when launching to build boost and increase launch consistency."
Groans: 433
| Not Ranked : 0 score A-la brake boosting? yeah, 2 step=basically retarding the shit out of ignition timing iirc moving the combustion event into the turbine itself.
Groans: 136
| Not Ranked : 0 score I'm not reading all the posts above. My opinion is more important than everyone else's in here anyways (except for my <3 Dustin. Kisses). COBB FFS/LC pulls fuel to lower RPM (OE rev limit strategy). A true 2-step retards timing. Disable FFS/LC. Buy N2MB WOT Box.
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | djuosnteisn (03-12-2012), fortressofcomfort (03-17-2012) |
| Not Ranked : 0 score My <3 silva Yup, wot box cuts spark... which is basically like super retarding it lol. But even with the AP's LC strategy, you can still build boost. I think the amount of boost will depending on the LC rpm as well. PS, i still use a wot box in my ms6, for the exact reasons silva mentioned.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 03-12-2012 at 01:58 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #24 | ![]() |
Groans: 64
| Neutral : +1 score
__________________ COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS | |
| The Following User Says Thank You to 2k4_8 For This Useful Post: | Celestspeed3 (03-13-2012) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Sweet thanks. I have mot been able to build boost with LC my FFS looks the same as yours. But my LC is also set lower than yours maybe that's why. DJ, what WOT box are you using?
| The Following User Says Thank You to Celestspeed3 For This Useful Post: | djuosnteisn (03-14-2012) |
![]() | | #26 | ![]() |
![]() Join Date: Jun 2011 Location: Aurora, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 461
Groaned at 20 Times in 5 Posts
__________________ 2011 MS3 || Tech Pkg || Shark fin || || HTP 3.5 Intake || || BNR4 || CS TMIC || CS CBE || || CS Boost & BpV Tubes || DENSO IVT22 || FORGE BPV v2 || || AT Internals || COBB APV3 || CNT DP || Koni Yellows || H&R Springs || || JBR Shift Knob || JBR Stage 2 SSP || JBR SSBushings || || JBR 88 RMM || JBR 80 TMM || JBR 80 PMM || JBR RSB || JBR RCAs || JBR EGR Block/Delete - OCC - Small Battery box || \\|// AJ 91 & E85/91 Mix Tunes by A.J \\|// || Window Tints, Lamine-x Headlights/Fogs, Tinted Tails, JDM Rain Guards || | |
![]() | | #27 | ![]() |
Groans: 433
| Not Ranked : 0 score It should, but I would also disconnect your SWAS. shit is invasive.
![]() | | #28 | ![]() |
| Not Ranked : 0 score yeah but then when I try driving slow in a parking lot all of a sudden the electric power steering says fuck you! Ive disc. SWAS when I was having @phate tune me, It gave me MOAR power in the lower gears... Torque to be exact... + lifted boost cap. With @jbarone 's 80 Duo Trilogy mounts there should not be any significant torque steer.... Not that torque steer ever was hard to control for me .. in fact it made it fun in a dangerous way. Come to think of it I should have taken that shit off when I went to the drag strip.... Oh Well I will go there when I get my 17x9 with 245/40-17s less wheel weight and moar grip MOAR POWER *(@#&(@*#(@*#.
![]() | | #29 | ![]() |
![]() Join Date: Mar 2011 Location: New jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score It's pretty funny using the traction control with launch control , it'll let me smoke the shit of tires for a few feet then kicks in and feathers the throttle for me , but that's for lazy people.
__________________ When you decide to be something, you can be it. That's what they don't tell you in the church. When I was your age they would say we can become cops, or criminals. Today, what I'm saying to you is this: when you're facing a loaded gun, what's the difference? |
![]() | | #30 | ![]() |
Groans: 196
| Not Ranked : 0 score I have LC at 4500rpms and I've seen as much as 5+psi when I've launched but I have not waited to see what the max PSI is.
| The Following User Says Thank You to triplejumper18 For This Useful Post: | breakfstincluded (04-13-2012) |
![]() | | #31 | ![]() |
WOT Box - N2MB Racing Fairly simple install, not sure if ECM pin out is the same on gen pu as it is on gen done... but might be close enough. If you have a manual it'd be simple to verify.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | Celestspeed3 (03-14-2012), silvapain (03-15-2012) |
![]() | | #32 | ![]() |
| Not Ranked : 0 score I had a chance to reviewmthe logs and as silly as this is, I wasn't holding my foot to the floor during launching. I would just push it down enough to hit the limiter. My car makes about 3psi if I floor it.
![]() | | #33 | ![]() |
I HAVE however not worried so much about FFS. I just hold right foot to floor, shift at 6k, and complete shift quickly. Shift is completed by 6700 unless missed. I really don't think I will blow the motor occasionally hitting the 6700 rpm limiter. So I guess above all TC must be disabled for spirited driving then I'm gonna have to do like silvapain says and disable LC/FFS. Too bad. It does make launching easier in this car but I guess I will just have to man up on one more skill. Maybe if someone local like Will wants to stop by one day to make sure I'm not hallucinating that would be good.
![]() | | #34 | ![]() |
Groans: 64
![]() | | #35 | ![]() |
Also I have posted the basic contents of this thread along with my current .ptm over at http://www.cobbforums.com/forums/for...77-Mazdaspeed3 so hopefully Braden will verify everything is setup correctly and I didn't screw something simple up.
![]() | | #36 | ![]() |
Groans: 64
![]() | | #37 | ![]() |
I have also applied Abilor's and Bucker's tuning recommendations separately in the past. Both are gains, Bucker's really rips esp with those ignition timing maps of his, but I just get too much noise (knock) and high BATs with their tunes. They are good tunes but just really on the edge and require only the finest of dino juice in the tank. I'm too cheap and I need a tune that works with pretty much any 93 octane around, and I don't want any noise, so I have chosen to stick with Cobb's OTS stage 1 stuff. I'm happy with 300ish at the crank for now. Whatever works. Boost tuning isn't the issue.
![]() | | #38 | ![]() |
![]() | | #39 | ![]() |
Groans: 64
![]() | | #40 | ![]() |
Groans: 196
| Not Ranked : 0 score Is your AP and ATR up to date?
| traction control light on.... | countrymanjeff | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 17 | 04-01-2016 07:08 PM |
| can't stop, ABS/Traction Control lights, no cruise control...vacuum leak? | btstarcher | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 06-17-2011 11:06 PM |
| Customizing Traction Control with LC | Trader | Cobb ATR Support | 6 | 08-19-2009 10:10 PM |
| Traction control light | tuners | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 07-20-2009 06:14 PM |
| Traction Control (MS3 specific) | SLS MS3 | Cobb ATR Support | 15 | 06-08-2009 01:08 PM |
