> Gen2 MS3 General Discussion
 Old 01-17-2020, 06:48 PM   #1
Sonofnothing's Avatar
Posts: 33   (View Stats)
Sonofnothing is on a distinguished road
Default Super rich AFR
Freektuned last summer, everything was fine until recently. My obd2 cable was broken , and I sent my AP back to cobb for a repair. After not having a visual for a little while, I was surprised to see my AFR so low 9.70 at wot.
I checked for boost leaks, and as far as I can tell, everything is cinched up tightly. I've attached 3 datalogs. In one, I started a pull, let off the throttle, and when I got back on it, the afr was at target, around 11ish. One is a clean 3rd gear pull from the fresh tune from Justin.
Maybe this is because of my snow tires, and wheels spin, but even when I gently roll on the throttle, or do a 4th gear pull with very minimal chance for wheel spin, I still see it. Thanks for any input.
'13 ms3 * 72k * FREEKtuned * Accessport v3 * COBB SRI/TI * Autotech HPFP * ETS TMIC * CS fully mounted * CS short shift plate/bushings * Goodyear Eagle F1 Asymmetric 3 * dash designs suede * weather tech floor mats.
Sonofnothing is offline   Reply With Quote
 Old 01-18-2020, 09:01 PM   #2
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
Wheel spin and changes in steering angle during a pull can cause this.
2018 Audi RS3
2007 Acura TSX 6MT
Super rich, stumbling idle csmaan12 2010 MS3 - Troubleshoot/Diagnostics 14 07-05-2016 07:49 AM
High knock super rich afr ciezczak1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 07-24-2013 11:25 AM
KR Spike/Super rich at WOT sidekick MazdaSpeed 3/6 - ECU Computer Tuning 30 07-26-2012 05:43 PM
Super rich may avoid super expensive cars because of bad image Haltech Automotive News 0 10-02-2008 06:10 PM
Page generated in 0.22270 seconds with 22 queries
