> Gen2 MS3 General Discussion
 Old 03-26-2014, 11:10 AM   #1
meow.
msew's Avatar
Posts: 828   (View Stats)
msew is the leader of the worldmsew is the leader of the worldmsew is the leader of the worldmsew is the leader of the worldmsew is the leader of the worldmsew is the leader of the worldmsew is the leader of the worldmsew is the leader of the worldmsew is the leader of the worldmsew is the leader of the worldmsew is the leader of the world
Default Why doesn't the engine crank over..
Long story short, my friend works at a shop and they got a 2012 MS3 in
They slapped a 2013 motor in it from a junk yard because the other motor blew
(What had happened was... the oil filter blew off and spun bearings because someone put the wrong filter on )
Car cranks once and then it stops.
They checked all the obvious, and then they asked me to consult with MSF
Anyone? Thoughts?
2012 Black Mica MS3 w/ Tech
BUNCH OF RICER MODS, MAYBE GOT LIKE +5WHP | ~ TUNED BY NISHAN
~~ NJ NATOR ~~
msew is offline   Reply With Quote
 Old 03-26-2014, 11:19 AM   #2
Voltwings's Avatar
Posts: 3,713   (View Stats)
Plenty of things it could be, but likely a sensor or ground strap not plugged in / attached. Really not enough information to go off of here to make an accurate assumption.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
chaser27 (03-26-2014), msew (03-27-2014)
 Old 03-27-2014, 07:37 AM   #3
meow.
msew's Avatar
They gave up and sent it to the dealer. They also had to rent the lady a rental, and her son a rental. Remind me to always do my oil change myself -.-
Sent from my iPhone using Tapatalk.
~~ NJ NATOR ~~
 Old 03-27-2014, 07:42 AM   #4
Police - Grammarhead
Vansquish's Avatar
Always do your oil changes yourself. (There, now you've been reminded.)
Doesn't turn over, Whining noise in engine bay Opdahl Mazdaspeed3/6 General Discussion 8 01-18-2013 06:50 PM
PTP PCV fix doesn't fit in new engine kgb MazdaSpeed 3/6 - Turbo Induction 22 06-09-2010 10:40 AM
Page generated in 0.25047 seconds with 22 queries
