> Gen2 MS3 General Discussion
 Old 11-10-2015, 09:31 PM   #1
theandrewlane's Avatar
Posts: 14   (View Stats)
theandrewlane will become famous soon enough
Default Winter Wheels - 17x8 +35mm?
This is my first winter with my genpu MS3, and I'm searching for some cheap eBay rims.
I found these 17x8 wheels that should fit, I just don't know about the 35mm offset. I have stock suspension, will these rub? Does the $399 price tag mean these wheels are $hit?
What's a typical tire size for this setup?
2013 Black Mica Mazdaspeed 3 w/ Tech Package
Corksport SRI, Corksport TIP, Corksport HPFP, Denso ITV22 Plugz, Cobb AP V3, Stratified Stage 2 91 Flash Tune, Passport X70, Laser Veil G5
theandrewlane is offline   Reply With Quote
 Old 11-11-2015, 05:20 AM   #2
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
those should be fine. I'm running 17x9+48s which puts my wheel rim as close to the fender as a 17x8+35. With 205 or 215 tires you should be fine with no roll or anything.
Blue Pu.
 Old 11-11-2015, 05:31 AM   #3
PUGENE's Avatar
Posts: 1,902   (View Stats)
PUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the worldPUGENE is the leader of the world
Groans: 61
If you're investing in a winter set, steelies + blizzaks can be had for ~5 or 600 iirc
Precision: PTE 5858
Kozmic: Downpipe//Dumptube//Oil Return&Feed//EGR Delete
Tial: 44mm EWG
HTP: 3.5" Intake + 51r Battery Tray
CPE: Stage 2 RMM//Manifold
JBR: SSP//Shifter Bushings//Knob//TMM//OCC
UR: CBE
HKS: SSQV4
CS: Springs
NGK 1-Step Colder
POWERED BY PURPLE DRANK
I'm from Jersey...the Drama State.
PUGENE is offline   Reply With Quote
 Old 11-11-2015, 07:07 AM   #4
pmartz16's Avatar
Posts: 1,140   (View Stats)
pmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the world
find a set of mazda 3, 5, 6, or nc miata wheels in 17 for 50-100 then get snow tires for them for 450. Thats what I did with mazda 5 wheels
2008.5 Mazdaspeed 3 BM - Built BT Realgib3 Tuned
2014 Mz3 MG
pmartz16 is offline   Reply With Quote
 Old 11-12-2015, 07:14 PM   #5
hamfisted's Avatar
Posts: 92   (View Stats)
hamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant futurehamfisted has a brilliant future
If you're looking for winter wheels & tires, going wider than stock on the wheels is probably something you want to avoid. (assuming you want to put the snow tires on them and not on your stockers)
2012 CWP non-tech
CS SRI+TIP, Autotech HPFP internals, CS catted racepipe, CS BPV, Stratified E33 tune,
CPE stage2 RMM, Enkei Fujin 17x7
hamfisted is offline   Reply With Quote
 Old 11-12-2015, 08:13 PM   #6
speedre's Avatar
Posts: 103   (View Stats)
speedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to beholdspeedre is a splendid one to behold
Groaned at 7 Times in 3 Posts
Agree with hamfisted, thinner always better to cut through snow. I had some Thule chains too that saved my ass a few times. Not good to have on for an extended time, but nothing beats them if things get really rough out there.
speedre is offline   Reply With Quote
 Old 11-18-2015, 09:57 PM   #7
Fusion_MS3's Avatar
Posts: 72   (View Stats)
Fusion_MS3 is a glorious beacon of lightFusion_MS3 is a glorious beacon of lightFusion_MS3 is a glorious beacon of lightFusion_MS3 is a glorious beacon of lightFusion_MS3 is a glorious beacon of light
Just to add to this... I ran an 18x8+35 with a 225/40/18 lowered on CS Springs, and the rear rubs with 3 people in the car. But if you're stock height and NOT running 225s you should be more than fine.
Fusion_MS3 is offline   Reply With Quote
 Old 11-19-2015, 12:22 AM   #8
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Leaving aside the potential rubbing issues, 35mm offset is going to sand your sides pretty bad in the winter. I'm running a 205/50/r17 tire with 40mm ET and it's not that pleasant, they're as wide as my summer 48mm ET with 225mm tires on them.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
17x8.25 with 35mm offset redline 2010 MS3 - Wheels & Tires 4 04-22-2013 09:34 AM
MB Wheels Weapon 17X8 robertoms MazdaSpeed 3/6 - Wheels & Tires 13 09-10-2012 10:18 PM
Varrstoen Wheels - ES 2.2.1 (18 x 8.0 (+35mm) PapaSmurf 2010 MS3 - Wheels & Tires 30 06-09-2011 12:17 PM
Speed with MX-5 wheels and 35mm spacers IshiKage MazdaSpeed 3/6 - Wheels & Tires 20 01-12-2011 04:25 PM
Page generated in 0.27681 seconds with 27 queries
