| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() Join Date: Jun 2014 Location: Rolling Meadows, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42
(Thread Starter) | Not Ranked : 0 score I got my Stratified E30 Flash Tune ready to go, driving my car to 1 bar left to follow the initial instructions on the first fill up (4 Gallons E85, and the rest with 93). I'm confused though, when I need to fill up again, usually at 2 bars, how much do I have to fill up of each to achieve the same mixture? Or should I just keep driving to 1 bar and do the 4 gal E85 and 93 the rest, each time I fill up? Thanks..
__________________ 2011 Mazdaspeed3 Mod List: FREEKTUNED ETS TMIC Autotech HPFP Internals CS Stage II SRI + TIP Tial QR UR Catback UR Catless Test Pipe Damond RMM Damond SSP |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score Their tune is still somewhat conservative, drive to 1/4 tank and fill up 3 gals E rest 93. If you go over or under its fine but I would lean toward extra E vs extra 93.
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
| The Following User Says Thank You to speedfreak44 For This Useful Post: | csmaan12 (10-11-2015) |
(Thread Starter) | Not Ranked : 0 score Cool that's exactly what I wanted to know, thanks. I figured it's a little more lenient, but I also don't want to blow anything up.
![]() Join Date: Sep 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 789
| Not Ranked : 0 score The tune is designed to run anywhere between 30ish percent and 40ish percent. It's not really ideal to fill up X gallons of E, then top it off with 93, although it wont hurt anything. If you're an anal retentive guy like me, you will need to fill up with the exact amount of E and an exact amount of 93 every time. I shoot for the low end and run a 30.68% mix. So when I fill up, I never actually put in a full tank of gas. I'll put in either: 2 gallons e85: 5 gallons of 93 or, 3 gallons e85: 7.5 gallons 93. The math is as follows assuming you're doing the 3:7.5 fill-up: (3(0.85)+7.5(0.10))/14.5 = .3068 ~ 30.68% I have a gen1 so my gas tank is 14.5 gallons as you will see as the last number in the calculation above. This is only if you want to be super accurate about it. I find it helps with fuel trims if you are more accurate.
__________________ 2009 MS3 GT - JBR SRI/TIP - CS Racepipe - TurboXS CBE - Cobb AP - Stratified E85 Flash Tune Stg. II (294/342) - Stratified Guardian Angel - Autotechs - CP-e S2 RMM - KW V2 - SPC RUCAs |
| Not Ranked : 0 score When I ran their flash tune my trims were all less than 5% despite never following exact math
| The Following User Says Thank You to speedfreak44 For This Useful Post: | csmaan12 (10-14-2015) |
Groans: 189
| Not Ranked : 0 score Don't top off. Keep the ratio the same; document how many gallons it takes at whatever marking your fuel gauge is at and use that as the basis for your ratio according to the cheat sheets.
__________________ |
Thanks, if I end up being too lazy to math things then I'm going to follow your steps except mine was a 4/9 initial fill up. So I'd have to adjust to that. Apparently my gas tank is 15.9 gallons though on the pu.
__________________ 2011 Mazdaspeed3 Mod List: FREEKTUNED ETS TMIC Autotech HPFP Internals CS Stage II SRI + TIP Tial QR UR Catback UR Catless Test Pipe Damond RMM Damond SSP | |||
Groans: 189
| Not Ranked : 0 score It is lenient, but over time the disparity will grow significantly if you always top off; If you're always doing say 3 and 8, over time the mix will dilute further (which is exacerbated by not draining the tank to near empty). This is why I recommend filling via the 1/4 tank method (calculate mix per 1/4 tank and use that ratio to fill up).
| Banned ![]() Join Date: Feb 2012 Location: Pounding my dog in da bung
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
Groaned at 35 Times in 6 Posts
| Not Ranked : 0 score Hey bud, Ive personally been running E30 now for about 15k+ miles. The first couple of fill ups i was super anal about the correct ratio, but then that got real old real quick. Your "suppose" to run 4gal of E per tank of gas. After about about 1k miles on the E tune i got lazy and now i go anywhere from 4-5 1/2 gals of E per tank. My LFTS stay +/- 3 at all times, my AFR's are spot on, my fuel pressure stays between 1870-1920 at WOT, and in that 15k miles i have never seen knock above 1.2. Alota asshats here say im dumb or what ever, but what i say is that 15k+ miles on E, and I just swaped my turbo, and the K04 is still picture perfect. Just sold it to some chump for 400$. So I say to you and take with with a grain of salt.... dont go under 4gal per tank and dont go over 50/50 and you'll be right as rain. |
Groans: 189
| Not Ranked : 0 score He can go over 50/50 if the car is prepped for it.
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,746
Also, learn your fucking homophones.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
Groans: 438
Asshats aren't calling you dumb. People who are smart and educated on this platform are calling you dumb, because you have said a lot of dumb shit. And you come off as some toolbag who can't complete a sentence properly. Still hitting 22.8 accurately all day every day? OP, listen to the more educated people in this thread. You want to try and be as accurate as possible when filling up. Does it need to be absolutely perfect, no, the ECU can adjust to allow for some leeway with the ratio.
__________________ All good things must come to an end... | |
| Not Ranked : 0 score |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | Thepedigree13 (10-15-2015), Tifosi42 (10-15-2015) |
![]() Join Date: Feb 2013 Location: Montgomery, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 204
Groaned at 49 Times in 12 Posts
| Neutral : -1 score OP - as a general principle, yes it is ideal to fill up with exact ratios of E85 each time. In practice, is it really detrimental if you are not being perfectly precise with the ratios? No. When I fill up, I put in 4 gallons of E and then top it off with 93. If I make it to the gas station within 10-15 miles of my gas light turning on that will generally mean I'm putting in about 10 gallons of 93 (I wait till the gas light comes on to fill up). If I can't fill up right away (only 2 gas stations in town have E85 and they are inconveniently located) it can be as much as 11 gallons of 93. My trims are close to zero (+/- 2 or 3) regardless of whether I put in 10 or 11 gallons of 93. The ratio of E85 to 93 varies by less than 2% between putting in 10 or 11 gallons of 93 (28.5% compared to 26.6%). That simply isn't significant enough to affect your trims or alter your knock threshold. That obviously doesn't apply if you fill up from different points, e.g. sometimes you get gas when your gas light turns on, sometimes you get gas when you're at a quarter tank, etc. If you vary the points from which you fill up, you need to consistently use exact ratios because topping off with 93 will result in very different ratios each time. So basically, if you want to do it "right" then yes, always fill up using exact ratios. But if you want to do it easier (and fill up less often because you're actually filling your tank) just top off with 93.
__________________ 2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016! BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn |
![]() Join Date: Mar 2012 Location: Burnsville, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 215
| Not Ranked : 0 score Over the summer I ran Stratified ots for e30? (4 gallons of e). I got used to a good feel for how much farther I could drive with the gas light on. So I pretty much always filled from nearly empty. I only could experiment this, as I pretty much drove to the same places every week. After a while instead of topping off with 91. I just did 4 gallons of e and 9 of pump. For the sake of consistency. Was I doing it wrong too? Would like to know for future references.
__________________ SOLD - 2007 Mazdaspeed3 210k Current - 2007 Mazdaspeed6 |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score i dont understand why this is so hard? Just always fill up with a constant ratio. 4 gallons in a Gen 1 works out to damn as no different 25%, and in a Gen 2 is 25%. Therefore, every time you go to the pump its 1 gallon of E85 for every 3 gallons of 93, which works out to 25% ... simple. If you have half a tank, that's 7.5 gallons you need to fill up. You can do 1.5 and 4.5 for 7 gallons. Close enough. I can get my tank damn near full every time doing this, and my ratio is always perfect, and i dont have to wait until my tank is empty to fill up.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following 5 Users Say Thank You to Voltwings For This Useful Post: | csmaan12 (10-15-2015), Enki (10-15-2015), g00s3y (10-15-2015), rfinkle2 (10-15-2015), WAMBUSHHHH! (10-21-2015) |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score Turn on one e85 and one gas pump and put a funnel in your fill neck. Then put the e85 on the first click, and put the gas on the 3rd click. That's the most accurate way for sure. ![]() |
![]() Join Date: Jan 2013 Location: San Diego, CA
| Not Ranked : 0 score Loogy taught me this a while ago and it's saved me damn near 15 seconds of math/fill up.
__________________ 2009 Mazdaspeed3 GT Cobb AP v3 // Freektuned // AT Internals // CP-e 75 duro RMM // HTP 3" Full Intake // MS CBE // GFB Respons // JBR Round Knob // JBR SSP and bushings // JBR RSB // JBR flaps // S204 front lip // H&R springs // Koni Yellows // Ground Control bump stops // Denso ITV22 // Block8head pod with Prosport boost gauge // LED Interior // Tenzo Type-M // PAC AOEM-MAZ3 // Alpine MRP-M500 // Kicker CVR's // Escort Passport 9500ix |
(Thread Starter) | Not Ranked : 0 score I think I figured out a ratio on my last 4 fill ups. I've been doing 1/4 tank fill up, which is 11 Gallons. So 3.5-3.75 of E85 and 7.5-7.25 of 93....am I doing it right? Given that at 1/4 tank I have about 4.5 Gallons left. After fill up LTFT starts at .78/4.69 and settles after a couple miles to -.78/4.69 and stays that way until next fill up pretty much.
![]() Join Date: Aug 2013 Location: Round Rock, Tx.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 85 Times in 26 Posts
| Not Ranked : 0 score There are ethanol calculator apps on iTunes and Android. Search google play for "e85 Mix Calculator" if you want to keep it exact. You should do a test on the e85 and the gas your using to see how much E comes pre mixed from the gas station to make sure your adding the correct amount to keep it exact. The gas station's ratio changes with the seasons depending on how far north or south you are. Using a cheat sheet such as the one rfinkle posted above is a good way to go as well. |
Just curious how do I determine how much %E I have left over in the tank before fillup. Is it always assumed to be E10?
Groans: 189
| Not Ranked : 0 score Or he could use one of the three I've made and have been available for a couple of years now.
By the looks of it, I should be adding more E at the pump and less 93, because I'm basically doing the math based on the fact that I need 11 gallons to get from 1/4 to full. BUT according to the sheets, an E30 mix can be achieved (with E70 winter blend) by mixing 4/7 which I was slightly off. Now am I wrong to top off, or is it okay if I know exactly how much I need from a certain fuel level to achieve top off. For example, needing 11 gallons from 1/4 - Full...therefore using 4/7 mix?
![]() | | #24 | ![]() |
Groans: 189
| Not Ranked : 0 score Use the HTML version on your phone which does remix calculations for you.
| Pupu FTL... | CWP_MS3 | MazdaSpeed 3/6 - E85 Fueling | 69 | 09-30-2014 06:33 AM |
| Galaxy Note 3 and Pupu fail... | CWP_MS3 | Gen2 MS3 General Discussion | 21 | 04-27-2014 12:37 PM |
| Frnchplayr15's PuPu Mazdaspeed 3 Build Thread | Frnchplayr15 | Members Rides Gallery | 8 | 04-05-2014 06:11 PM |
| x2's 2013 lasers go PUPU build thread! | xecuter2 | 2010 MS3 - Build Diaries | 26 | 09-17-2013 08:44 AM |
| Transfer Case won't refill | rrussell50 | MazdaSpeed 6 - Engine, Transmission & Driveline | 9 | 08-15-2011 08:51 PM |
