| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() | | #41 | ![]() |
![]() Join Date: Apr 2013 Location: Chattanooga, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,760
Groans: 42
| Not Ranked : 0 score
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci |
![]() | | #42 | ![]() |
Groans: 189
| Not Ranked : 0 score Actually that may not necessarily be true. Back when I was stock turbo, with stock EBCS in stock configuration, I could hit 17 PSI on an ots map, but as I added timing boost dropped off while airflow remained the same. I was hitting 100% WGDC from about 4500 to 6k rpm.
__________________ |
![]() | | #43 | ![]() |
Groans: 42
| Not Ranked : 0 score hmmm. that's interesting.... I'm thinking one of two things. Maybe you can give some insight.. 1) As you increased timing, you were getting better evacuation of the cylinder increasing Volumetric Efficiency, but having less energy left to spool the turbo. Boost drops, airflow remains the same. 2) I changed my mind... was originally thinking something about stock EBCS needing a restrictor pill with higher boost K04's, but I'm back to thinking number 1.
![]() | | #44 | ![]() |
![]() Join Date: Jul 2012 Location: Anaheim, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
Groaned at 7 Times in 5 Posts
-1.00 2.50 4.50 7.50 12.00 14.00 16.00 17.00 18.50 19.50 ^ That timing curve is with the recent edit of taking away .5 of a degree at 3000rpm and 1.5 degrees from 3500-4000rpm ^ So what you guys are saying is to just target 18psi as a peak and taper it off to 17? current boost targets from 2500 RPM and on is as follows: 21.00 21.00 21.00 21.00 21.00 19.00 18.00 18.00 18.00 18.00
__________________ Self Tuned: 310 HP / 355 TQ on E85 50/50 2012 black speed3 - AP - CxRacing FMIC - COBB SF - COBB TIP - Ebay catless long DP - XS Power Exhaust Manifold - ARK CBE - AutoTech internals - Rotella T6 - JBR 88 Duro RMM - JBR MudFlaps - DevilsOwn M.I. - GFB Respons 50/50 - AEM DryFlow - NGK Step Colder Instagram @ mpodboj www.matiaspodbojracing.yolasite.com | |
![]() | | #45 | ![]() |
Groans: 42
I'll update this when I get home with a better "recommendation" of numbers, but not quite like that. You have more of a "Step" function there ^ with the 2500 number beyond the surge line. Again, I'll update this in a bit when I'm not at work and have access to my tools, but something more like 15, 18, 21, 21, 20.5, 20, 19, 17.5, 16, 14 If you look at the compressor chart I posted above. I put in the boost pressures you were running at each 500 interval from your logs. The y-axis is the pressure you are running, the x-axis is the amount of airflow and the part I was really looking at is the curved lines. The line is supposed to signify a shaft speed of the turbo. How many rpm's your turbo needs to spin at to achieve said boost at said airflows. Take it all with a grain of salt because assumptions are made in plotting where you fall, but it looks to me as if your current boost targets fall off slightly before they have to (in that "V" section at the right of the plot) If you can hit 17.5 at 6k, you can hit higher than 17.5 at 5500 is what I'm getting at. With the added shaft speed at 5500 that comes with higher boost, you shouldn't have to work as hard to hold 17.5 at 6k.
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci | |
| The Following User Says Thank You to chaser27 For This Useful Post: | OCspeed (12-08-2014) |
![]() | | #46 | ![]() |
boost in the 5500 region when looking at the 6000 region and the given boost its making. I'll check back later when you are not at work
![]() | | #47 | ![]() |
Groans: 189
| Not Ranked : 0 score No I was saying you should reduce target boost (and wgdc) at 3k down to 18. Rest can stay as it is since you're on corn and not pushing timing to the limit.
![]() | | #48 | ![]() |
Groans: 42
| Not Ranked : 0 score Hey man, I looked at some numbers and my estimate from before was pretty much what they should have been. It may get you a little more area under the curve. You're already pretty quick with a 60-100 time of 5.67 seconds. I can't find the thread right now, but IIRC you're doing good for a K04.
![]() | | #49 | ![]() |
3000 rpm boost target
![]() | | #50 | ![]() |
Groans: 189
| Not Ranked : 0 score It won't hurt to flatten out the boost curve, just don't push it too much past where it is at 6k+.
![]() | | #51 | ![]() |
Groans: 42
| Not Ranked : 0 score I pretty much think anything is worth a shot haha. Maybe you'll get 5.63 seconds ![]() But as he said ^, we aren't saying up the boost everywhere, just in that small section
![]() | | #52 | ![]() |
New boost targets are as follows starting from 2500 RPM: 15.00 18.00 21.00 21.00 20.50 20.00 18.25 17.50 16.00 14.00 Instead of pushing (or trying to push) 19psi at 5500, like suggested above, I input 18.25psi and to first see if it makes a noticeable difference carrying the boost in the other areas of the curve
__________________ Self Tuned: 310 HP / 355 TQ on E85 50/50 2012 black speed3 - AP - CxRacing FMIC - COBB SF - COBB TIP - Ebay catless long DP - XS Power Exhaust Manifold - ARK CBE - AutoTech internals - Rotella T6 - JBR 88 Duro RMM - JBR MudFlaps - DevilsOwn M.I. - GFB Respons 50/50 - AEM DryFlow - NGK Step Colder Instagram @ mpodboj www.matiaspodbojracing.yolasite.com | ||
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alright, update time after a long and busy week! Went out tonight to get 2 clean logs. While the car on vdyno doesn't show to be making more power, for some reason it felt like it pulled harder. Data-log 1 and 2 are from tonight with the new map featuring the change in timing (less timing in the lower part of the RPM band, and 1 degree of more timing added to the upper RPM band) along with the boost target changes as suggested by ;chaser27@ For a better idea of what HP the car is making, I factored in my weight to the vdyno graphs as shown. This also lets me think the car is making more powah! Data-log 3 and 4 on the vdyno are the two logs from the previous map
![]() | | #54 | ![]() |
Groans: 42
| Not Ranked : 0 score It looks like the boost curve is basically identical to the old one, minus the lower rpms. You have a bit of boost spike down low, you could back down WGDC there a bit. Double check all your load tables and makes sure you aren't hitting any limits around 5500. Looking at WGDC there, you can see it levels off and then kicks up again.
| The Following User Says Thank You to chaser27 For This Useful Post: | OCspeed (12-13-2014) |
![]() | | #55 | ![]() |
I too saw that the boost curve, besides the spool up, looks exactly the same. It actually seems to be slightly under boosting. I also think i'm getting to the point where timing is gonna have to stay where it is, unless you or enki think I can run another half degree to a full degree up top. It feels like i'm missing something to make more power, but maybe that's just me wanting more and more haha
![]() | | #56 | ![]() |
Groans: 189
| Not Ranked : 0 score You're about tapped out it seems. On 50/50 E85 mix, I never could make more than 250 @ 6k rpm with the stock boost control setup due to elevation. That was with MBT timing, and 100% WGDC.
![]() | | #57 | ![]() |
And what do you think about upping WGDC in some areas to help up and hold boost a little better, or should I just leave as is and stop whining? haha
![]() | | #58 | ![]() |
Groans: 189
| Not Ranked : 0 score It's hard to say. Every car is different as to what timing numbers it likes, but it is possible. The question is, how far do you want to push this? Too far and it won't last nearly as long; stock block power is a tradeoff of zoom vs longevity, which not only applies to your engine, but turbo as well. If you don't care about longevity of the engine, then by all means, find out what she can do.
![]() | | #59 | ![]() |
![]() It looks like i'm gonna keep the tune where it's at. I'm all about making power, but this is my DD, and i'm not down to push it so far where i'm on the ragged edge
![]() | | #60 | ![]() |
Groans: 189
| Not Ranked : 0 score Do you know where the ragged edge is yet?
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score Maybe I have an idea in some aspects considering the turbo and stock block along with aggressive timing. But really, no
![]() | | #62 | ![]() |
Groans: 189
| Not Ranked : 0 score You should be fine to find out, but don't run that tune full time.
| The Following User Says Thank You to Enki For This Useful Post: | OCspeed (12-13-2014) |
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm gonna take my chances and not try to find out. In all honesty, i'm happy with where the car is right now. I don't feel like going into the unknown and taking a risk. Am I leaving a couple HP or TQ on the table? Maybe, but who cares, the car feels great ![]() Also, I couldn't have gotten to where I am at the moment without all the info on MSF, mister Enki for his fuel mix cheat sheet and all his help, Chaser27 with all his help, and everyone else that contributed to the the thread, so really, THANK YOU
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just for a little update, the car is still running great and feels strong. I don't get the chance to get on it a lot, but when I do it feels great Just a quick question and concern: I remember reading something along the lines that if you tune for E85 during the winter, you will go lean during the summer months. Being in California and how random the weather here is in socal, should I be worried for the upcoming warmer days/months since I tuned during cold temps? Maybe i'm over-thinking this, but any input would be appreciated
![]() | | #65 | ![]() |
Groans: 189
| Not Ranked : 0 score You're on 50/50; I wouldn't be too worried if I were you, just take a look at your fuel trims every now and then.
| The Following User Says Thank You to Enki For This Useful Post: | OCspeed (01-25-2015) |
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score After getting pulled over, stocking out, and facing the state ref, I finally have my car back to the way it was. I changed my catted DP to a catless setup and went back to the 50/50 mix and flashed my tune. I did one log getting on the freeway and it seems like everything is running fine (log attached). Going catless I expected to have boost issues here and there but it seems to run fine and seems to be slightly under boosting by a little (.5-1psi). The new E85 station that opened up down the street from me last week has got me thinking to switch over to 100% E85 since I have a oil change coming up in a hundred miles and go with the Royal Purple and the S-1 combo. Should I expect gains from switching over? I think I read Enki (or maybe it was someone else?) mentioned that you can keep the same inputs on the tune and just calibrate the intake and you should see some gains? I may be wrong though
| The Following User Says Thank You to OCspeed For This Useful Post: | Koke382 (07-28-2015) |
![]() | | #67 | ![]() |
Groans: 189
| Not Ranked : 0 score Stock turbo you can gain a touch of airflow up top by going full corn; the biggest benefit, however, is the smoothness and only one pump per trip to the gas station.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Justin@Freektune (07-28-2015), OCspeed (07-29-2015) |
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I guess the only loss i'll have/might have is my fuel level sensor going out with the E85 eating away at the connectors
![]() | | #69 | ![]() |
Groans: 189
| Not Ranked : 0 score There's a thread on this issue and how to resolve it.
![]() | | #70 | ![]() |
Groans: 438
| Not Ranked : 0 score And about 100 miles less per tank.
__________________ All good things must come to an end... |
![]() | | #71 | ![]() |
Groans: 189
| Not Ranked : 0 score Depending on tune/driving style.
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score Eh, evens out with the cheaper cost of E85/gallon
| Lean at WOT | LatinKraze | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 01-10-2014 02:36 PM |
| Lean at WOT | Jettster91 | Mazdaspeed3/6 General Discussion | 14 | 04-30-2013 03:51 AM |
| too lean during WOT | evolizzee | 2010 MS3 - Troubleshoot/Diagnostics | 13 | 10-11-2012 05:17 PM |
| Dealers got lean; many plan to stay lean | Haltech | Automotive News | 0 | 05-30-2010 10:10 PM |
| to lean?? | wisniaPl | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 04-04-2009 07:27 PM |
