| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() | | #81 | ![]() |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score
I've been meaning to do the swap, but it's below freezing at night where I am, and don't have the urge to have car troubles right now...
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP | |
![]() | | #82 | ![]() |
![]() Join Date: Nov 2009 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score I've never trusted Nulon for some reason, prob because I asked them what I should run for E85 and 98 for 500 crank hp Mazdaspeed/MPS and they said I should run their Full Synthetic 15W-50 Street and Track Engine Oil Nulon is only in Aus so didn't think it would be much good for everyone else if it was OK to use Last edited by cletusb; 06-09-2015 at 02:50 AM. |
| The Following User Says Thank You to cletusb For This Useful Post: | littleloogy (06-09-2015) |
![]() | | #83 | ![]() |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
(Thread Starter) | Not Ranked : 0 score Update for the hell of it... Somewhere near 15k miles, stopped paying attention. I know it wasn't a unicorn E85 pump/blend either as I have run a full tank from a different NY station, a full tank from a station in Maryland, and now 3 full tanks from the station here in VA. Redline s-1 holding strong, zero startup issues, zero FP issues. /thread.
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
![]() | | #84 | ![]() |
Mainly is it just the rebuild or have you had to "top up" the S1 at all | |
![]() | | #85 | ![]() |
![]() Join Date: Jan 2012 Location: mars
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
| Not Ranked : 0 score i believe it's just needed for the fuel pump rebuild
__________________ [SIGPIC][/SIGPIC] Corn Fed//Richtuned |
![]() | | #86 | ![]() |
(Thread Starter) | Not Ranked : 0 score Rebuilt the pump with S-1. After thousands thousands of miles did it again just to verify and check. Been thousands and thousands of miles since that "rebuild". Never a drop in tank. Still have half the original bottle of S-1 that I bought last year.
| The Following User Says Thank You to MSP6 For This Useful Post: | Enki (07-20-2015) |
![]() | | #87 | ![]() |
Groans: 189
| Not Ranked : 0 score If/when it does start to act up again, just pull the spill valve and flush it out with S1 using a syringe.
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | MSP6 (07-20-2015) |
![]() | | #88 | ![]() |
![]() Join Date: Dec 2013 Location: Pinckney, Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 794
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score Would you guys suggest running a bottle of that redline on a full tank also?? It does really well on the HPFP. What about the rest of the system?? I run a eth drier in my tank once a oil change. I've put about 20k on my car with a 4/8 mix. I would love to do a full E85 tune. I have yet pulled my internals to see whats going on. Data logging shows good pressure though.
__________________ 2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30 |
![]() | | #89 | ![]() |
Groans: 189
| Not Ranked : 0 score No. Don't put any in the tank as it won't help. It's fairly well proven that nothing in the tank will help at all.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | ALPINEST4RS (07-20-2015), cocoanton (07-20-2015) |
![]() | | #90 | ![]() |
If that's all it takes to get it working again, could that be enough to get it working the first time?
![]() | | #91 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
The beginning of my additive thread begs to differ. I was able to do thousands of miles when adding 1oz per gallon. But the cost to benefit ratio was way to high, which lead me to injecting directly into the SV, which was a pain in the ass, which lead me to developing the add into pump method. I know the thread is long and hard to follow, but the info is in there. Sent from my iPhone 6 | |
![]() | | #92 | ![]() |
Groans: 189
| Not Ranked : 0 score Never helped me; nothing in the tank did. Not even when I was running my car on 40% lighter fluid (which is the best thing I've found for cleaning the pump).
![]() | | #93 | ![]() |
| Not Ranked : 0 score Did you try si1 in the tank? That was the only one that worked for me. All others ![]() Sent from my iPhone 6 |
![]() | | #94 | ![]() |
Groans: 189
| Not Ranked : 0 score A full bottle with probably 2-3 gallons left in the tank. No bueno.
![]() | | #95 | ![]() |
![]() Join Date: Apr 2014 Location: san diego CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score This is awesome ill have to give it a try now that they put an e85 pump 4 miles from my house. Time to get on some corn! |
![]() | | #96 | ![]() |
![]() Join Date: Jun 2015
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 3
Groaned at 9 Times in 5 Posts
| The Following 2 Users Say Thank You to SPEEDO90 For This Useful Post: | g00s3y (08-08-2015), littleloogy (08-07-2015) |
![]() | | #97 | ![]() |
| Not Ranked : 0 score you guys have me thinking of going full E over here myself. Running CPE pump.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
| The Following User Says Thank You to Dano For This Useful Post: | littleloogy (08-08-2015) |
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score Doooooo it.
![]() | | #99 | ![]() |
Groans: 438
| Not Ranked : 0 score It's fun. I may be going back full e possibly. Just saw it was $1.84 when I went to mix yesterday. With prices still dropping, it's getting temping. 15mpg is just hard to swallow, among other things that are hard to swallow... Or so I hear, I wouldn't know...
__________________ All good things must come to an end... |
![]() | | #100 | ![]() |
| Not Ranked : 0 score |
![]() | | #101 | ![]() |
Groans: 438
| Not Ranked : 0 score See no reason why si-1 wouldn't work with the CP-E pump also. Worst that happens is you get some sticky death, have to pull the pump and clean it. Or just inject some into the spill valve.
| The Following 2 Users Say Thank You to g00s3y For This Useful Post: | Enki (08-09-2015), littleloogy (08-09-2015) |
![]() | | #102 | ![]() |
(Thread Starter) | Not Ranked : 0 score Unintentional testing in progress: Work schedule went whacky for a few days and I got fed up and filled up with 93. (Corn is 16 miles from me) Ran a half tank and dialed in my 93 tune. Filled back up with E and ran a full tank of 50/50 (or close enough) Now back to full corn today so we'll see how the Redline and RP like switching back and forth.
![]() | | #103 | ![]() |
| Not Ranked : 0 score my other main issue, against going full E, is my lack of fueling headroom. I don't relish having ~ 30% of my fueling coming from a meth nozzle and I am not investing in a 5th port. My meth failsafe bit the dust back in the spring and I have not implemented a replacement solution as of yet. No other WMI failsafes will work with 100% meth so I am looking at the AEM AFR failsafe as a replacement solution BUT I can't mount it in the aux bung on my DP because my CPE EM blocks one of them. TL;DR its like 15 steps to get there for god's sake.
![]() | | #104 | ![]() |
Groans: 189
| Not Ranked : 0 score My meth failed at the track; 24 psi and 14 AFR. No knock, just a loss of power.
![]() | | #105 | ![]() |
Groans: 438
__________________ All good things must come to an end... | |
| The Following User Says Thank You to g00s3y For This Useful Post: | Enki (08-12-2015) |
![]() | | #106 | ![]() |
![]() Join Date: Mar 2014 Location: Ventura county, CA
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Ok so I been reading about e85 for some hours and this is my very first comment/post here in the forum ever since I joined. I recently became passionate about going full e85 ever since I watched the documentary film "Pump" on the Netflix and pretty much decided to give my big middle finger to the corrupted government and the oil companies. If you haven't seen it I highly recommend ya'll to watch it. You'll be surprised to see what you can learn. Anyways, I'm trying to understand and write down the steps and necessary parts to go full e85 and here is what I have so far. 1) AP, 2) HPFP, 3) Change my oil to RP dexos spec. 4) Clean out HPFP and the spill valve with S-1 fuel system treatment. 4) Get a tune or self-tune(although I know nothing about it but I'm willing to read and learn. Please guide me to right direction). Is there anything else that I should add to the list? I thank you in advance and I hope to get positive feedback. |
![]() | | #107 | ![]() |
| Not Ranked : 0 score Hard to believe that the SI-1 protects the HPFP in the long run. It is a great cleaner but with the amount of fuel running through it, I don't see it "sticking around." What is more likely happening is that oil manufacturers (along with fuel manufacturers) are creating products that are more compatible with each other as the use of ethanol is common and the tight tolerances of DI engines are used by all OEMs. This is supported by the Dexos1 specification (http://www.hankgraffbgc.com/Dexos1.pdf) - improved oxidation and reduced volatility. Is there any data on foregoing the SI-1 cleaning, changing to a Dexos1 oil and then after a couple of oil changes switching to full E85? Cleaning the HPFP of old oil deposits is not a bad idea - but some are reluctant to pull the pump and the risk of flexing the hard line causing a possible leak down the road is always there.
| The Following User Says Thank You to Lex For This Useful Post: | TORQUERULES (05-31-2016) |
![]() | | #108 | ![]() |
Groans: 189
| Not Ranked : 0 score Yes, if memory serves. Pretty sure I've posted in my EFR thread about this too. I was running RP for a while, and cut over and had issues after a short period of time. Cleaned out with Redline, primed with Redline, and it took a very, very long time to have the occasional intermittent issue again (which was fixed by simply re-priming with redline).
![]() | | #109 | ![]() |
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." | |
![]() | | #110 | ![]() |
| Not Ranked : 0 score @Lex; if someone wants to send me their extra Autotech internals I would be more then willing to test that. I have been skeptical about the results of this treatment also, almost like it was too good to be true. Only one way to find out. Sent from my iPhone 6 |
![]() | | #111 | ![]() |
Groans: 189
| Not Ranked : 0 score If you look at the pump design, there shouldn't be a whole lot of fuel actually moving through the internals area of the pump; there's only a vent in the collar so that fluids behind the piston can move to next to it, and would then go right back to where it was on stroke. Would it dilute over time? Certainly. Is it possible that you only need a very small amount of redline present to prevent issues? Plausible. I could probably pull a sample from my pump and see how clear/pink it is compared to regular corn/meth.
![]() | | #112 | ![]() |
| Not Ranked : 0 score HEY GUYS! So its been one month and 18 days now on 100% E85 tune using this S1 and RP oil method and I have to say.... Not bad I have not noticed any issues at all, car is running strong and healthy! I haven't opened my spill valve yet to see if I need to inject S1 for gunk, but I don't see why I would have to so soon.... Its only been a month and few days so ill give it till my next oil change to open it up and check it out. I will post when that time comes around! Has anyone else tried this? I would like to hear your stories running full E85! |
| The Following User Says Thank You to SPEEDO90 For This Useful Post: | littleloogy (09-25-2015) |
![]() | | #113 | ![]() |
| Not Ranked : 0 score @SPEEDO90; that's great man! Hope you have as much success as everyone else. Keep us posted! Sent from my iPhone 6 |
![]() | | #114 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score On a separate subject if I may chime in here, I have been having really bad oil consumption and I think its the oil not draining out of my turbo fast enough and I wonder if it is because I am running T6 which is 15-40, maybe If i switch back to an oil that is 5w-30 it will drain better and ill stop hemorrhaging oil and burning it in my exhaust. I come to this conclusion while reading all of this about oil, and I run T6 because the forums said to .... but I am wondering now if that is why my couch is getting fucked so badly, I put in a quart of oil like every other gas tank. |
![]() | | #115 | ![]() |
| Not Ranked : 0 score Have you been using the wrong T6? I can't get it where I live but from reading the forums I'm pretty sure everyone runs the 5w40 version. Don't know anyone running a 15w oil |
![]() | | #116 | ![]() |
| Not Ranked : 0 score I hope if i switch to 5w- 30 my issues will go away shit might already be ruined though. I dont know how I ended up with 15-40 EDIT: wait wtf ..... I look at my amazon history and all I have been buying is 5w-40 why the fuck do I have 15w-40, i don't have 15 in my purchase history. |
![]() | | #117 | ![]() |
![]() Join Date: May 2012
| Not Ranked : 0 score Isn't it called SI-1? I only found Redline SI-1 (60103), is that the correct one or are they different? Regarding the Oil: Would Mobil 1 ESP 0W-40 (151496) be good too? Someone tried that? It even has dexos2 approval (instead of dexos1). Royal Purple isn't an option around here (Europe). |
![]() | | #118 | ![]() |
| Not Ranked : 0 score yes it is si-1 not s-1. As far as oil, I belive only RP has been tested successful so far but that doesn't stop you from trying some other dexos spec oil.
| The Following User Says Thank You to Dano For This Useful Post: | Enki (11-05-2015) |
![]() | | #119 | ![]() |
Groans: 189
| Not Ranked : 0 score Shell Helix Ultra is the oil I wanted to test originally, as it's also Dexos spec.
| The Following User Says Thank You to Enki For This Useful Post: | Dano (11-05-2015) |
![]() | | #120 | ![]() |
| Not Ranked : 0 score I'm first gonna test one of the LiquiMoly additives: 3720, 5108 or 5110 and give you guys feedback. Would be a more viable option here, i had to order the SI-1 from the US and A, and it took almost two weeks (and it cost me 30$ ) |
| Montezemolo steps down, Marchionne steps up as chairman of Ferrari | Haltech | Automotive News | 0 | 09-10-2014 07:20 AM |
| Fisker CEO Tony Posawatz steps down, Bernhard Koehler steps in | Haltech | Automotive News | 0 | 08-26-2013 10:30 AM |
| Full Redline Leathers for MS6 | 06Speed6 | MazdaSpeed 3/6 - Appearance | 1 | 05-07-2010 11:34 PM |
| ideally whats the best boost targets for custom tune from full boost to redline? | Wenis Prinkle | Cobb ATR Support | 26 | 08-24-2009 06:36 PM |
| Laurens van der Acker steps down as Mazda design chief, Ikuo Maeda steps up | Haltech | Automotive News | 0 | 04-01-2009 09:30 AM |
