Like Tree27Likes
 Old 05-27-2016, 04:54 PM   #161
Gerbilo's Avatar
Posts: 612   (View Stats)
Gerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the world
Originally Posted by Orangatang View Post
ahem. Oreilly auto near me.(phone turned photo sideways.)
Can confirm. dexos1 Brands
Just took this photo a minute ago of the box next to my desk.
I'm not disputing any of your findings on this subject, just saying PennzPlat is dexos1 and I swear it has been for a while.
I'm going to shut up now and let you good folks science me, as usual.
2010 CBM Mazdaspeed3
Freektune 93
CorkSport SRI, TIP & Race Pipe
CP-E Stage 2 RMM & TMIC
Cobb Accessport V3
Autotech HPFP Internals
Pilot Super Sport 235/40/18 - Stock Pu
Pilot Alpin PA3 215/50/17 - Sport Edition CE
2016.5 MGM Mazda CX-5 Touring
Gerbilo is offline   Reply With Quote
 Old 05-27-2016, 07:04 PM   #162
blackms3_71's Avatar
Posts: 2,250   (View Stats)
$9 a qt? Fuck that. Go to walmart.
The Following 2 Users Say Thank You to blackms3_71 For This Useful Post:
CWP_MS3 (11-02-2016), Gerbilo (05-27-2016)
 Old 05-27-2016, 07:36 PM   #163
Orangatang's Avatar
Posts: 466   (View Stats)
Orangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the world
Attachment 225677
I know you were not disputing my findings. Just adding to it.
Corksport stage 2 sri/tip, Autotech Internals, RSB,
CBE, Forge bpv, Koni FSD, Mazda Sport Springs,
ITV22, JBR PMM, JBR TMM, JBR RMM, Damond SSP
JBR SSB, CX piping with TR6, DM OCC
Dizzy Tuned
" I just don't need a stage 6, 16 puck, teflon diamond plated clutch that can snap a femur downshifting." -Raider
Orangatang is offline   Reply With Quote
 Old 05-27-2016, 10:03 PM   #164
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Test it and let us know how it goes.
No, really. Do it.
 Old 05-29-2016, 05:22 PM   #165
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
that is def new...at least as of 6 months ago. give it a try. RP is spensive.
 Old 05-29-2016, 07:09 PM   #166
Amaroms3's Avatar
Posts: 68   (View Stats)
Amaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to beholdAmaroms3 is a splendid one to behold
Might be giving this a try. I've been running pennzoil platnium for about 2 years now. My internals are coming in this week I hope and will be doing the sl1 treatment with this oils so hopefully works out for me.
Amaroms3 is offline   Reply With Quote
 Old 05-29-2016, 11:40 PM   #167
Orangatang's Avatar
Sadly I am not full e85. just a little e85 mixed in.
I just like to read posts and try to help out when I can.
Dizzy Tuned
 Old 05-31-2016, 08:55 AM   #168
TORQUERULES's Avatar
Posts: 283   (View Stats)
TORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond repute
I am probably never going to go full E85, but wonder if at least using the Redline treatment on the spill valve would be good for a car running a 30% mix? I have never ran it yet, getting ready to try it out soon, and I already run a Dexos 1 oil.
(SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc.
2017 Mazda CX-3 Meteor Gray
TORQUERULES is offline   Reply With Quote
 Old 05-31-2016, 11:49 AM   #169
Trail of Fail
Dano's Avatar
not needed.
on a 4/8 gallon mix, E35, no oil or Si-1 additions are needed. I believe problems with the CDFP tend to arise approaching a 50% concentration of E.
I am running a E40ish, 5/7 mix, without issue and have been for over a year, but want to go to 50% so switched to RP. Going to try and not use Si-1 at all.
So bottom line you don't need to do a thing with oil and if you want piece of mind you can throw some Si-1 into the spill valve but likely not necessary to maintain pressure.
Enki (05-31-2016), TORQUERULES (06-01-2016)
 Old 06-01-2016, 06:17 AM   #170
That is what I figured, but I thought it a good idea to ask. Thanks.
 Old 06-10-2016, 06:06 PM   #171
Mazd1222's Avatar
Posts: 74   (View Stats)
Mazd1222 has a spectacular aura aboutMazd1222 has a spectacular aura about
Groaned at 16 Times in 7 Posts
Default e85
Can I run my standard tune with a e50 mix in the tank
Mazd1222 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Mazd1222 For This Un-useful Post:
Cheapspeed (06-10-2016), g00s3y (06-11-2016)
 Old 06-10-2016, 11:30 PM   #172
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
No.
 Old 06-11-2016, 04:48 AM   #173
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Yes, you can actually.
Just let us know how long it takes for your car to fuck up afterwards. Because it will happen doing something stupid like that.
 Old 06-19-2017, 07:43 AM   #174
MSP6's Avatar
Posts: 1,246   (View Stats)
Issues with the hardware fix came up, bumping this for any new searchers.
Just shy of 30k miles and 2.5 years and no sticking issues, and not a single cold start issue since moving to VA. It's not E-85 supply specific as I have used 6-7 different stations in 3 different states.
Car has seen <1k of 93 spread out over that time when E85 pumps have been down and I was lazy during that week and on the gas light.
Redline S1 cleans existing black death, RP Dexxos spec prevents further death. We win.
wes3id, Hoyoman and TRBLSM like this.
 Old 12-14-2017, 12:02 PM   #175
Arab's Avatar
Posts: 15   (View Stats)
Arab has a spectacular aura aboutArab has a spectacular aura about
Raising the dead here...
I ran e30 from 2012 until around a year ago, took around 4 years/40k miles with Rotella t6 for black death to build up and cause a loss of pressure. I switched to RP dexos1, cleaned and lubed the pump and spill valve with redline and stayed on e30 for 2 oil more changes with RP. Both oil changes I did the redline cleaning just to be overkill about it, and had my RV get stuck open. So I replaced the RV, cleaned the pump again and switched to e85. This semester I had to drive 80 miles a day going to class and back home 4 days a week so my car got plenty of miles on it and went through a lot of tanks of e85 and now my RV problem is back(I think, problems detailed below).
My idle FP bounces from 70~90 psi and the car is a bitch to get started, but I'll get it to idle after like 30 minutes of cranking and watching it rev up to cold idle(~2200 rpm) and dying immediately. Also when it does hold idle the rpms drop when I blip the throttle. I've tried injecting redline through the spill valve and took the pump back off, disassembled it, soaked all parts in redline again(there was no build up at all on them when removed), and verified I reassembled it right by following the rallysportdirect instructions and the OP and torqued the internals down with a torque wrench. I can't decide if my problem is the ITFP or RV but I'm suspecting the RV, so any ideas of what to check or what tests I can do would be awesome. I'm also wondering if anything could be helped by soaking the RV in redline and cleaning it cuz I'm trying to save money to get an awd subframe for my civic I picked up a few weeks ago(couldn't say no to a $100 Honda that runs and drives but I can't go back to fwd after having awd this long lol) plus I gotta pay tuition soon so I can't just buy a pump and RV right now but with my luck I need both.
Sent from my SM-G955U using Tapatalk
06 Speed6 @85k
Mods: 3" TBE, JBR Tru-3.0, Autotech Internals, CX FMIC, Turbosmart Hybrid, RMM, TurbineTech Diff Mounts, H&R Springs, AP tuned on e30
Arab is offline   Reply With Quote
 Old 12-15-2017, 06:59 AM   #176
MSP6's Avatar
That sounds like a stuck RV if not a combo of things. Doesn't seem like the ITFP because you would not get any fuel up to the HPFP if it was dead.
Try slowly increasing throttle and then giving it a quick blip. Watch FP to see if it slowly builds as you lightly increase throttle and then plummets when you jab the throttle. This is what mine did back in the day when my RV died. If you bought a used RV there is a good chance it was already shot.
The Following User Says Thank You to MSP6 For This Useful Post:
Arab (12-15-2017)
 Old 12-15-2017, 07:25 AM   #177
Arab's Avatar
The RV I put in was new. I'll try that when I get back home later today though
06 Speed6 @85k
Montezemolo steps down, Marchionne steps up as chairman of Ferrari Haltech Automotive News 0 09-10-2014 07:20 AM
Fisker CEO Tony Posawatz steps down, Bernhard Koehler steps in Haltech Automotive News 0 08-26-2013 10:30 AM
Full Redline Leathers for MS6 06Speed6 MazdaSpeed 3/6 - Appearance 1 05-07-2010 11:34 PM
ideally whats the best boost targets for custom tune from full boost to redline? Wenis Prinkle
Cobb ATR Support
26 08-24-2009 06:36 PM
Laurens van der Acker steps down as Mazda design chief, Ikuo Maeda steps up Haltech Automotive News 0 04-01-2009 09:30 AM
Page generated in 0.41376 seconds with 32 queries
